[PATCH v2 09/12] c-user: Generate semaphore manager documentation
Wed Feb 10 16:28:06 UTC 2021
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup.  The documentation was
transfered to interface specification items.  The documentation source
files were generated from the items by a script.
Update #3993.
 c-user/semaphore/directives.rst   | 1485 ++++++++++++++++++-----------
 c-user/semaphore/introduction.rst |   52 +-
 2 files changed, 966 insertions(+), 571 deletions(-)
diff --git a/c-user/semaphore/directives.rst b/c-user/semaphore/directives.rst
index 460947d..28b639d 100644
--- a/c-user/semaphore/directives.rst
+++ b/c-user/semaphore/directives.rst
@@ -1,650 +1,1015 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020, 2021 embedded brains GmbH (http://www.embedded-brains.de)
 .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated.  If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://www.rtems.org/bugs.html
+.. For information on updating and regenerating please refer to the How-To
+.. section in the Software Requirements Engineering chapter of the
+.. RTEMS Software Engineering manual.  The manual is provided as a part of
+.. a release.  For development sources please refer to the online
+.. documentation at:
+.. https://docs.rtems.org
+.. _SemaphoreManagerDirectives:
 Directives
-This section details the semaphore manager's directives.  A subsection is
-dedicated to each of this manager's directives and describes the calling
-sequence, related constants, usage, and status codes.
+This section details the directives of the Semaphore Manager. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/sem/if/create
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_create()
 .. index:: create a semaphore
-.. index:: rtems_semaphore_create
-.. _rtems_semaphore_create:
-SEMAPHORE_CREATE - Create a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_create(
-            rtems_name           name,
-            uint32_t             count,
-            rtems_attribute      attribute_set,
-            rtems_task_priority  priority_ceiling,
-            rtems_id            *id
-DIRECTIVE STATUS CODES:
-    .. list-table::
-     :class: rtems-table
-     * - ``RTEMS_SUCCESSFUL``
-       - semaphore created successfully
-     * - ``RTEMS_INVALID_NAME``
-       - invalid semaphore name
-     * - ``RTEMS_INVALID_ADDRESS``
-       - ``id`` is NULL
-     * - ``RTEMS_TOO_MANY``
-       - too many semaphores created
-     * - ``RTEMS_NOT_DEFINED``
-       - invalid attribute set
-     * - ``RTEMS_INVALID_NUMBER``
-       - invalid starting count for binary semaphore
-       - too many global objects
-DESCRIPTION:
-    This directive creates a semaphore which resides on the local node. The
-    created semaphore has the user-defined name specified in name and the
-    initial count specified in count.  For control and maintenance of the
-    semaphore, RTEMS allocates and initializes a SMCB.  The RTEMS-assigned
-    semaphore id is returned in id.  This semaphore id is used with other
-    semaphore related directives to access the semaphore.
-    Specifying PRIORITY in attribute_set causes tasks waiting for a semaphore
-    to be serviced according to task priority.  When FIFO is selected, tasks
-    are serviced in First In-First Out order.
-NOTES:
-    This directive may cause the calling task to be preempted due to an
-    obtain and release of the object allocator mutex.
-    The priority inheritance and priority ceiling algorithms are only supported
-    for local, binary semaphores that use the priority task wait queue blocking
-    discipline.
-    The following semaphore attribute constants are defined by RTEMS:
-    .. list-table::
-     * - ``RTEMS_FIFO``
-       - tasks wait by FIFO (default)
-     * - ``RTEMS_PRIORITY``
-       - tasks wait by priority
-     * - ``RTEMS_BINARY_SEMAPHORE``
-       - restrict values to 0 and 1
-     * - ``RTEMS_COUNTING_SEMAPHORE``
-       - no restriction on values (default)
-     * - ``RTEMS_SIMPLE_BINARY_SEMAPHORE``
-       - restrict values to 0 and 1, block on nested access, allow deletion of locked semaphore.
