[PATCH 7/8] c-user: Generate barrier manager documentation
    Sebastian Huber
    Tue Feb  9 09:43:27 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup.  The documentation was
transfered to interface specification items.  The documentation source
files were generated from the items by a script.
Update #3993.
 c-user/barrier/directives.rst   | 569 ++++++++++++++++++++------------
 c-user/barrier/index.rst        |   2 +
 c-user/barrier/introduction.rst |  45 ++-
 3 files changed, 398 insertions(+), 218 deletions(-)
diff --git a/c-user/barrier/directives.rst b/c-user/barrier/directives.rst
index 9d1fdc0..2cb5ced 100644
--- a/c-user/barrier/directives.rst
+++ b/c-user/barrier/directives.rst
@@ -1,265 +1,416 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 1988, 2018 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated.  If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual.  The manual is provided as a part of
+.. a release.  For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _BarrierManagerDirectives:
 Directives
-This section details the barrier manager's directives.  A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
+This section details the directives of the Barrier Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/barrier/if/create
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_barrier_create()
 .. index:: create a barrier
-.. index:: rtems_barrier_create
-.. _rtems_barrier_create:
-BARRIER_CREATE - Create a barrier
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_barrier_create(
-            rtems_name           name,
-            rtems_attribute      attribute_set,
-            uint32_t             maximum_waiters,
-            rtems_id            *id
-DIRECTIVE STATUS CODES:
-    .. list-table::
-     :class: rtems-table
-     * - ``RTEMS_SUCCESSFUL``
-       - barrier created successfully
-     * - ``RTEMS_INVALID_NAME``
-       - invalid barrier name
-     * - ``RTEMS_INVALID_ADDRESS``
-       - ``id`` is NULL
-     * - ``RTEMS_TOO_MANY``
-       - too many barriers created
-DESCRIPTION:
-    This directive creates a barrier which resides on the local node. The
-    created barrier has the user-defined name specified in ``name`` and the
-    initial count specified in ``count``.  For control and maintenance of the
-    barrier, RTEMS allocates and initializes a BCB.  The RTEMS-assigned barrier
-    id is returned in ``id``.  This barrier id is used with other barrier
-    related directives to access the barrier.
-    .. list-table::
-     * - ``RTEMS_BARRIER_MANUAL_RELEASE``
-       - only release
-    Specifying ``RTEMS_BARRIER_AUTOMATIC_RELEASE`` in ``attribute_set`` causes
-    tasks calling the ``rtems_barrier_wait`` directive to block until there are
-    ``maximum_waiters - 1`` tasks waiting at the barrier.  When the
-    ``maximum_waiters`` task invokes the ``rtems_barrier_wait`` directive, the
-    previous ``maximum_waiters - 1`` tasks are automatically released and the
-    caller returns.
-    In contrast, when the ``RTEMS_BARRIER_MANUAL_RELEASE`` attribute is
-    specified, there is no limit on the number of tasks that will block at the
-    barrier. Only when the ``rtems_barrier_release`` directive is invoked, are
-    the tasks waiting at the barrier unblocked.
-NOTES:
-    This directive may cause the calling task to be preempted due to an
-    obtain and release of the object allocator mutex.
-    The following barrier attribute constants are defined by RTEMS:
-    .. list-table::
-     * - ``RTEMS_BARRIER_AUTOMATIC_RELEASE``
-       - automatically release the barrier when the configured number of tasks are
-         blocked
-       - only release the barrier when the application invokes
-         the ``rtems_barrier_release`` directive.  (default)
+.. _InterfaceRtemsBarrierCreate:
+rtems_barrier_create()
+Creates a barrier.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+    rtems_status_code rtems_barrier_create(
+      rtems_name      name,
+      rtems_attribute attribute_set,
+      uint32_t        maximum_waiters,
+      rtems_id       *id
+.. rubric:: PARAMETERS:
+``name``
+    This parameter is the object name of the barrier.
+``attribute_set``
+    This parameter is the attribute set of the barrier.
+``maximum_waiters``
+    This parameter is the maximum count of waiters on an automatic release
+    barrier.
+``id``
+    This parameter is the pointer to an object identifier variable.  The
+    identifier of the created barrier will be stored in this variable, in case
+    of a successful operation.
