[PATCH 2/4 v2] bsp/riscv: Add NOEL-V BSP
Tue Feb 9 13:36:12 UTC 2021
On 09/02/2021 12:40, Daniel Hellstrom wrote:
> From: Martin Aberg<maberg at gaisler.com>
> Added support for Cobham Gaisler NOEL-V systems. The NOEL-V support
> is implemented as a riscv BSP. Both 32-bit and 64-bit processor
> systems are supported. Cobham Gaisler's NOEL-V RISC-V processor IP
> is described here:
>    https://www.gaisler.com/NOELV
> Compatible with the following NOEL-V FPGA example design ranges
> available from Cobham Gaisler. Follow the links for free
> bit-streams, DTS/DTB, user'manuals and quick-start guides:
> - NOEL-ARTYA7-EX    (https://www.gaisler.com/NOEL-ARTYA7)
> - NOEL-PF-EX        (https://www.gaisler.com/NOEL-PF)
> - NOEL-XCKU-EX      (https://www.gaisler.com/NOEL-XCKU)
> Uses the shared GRLIB APBUART console driver "apbuart_termios.c".
> APBUART devices are probed using device tree.
> Update #4225.
Looks good.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