-     * - ``RTEMS_NO_INHERIT_PRIORITY``
-       - do not use priority inheritance (default)
-     * - ``RTEMS_INHERIT_PRIORITY``
-       - use priority inheritance
-     * - ``RTEMS_NO_PRIORITY_CEILING``
-       - do not use priority ceiling (default)
-     * - ``RTEMS_PRIORITY_CEILING``
-       - use priority ceiling
-     * - ``RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING``
-       - do not use Multiprocessor Resource Sharing Protocol (default)
-     * - ``RTEMS_MULTIPROCESSOR_RESOURCE_SHARING``
-       - use Multiprocessor Resource Sharing Protocol
-     * - ``RTEMS_LOCAL``
-       - local semaphore (default)
-     * - ``RTEMS_GLOBAL``
-       - global semaphore
-    Semaphores should not be made global unless remote tasks must interact with
-    the created semaphore.  This is to avoid the system overhead incurred by
-    the creation of a global semaphore.  When a global semaphore is created,
-    the semaphore's name and id must be transmitted to every node in the system
-    for insertion in the local copy of the global object table.
-    *Note*, some combinations of attributes are not valid.  See the earlier
-    discussion on this.
-    The total number of global objects, including semaphores, is limited by the
-    maximum_global_objects field in the Configuration Table.
-    It is not allowed to create an initially locked MrsP semaphore and the
-    ``RTEMS_INVALID_NUMBER`` status code will be returned in SMP configurations
-    in this case.  This prevents lock order reversal problems with the
-    allocator mutex.
+.. _InterfaceRtemsSemaphoreCreate:
+rtems_semaphore_create()
+Creates a semaphore.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+    rtems_status_code rtems_semaphore_create(
+      rtems_name          name,
+      uint32_t            count,
+      rtems_attribute     attribute_set,
+      rtems_task_priority priority_ceiling,
+      rtems_id           *id
+.. rubric:: PARAMETERS:
+``name``
+    This parameter is the object name of the semaphore.
+``count``
+    This parameter is the initial count of the semaphore.  If the semaphore is
+    a binary semaphore, then a count of 0 will make the calling task the owner
+    of the binary semaphore and a count of 1 will create a binary semaphore
+    without an owner.
+``attribute_set``
+    This parameter is the attribute set of the semaphore.
+``priority_ceiling``
+    This parameter is the priority ceiling if the semaphore is a binary
+    semaphore with the priority ceiling or MrsP locking protocol as defined by
+    the attribute set.
+``id``
+    This parameter is the pointer to an object identifier variable.  When the
+    directive call is successful, the identifier of the created semaphore will
+    be stored in this variable.
+.. rubric:: DESCRIPTION:
+This directive creates a semaphore which resides on the local node.  The
+semaphore has the user-defined object name specified in ``name`` and the
+initial count specified in ``count``.  The assigned object identifier is
+returned in ``id``.  This identifier is used to access the semaphore with other
+semaphore related directives.
+The **attribute set** specified in ``attribute_set`` is built through a
+*bitwise or* of the attribute constants described below.  Not all combinations
+of attributes are allowed.  Some attributes are mutually exclusive.  If
+mutually exclusive attributes are combined, the behaviour is undefined.
+Attributes not mentioned below are not evaluated by this directive and have no
+effect.  Default attributes can be selected by using the
+:c:macro:`RTEMS_DEFAULT_ATTRIBUTES` constant.  The attribute set defines
+* the scope of the semaphore: :c:macro:`RTEMS_LOCAL` (default) or
+  :c:macro:`RTEMS_GLOBAL`,
+* the task wait queue discipline used by the semaphore: :c:macro:`RTEMS_FIFO`
+  (default) or :c:macro:`RTEMS_PRIORITY`,
+* the class of the semaphore: :c:macro:`RTEMS_COUNTING_SEMAPHORE` (default),
+  :c:macro:`RTEMS_BINARY_SEMAPHORE`, or
+  :c:macro:`RTEMS_SIMPLE_BINARY_SEMAPHORE`, and
+* the locking protocol of a binary semaphore: no locking protocol (default),
+  :c:macro:`RTEMS_INHERIT_PRIORITY`, :c:macro:`RTEMS_PRIORITY_CEILING`, or
+  :c:macro:`RTEMS_MULTIPROCESSOR_RESOURCE_SHARING`.
+The semaphore has a local or global **scope** in a multiprocessing network
+(this attribute does not refer to SMP systems).  The scope is selected by the
+mutually exclusive :c:macro:`RTEMS_LOCAL` and :c:macro:`RTEMS_GLOBAL`
+attributes.
+* A **local scope** is the default and can be emphasized through the use of the
+  :c:macro:`RTEMS_LOCAL` attribute.  A local semaphore can be only used by the
+  node which created it.
+* A **global scope** is established if the :c:macro:`RTEMS_GLOBAL` attribute is
+  set.  Setting the global attribute in a single node system has no effect.