+.. rubric:: DESCRIPTION:
+This directive creates a barrier which resides on the local node.  The barrier
+has the user-defined object name specified in ``name`` and the initial count
+specified in ``attribute_set``.  The assigned object identifier is returned in
+``id``.  This identifier is used to access the barrier with other barrier
+related directives.
+The **attribute set** specified in ``attribute_set`` is built through a
+*bitwise or* of the attribute constants described below.  Not all combinations
+of attributes are allowed.  Some attributes are mutually exclusive.  If
+mutually exclusive attributes are combined, the behaviour is undefined.
+Attributes not mentioned below are not evaluated by this directive and have no
+effect.  Default attributes can be selected by using the
+:c:macro:`RTEMS_DEFAULT_ATTRIBUTES` constant.
+The **barrier class** is selected by the mutually exclusive
+:c:macro:`RTEMS_BARRIER_MANUAL_RELEASE` and
+:c:macro:`RTEMS_BARRIER_AUTOMATIC_RELEASE` attributes.
+* The **manual release class** is the default and can be emphasized through use
+  of the :c:macro:`RTEMS_BARRIER_MANUAL_RELEASE` attribute.  For this class,
+  there is no limit on the number of tasks that will block at the barrier. Only
+  when the :ref:`InterfaceRtemsBarrierRelease` directive is invoked, are the
+  tasks waiting at the barrier unblocked.
+* The **automatic release class** is selected by the
+  :c:macro:`RTEMS_BARRIER_AUTOMATIC_RELEASE` attribute.  For this class, tasks
+  calling the :ref:`InterfaceRtemsBarrierWait` directive will block until there
+  are ``maximum_waiters`` minus one tasks waiting at the barrier.  When the
+  ``maximum_waiters`` task invokes the :ref:`InterfaceRtemsBarrierWait`
+  directive, the previous ``maximum_waiters`` - 1 tasks are automatically
+  released and the caller returns.
+.. rubric:: RETURN VALUES:
+:c:macro:`RTEMS_SUCCESSFUL`
+    The requested operation was successful.
+:c:macro:`RTEMS_INVALID_NAME`
+    The ``name`` parameter was invalid.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+    The ``id`` parameter was `NULL
+    <https://en.cppreference.com/w/c/types/NULL>`_.
+:c:macro:`RTEMS_INVALID_NUMBER`
+    The ``maximum_waiters`` parameter was 0 for an automatic release barrier.
+:c:macro:`RTEMS_TOO_MANY`
+    There was no inactive object available to create a barrier.  The number of
+    barriers available to the application is configured through the
+    :ref:`CONFIGURE_MAXIMUM_BARRIERS` application configuration option.
+.. rubric:: NOTES:
+For control and maintenance of the barrier, RTEMS allocates a :term:`BCB` from
+the local BCB free pool and initializes it.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex.  This may
+  cause the calling task to be preempted.
+* The number of barriers available to the application is configured through the
+* Where the object class corresponding to the directive is configured to use
+  unlimited objects, the directive may allocate memory from the RTEMS
+  Workspace.
+.. Generated from spec:/rtems/barrier/if/ident
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_barrier_ident()
+.. _InterfaceRtemsBarrierIdent:
+rtems_barrier_ident()
+Identifies a barrier by the object name.
+.. code-block:: c
+    rtems_status_code rtems_barrier_ident( rtems_name name, rtems_id *id );
+``name``
+    This parameter is the object name to look up.
+``id``
+    This parameter is the pointer to an object identifier variable.  The object
+    identifier of an object with the specified name will be stored in this
+    variable, in case of a successful operation.
+This directive obtains a barrier identifier associated with the barrier name
+specified in ``name``.
+    The ``name`` parameter was 0.
-.. index:: get ID of a barrier
-.. index:: obtain ID of a barrier
-.. index:: rtems_barrier_ident
+    There was no object with the specified name on the local node.
-.. _rtems_barrier_ident:
+.. rubric:: NOTES:
-BARRIER_IDENT - Get ID of a barrier
+If the barrier name is not unique, then the barrier identifier will match the
+first barrier with that name in the search order.  However, this barrier
+identifier is not guaranteed to correspond to the desired barrier.
-CALLING SEQUENCE:
-    .. code-block:: c
+The objects are searched from lowest to the highest index.  Only the local node
+is searched.
-        rtems_status_code rtems_barrier_ident(
-            rtems_name        name,
-            rtems_id         *id
+The barrier identifier is used with other barrier related directives to access
+the barrier.
-    .. list-table::
-       - barrier identified successfully
-       - barrier name not found
-     * - ``RTEMS_INVALID_NODE``
-       - invalid node id
-DESCRIPTION:
-    This directive obtains the barrier id associated with the barrier name.  If
-    the barrier name is not unique, then the barrier id will match one of the
-    barriers with that name.  However, this barrier id is not guaranteed to
-    correspond to the desired barrier.  The barrier id is used by other barrier
+* The directive may be called from within any runtime context.
-NOTES:
-    This directive will not cause the running task to be preempted.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/barrier/if/delete
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_barrier_delete()
 .. index:: delete a barrier
-.. index:: rtems_barrier_delete
-.. _rtems_barrier_delete:
+.. _InterfaceRtemsBarrierDelete:
+rtems_barrier_delete()
+Deletes the barrier.
+.. code-block:: c
+    rtems_status_code rtems_barrier_delete( rtems_id id );
+``id``
+    This parameter is the barrier identifier.
+This directive deletes the barrier specified by ``id``.  All tasks blocked
+waiting for the barrier to be released will be readied and returned a status
+code which indicates that the barrier was deleted.
+:c:macro:`RTEMS_INVALID_ID`
+    There was no barrier associated with the identifier specified by ``id``.
-BARRIER_DELETE - Delete a barrier
+.. rubric:: NOTES:
-CALLING SEQUENCE:
-    .. code-block:: c
+The :term:`BCB` for the deleted barrier is reclaimed by RTEMS.
-        rtems_status_code rtems_barrier_delete(
-            rtems_id id
-    .. list-table::
-       - barrier deleted successfully
-     * - ``RTEMS_INVALID_ID``
-       - invalid barrier id
-DESCRIPTION:
-    This directive deletes the barrier specified by ``id``.  All tasks blocked
-    waiting for the barrier to be released will be readied and returned a
-    status code which indicates that the barrier was deleted.  The BCB for this
-    barrier is reclaimed by RTEMS.
-NOTES:
-    The calling task will be preempted if it is enabled by the task's execution
-    mode and a higher priority local task is waiting on the deleted barrier.
-    The calling task will NOT be preempted if all of the tasks that are waiting
-    on the barrier are remote tasks.
+* The calling task does not have to be the task that created the object.  Any
+  local task that knows the object identifier can delete the object.
-    The calling task does not have to be the task that created the barrier.
-    Any local task that knows the barrier id can delete the barrier.
+  unlimited objects, the directive may free memory to the RTEMS Workspace.
+.. Generated from spec:/rtems/barrier/if/wait
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_barrier_wait()
 .. index:: wait at a barrier
-.. index:: rtems_barrier_wait
-.. _rtems_barrier_wait:
-BARRIER_WAIT - Wait at a barrier
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_barrier_wait(
-            rtems_id         id,
-            rtems_interval   timeout
-    .. list-table::
-       - barrier released and task unblocked
-     * - ``RTEMS_UNSATISFIED``
-       - barrier not available
-     * - ``RTEMS_TIMEOUT``
-       - timed out waiting for barrier
-     * - ``RTEMS_OBJECT_WAS_DELETED``
-       - barrier deleted while waiting
-DESCRIPTION:
-    This directive waits at the barrier specified by ``id``.  The timeout
-    parameter specifies the maximum interval the calling task is willing to be
-    blocked waiting for the barrier.  If it is set to ``RTEMS_NO_TIMEOUT``,
-    then the calling task will wait until the barrier is released.
-    Conceptually, the calling task should always be thought of as blocking when
-    it makes this call and being unblocked when the barrier is released.  If
-    the barrier is configured for manual release, this rule of thumb will
-    always be valid.  If the barrier is configured for automatic release, all
-    callers will block except for the one which is the Nth task which trips the
-    automatic release condition.
-NOTES:
-    A clock tick is required to support the timeout functionality of this
-    directive.
+.. _InterfaceRtemsBarrierWait:
+rtems_barrier_wait()
+Waits at the barrier.
+.. code-block:: c
+    rtems_status_code rtems_barrier_wait( rtems_id id, rtems_interval timeout );
+``id``
+``timeout``
+    This parameter is the timeout in clock ticks.  Use
+    :c:macro:`RTEMS_NO_TIMEOUT` to wait potentially forever.