+The **task wait queue discipline** is selected by the mutually exclusive
+:c:macro:`RTEMS_FIFO` and :c:macro:`RTEMS_PRIORITY` attributes.
+* The **FIFO discipline** is the default and can be emphasized through use of
+  the :c:macro:`RTEMS_FIFO` attribute.
+* The **priority discipline** is selected by the :c:macro:`RTEMS_PRIORITY`
+  attribute.  The locking protocols require the priority discipline.
+The **semaphore class** is selected by the mutually exclusive
+:c:macro:`RTEMS_COUNTING_SEMAPHORE`, :c:macro:`RTEMS_BINARY_SEMAPHORE`, and
+:c:macro:`RTEMS_SIMPLE_BINARY_SEMAPHORE` attributes.
+* The **counting semaphore class** is the default and can be emphasized through
+  use of the :c:macro:`RTEMS_COUNTING_SEMAPHORE` attribute.
+* The **binary semaphore class** is selected by the
+  :c:macro:`RTEMS_BINARY_SEMAPHORE` attribute.  Binary semaphores are mutual
+  exclusion (mutex) synchronization primitives which may have an owner.  The
+  count of a binary semaphore is restricted to 0 and 1 values.
+* The **simple binary semaphore class** is selected by the
+  :c:macro:`RTEMS_SIMPLE_BINARY_SEMAPHORE` attribute.  Simple binary semaphores
+  have no owner.  They may be used for task and interrupt synchronization.  The
+  count of a simple binary semaphore is restricted to 0 and 1 values.
+Binary semaphores may use a **locking protocol**.  If a locking protocol is
+selected, then the scope shall be local and the priority task wait queue
+discipline shall be selected.  The locking protocol is selected by the mutually
+exclusive :c:macro:`RTEMS_INHERIT_PRIORITY`, :c:macro:`RTEMS_PRIORITY_CEILING`,
+and :c:macro:`RTEMS_MULTIPROCESSOR_RESOURCE_SHARING` attributes.
+* The default is **no locking protocol**.  This can be emphasized through use
+  of the :c:macro:`RTEMS_NO_INHERIT_PRIORITY`,
+  :c:macro:`RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING`, and
+  :c:macro:`RTEMS_NO_PRIORITY_CEILING` attributes.
+* The **priority inheritance locking protocol** is selected by the
+  :c:macro:`RTEMS_INHERIT_PRIORITY` attribute.
+* The **priority ceiling locking protocol** is selected by the
+  :c:macro:`RTEMS_PRIORITY_CEILING` attribute.  For this locking protocol a
+  priority ceiling shall be specified in ``priority_ceiling``.
+* The **MrsP locking protocol** is selected by the
+  :c:macro:`RTEMS_MULTIPROCESSOR_RESOURCE_SHARING` attribute in SMP
+  configurations, otherwise this attribute selects the **priority ceiling
+  locking protocol**.  For these locking protocols a priority ceiling shall be
+  specified in ``priority_ceiling``.  This priority is used to set the priority
+  ceiling for all schedulers.  This can be changed later with the
+  :ref:`InterfaceRtemsSemaphoreSetPriority` directive using the returned object
+  identifier.
+.. rubric:: RETURN VALUES:
+:c:macro:`RTEMS_SUCCESSFUL`
+    The requested operation was successful.
+:c:macro:`RTEMS_INVALID_NAME`
+    The ``name`` parameter was invalid.
+:c:macro:`RTEMS_INVALID_ADDRESS`
+    The ``id`` parameter was `NULL
+    <https://en.cppreference.com/w/c/types/NULL>`_.
+:c:macro:`RTEMS_INVALID_NUMBER`
+    The ``count`` parameter was invalid.
+:c:macro:`RTEMS_NOT_DEFINED`
+    The ``attribute_set`` parameter was invalid.
+:c:macro:`RTEMS_TOO_MANY`
+    There was no inactive object available to create a semaphore.  The number
+    of semaphores available to the application is configured through the
+    :ref:`CONFIGURE_MAXIMUM_SEMAPHORES` application configuration option.
+    In multiprocessing configurations, there was no inactive global object
+    available to create a global semaphore.  The number of global objects
+    available to the application is configured through the
+    :ref:`CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS` application configuration
+    option.
+:c:macro:`RTEMS_INVALID_PRIORITY`
+    The ``priority_ceiling`` parameter was invalid.