+This directive waits at the barrier specified by ``id``.  The ``timeout``
+parameter defines how long the calling task is willing to wait.  Use
+:c:macro:`RTEMS_NO_TIMEOUT` to wait potentially forever, otherwise set a
+timeout interval in clock ticks.
+Conceptually, the calling task should always be thought of as blocking when it
+makes this call and being unblocked when the barrier is released.  If the
+barrier is configured for manual release, this rule of thumb will always be
+valid.  If the barrier is configured for automatic release, all callers will
+block except for the one which trips the automatic release condition.
+:c:macro:`RTEMS_TIMEOUT`
+    The timeout happened while the calling task was waiting at the barrier.
+:c:macro:`RTEMS_OBJECT_WAS_DELETED`
+    The barrier was deleted while the calling task was waiting at the barrier.
+.. rubric:: NOTES:
+For automatic release barriers, the maximum count of waiting tasks is defined
+during barrier creation, see :ref:`InterfaceRtemsBarrierCreate`.
+* The timeout functionality of the directive requires a clock tick.  Clock
+  ticks are provided by the clock driver, see
+  :ref:`CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER` application configuration
+  option.
+.. Generated from spec:/rtems/barrier/if/release
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_barrier_release()
 .. index:: release a barrier
-.. index:: rtems_barrier_release
-.. _rtems_barrier_release:
+.. _InterfaceRtemsBarrierRelease:
+rtems_barrier_release()
+Releases the barrier.
+.. code-block:: c
+    rtems_status_code rtems_barrier_release( rtems_id id, uint32_t *released );
+``id``
+``released``
+    This parameter is the pointer to an integer variable.  The number of
+    released tasks will be stored in this variable, in case of a successful
+    operation.
+This directive releases the barrier specified by ``id``.  All tasks waiting at
+the barrier will be unblocked.  The number of released tasks will be returned
+in ``released``.
-BARRIER_RELEASE - Release a barrier
+    The ``released`` parameter was `NULL
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_barrier_release(
-            rtems_id  id,
-            uint32_t *released
-    .. list-table::
-       - barrier released successfully
+* The directive may be called from within interrupt context.
-DESCRIPTION:
-    This directive releases the barrier specified by id.  All tasks waiting at
-    the barrier will be unblocked.
-NOTES:
-    The calling task may be preempted if it causes a higher priority task to be
-    made ready for execution.
+* The directive may unblock another task which may preempt the calling task.
diff --git a/c-user/barrier/index.rst b/c-user/barrier/index.rst
index 68cd472..ddf0b56 100644
--- a/c-user/barrier/index.rst
+++ b/c-user/barrier/index.rst
@@ -4,6 +4,8 @@
 .. index:: barrier
+.. _RTEMSAPIClassicBarrier:
 Barrier Manager
diff --git a/c-user/barrier/introduction.rst b/c-user/barrier/introduction.rst
index 5965eed..11013bf 100644
--- a/c-user/barrier/introduction.rst
+++ b/c-user/barrier/introduction.rst
@@ -1,20 +1,47 @@
+.. Generated from spec:/rtems/barrier/if/group
+.. _BarrierManagerIntroduction:
 Introduction
-The barrier manager provides a unique synchronization capability which can be
-used to have a set of tasks block and be unblocked as a set.  The directives
-provided by the barrier manager are:
+.. The following list was generated from:
+.. spec:/rtems/barrier/if/create
+.. spec:/rtems/barrier/if/ident
+.. spec:/rtems/barrier/if/delete
+.. spec:/rtems/barrier/if/wait
+.. spec:/rtems/barrier/if/release
-- :ref:`rtems_barrier_create`
+The Barrier Manager provides a unique synchronization capability which can be
+used to have a set of tasks block and be unblocked as a set. The directives
+provided by the Barrier Manager are:
-- :ref:`rtems_barrier_ident`
+* :ref:`InterfaceRtemsBarrierCreate` - Creates a barrier.
-- :ref:`rtems_barrier_delete`
+* :ref:`InterfaceRtemsBarrierIdent` - Identifies a barrier by the object name.
-- :ref:`rtems_barrier_wait`
+* :ref:`InterfaceRtemsBarrierDelete` - Deletes the barrier.
-- :ref:`rtems_barrier_release`
+* :ref:`InterfaceRtemsBarrierWait` - Waits at the barrier.
+* :ref:`InterfaceRtemsBarrierRelease` - Releases the barrier.
2.26.2