+.. rubric:: NOTES:
+For control and maintenance of the semaphore, RTEMS allocates a :term:`SMCB`
+from the local SMCB free pool and initializes it.
+The SMCB for a global semaphore is allocated on the local node.  Semaphores
+should not be made global unless remote tasks must interact with the semaphore.
+This is to avoid the system overhead incurred by the creation of a global
+semaphore.  When a global semaphore is created, the semaphore's name and
+identifier must be transmitted to every node in the system for insertion in the
+local copy of the global object table.
+.. rubric:: CONSTRAINTS:
+The following constraints apply to this directive:
+* The directive may be called from within device driver initialization context.
+* The directive may be called from within task context.
+* The directive may obtain and release the object allocator mutex.  This may
+  cause the calling task to be preempted.
+* When the directive operates on a global object, the directive sends a message
+  to remote nodes.  This may preempt the calling task.
+* When a semaphore using the MrsP locking protocol is created, the initial
+  count shall be exactly one.
+* The number of semaphores available to the application is configured through
+  the :ref:`CONFIGURE_MAXIMUM_SEMAPHORES` application configuration option.
+* Where the object class corresponding to the directive is configured to use
+  unlimited objects, the directive may allocate memory from the RTEMS
+  Workspace.
+* The number of global objects available to the application is configured
+  through the :ref:`CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS` application
+  configuration option.
+.. Generated from spec:/rtems/sem/if/ident
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_ident()
+.. _InterfaceRtemsSemaphoreIdent:
-.. index:: get ID of a semaphore
-.. index:: obtain ID of a semaphore
-.. index:: rtems_semaphore_ident
+rtems_semaphore_ident()
-.. _rtems_semaphore_ident:
+Identifies a semaphore by the object name.
-SEMAPHORE_IDENT - Get ID of a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
+.. code-block:: c
-        rtems_status_code rtems_semaphore_ident(
-            rtems_name  name,
-            uint32_t    node,
-            rtems_id   *id
+    rtems_status_code rtems_semaphore_ident(
+      rtems_name name,
+      uint32_t   node,
+      rtems_id  *id
-    .. list-table::
-       - semaphore identified successfully
-       - semaphore name not found
-     * - ``RTEMS_INVALID_NODE``
-       - invalid node id
+``name``
+    This parameter is the object name to look up.
-DESCRIPTION:
-    This directive obtains the semaphore id associated with the semaphore name.
-    If the semaphore name is not unique, then the semaphore id will match one
-    of the semaphores with that name.  However, this semaphore id is not
-    guaranteed to correspond to the desired semaphore.  The semaphore id is
-    used by other semaphore related directives to access the semaphore.
+``node``
+    This parameter is the node or node set to search for a matching object.
-NOTES:
-    This directive will not cause the running task to be preempted.
+``id``
+    directive call is successful, the object identifier of an object with the
+    specified name will be stored in this variable.
-    If node is ``RTEMS_SEARCH_ALL_NODES``, all nodes are searched with the
-    local node being searched first.  All other nodes are searched with the
-    lowest numbered node searched first.
-    If node is a valid node number which does not represent the local node,
-    then only the semaphores exported by the designated node are searched.
+This directive obtains a semaphore identifier associated with the semaphore
+name specified in ``name``.
-    This directive does not generate activity on remote nodes.  It accesses
-    only the local copy of the global object table.
+The node to search is specified in ``node``.  It shall be
+* a valid node number,
+* the constant :c:macro:`RTEMS_SEARCH_ALL_NODES` to search in all nodes,
+* the constant :c:macro:`RTEMS_SEARCH_LOCAL_NODE` to search in the local node
+  only, or
+* the constant :c:macro:`RTEMS_SEARCH_OTHER_NODES` to search in all nodes
+  except the local node.
+    The ``name`` parameter was 0.
+    There was no object with the specified name on the specified nodes.
+:c:macro:`RTEMS_INVALID_NODE`
+    In multiprocessing configurations, the specified node was invalid.
+.. rubric:: NOTES:
+If the semaphore name is not unique, then the semaphore identifier will match
+the first semaphore with that name in the search order.  However, this
+semaphore identifier is not guaranteed to correspond to the desired semaphore.
+The objects are searched from lowest to the highest index.  If ``node`` is
+:c:macro:`RTEMS_SEARCH_ALL_NODES`, all nodes are searched with the local node
+being searched first.  All other nodes are searched from lowest to the highest
+node number.
+If node is a valid node number which does not represent the local node, then
+only the semaphores exported by the designated node are searched.
+This directive does not generate activity on remote nodes.  It accesses only
+the local copy of the global object table.
+The semaphore identifier is used with other semaphore related directives to
+access the semaphore.
+* The directive may be called from within any runtime context.
+* The directive will not cause the calling task to be preempted.
+.. Generated from spec:/rtems/sem/if/delete
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_delete()
 .. index:: delete a semaphore
-.. index:: rtems_semaphore_delete
-.. _rtems_semaphore_delete:
+.. _InterfaceRtemsSemaphoreDelete:
+rtems_semaphore_delete()
+Deletes the semaphore.
+.. code-block:: c
+    rtems_status_code rtems_semaphore_delete( rtems_id id );
+``id``
+    This parameter is the semaphore identifier.
+This directive deletes the semaphore specified by ``id``.
-SEMAPHORE_DELETE - Delete a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_delete(
-            rtems_id id
+:c:macro:`RTEMS_INVALID_ID`
+    There was no semaphore associated with the identifier specified by ``id``.
-    .. list-table::
+:c:macro:`RTEMS_ILLEGAL_ON_REMOTE_OBJECT`
+    The semaphore resided on a remote node.
-       - semaphore deleted successfully
-     * - ``RTEMS_INVALID_ID``
-       - invalid semaphore id
-     * - ``RTEMS_RESOURCE_IN_USE``
-       - binary semaphore is in use
-     * - ``RTEMS_ILLEGAL_ON_REMOTE_OBJECT``
-       - cannot delete remote semaphore
+:c:macro:`RTEMS_RESOURCE_IN_USE`
+    The binary semaphore had an owner.
-DESCRIPTION:
-    This directive deletes the semaphore specified by ``id``.  All tasks
-    blocked waiting to acquire the semaphore will be readied and returned a
-    status code which indicates that the semaphore was deleted.  The SMCB for
-    this semaphore is reclaimed by RTEMS.
+.. rubric:: NOTES:
-NOTES:
+Binary semaphores with an owner cannot be deleted.
-    The calling task will be preempted if it is enabled by the task's execution
-    mode and a higher priority local task is waiting on the deleted semaphore.
-    The calling task will NOT be preempted if all of the tasks that are waiting
-    on the semaphore are remote tasks.
+When a semaphore is deleted, all tasks blocked waiting to obtain the semaphore
+will be readied and returned a status code which indicates that the semaphore
+was deleted.
-    The calling task does not have to be the task that created the semaphore.  Any
-    local task that knows the semaphore id can delete the semaphore.
+The :term:`SMCB` for the deleted semaphore is reclaimed by RTEMS.
-    When a global semaphore is deleted, the semaphore id must be transmitted to
-    every node in the system for deletion from the local copy of the global
-    object table.
+When a global semaphore is deleted, the semaphore identifier must be
+transmitted to every node in the system for deletion from the local copy of the
+global object table.
-    The semaphore must reside on the local node, even if the semaphore was
-    created with the ``RTEMS_GLOBAL`` option.
+The semaphore must reside on the local node, even if the semaphore was created
+with the :c:macro:`RTEMS_GLOBAL` attribute.
-    Proxies, used to represent remote tasks, are reclaimed when the semaphore
-    is deleted.
+Proxies, used to represent remote tasks, are reclaimed when the semaphore is
+deleted.
+* The calling task does not have to be the task that created the object.  Any
+  local task that knows the object identifier can delete the object.
+  unlimited objects, the directive may free memory to the RTEMS Workspace.
+.. Generated from spec:/rtems/sem/if/obtain
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_obtain()
 .. index:: obtain a semaphore
 .. index:: lock a semaphore
-.. index:: rtems_semaphore_obtain
-.. _rtems_semaphore_obtain:
-SEMAPHORE_OBTAIN - Acquire a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_obtain(
-            rtems_id        id,
-            rtems_option    option_set,
-            rtems_interval  timeout
-    .. list-table::
-       - semaphore obtained successfully
-     * - ``RTEMS_UNSATISFIED``
-       - semaphore not available
-     * - ``RTEMS_TIMEOUT``
-       - timed out waiting for semaphore
-     * - ``RTEMS_OBJECT_WAS_DELETED``
-       - semaphore deleted while waiting
-DESCRIPTION:
-    This directive acquires the semaphore specified by id.  The ``RTEMS_WAIT``
-    and ``RTEMS_NO_WAIT`` components of the options parameter indicate whether
-    the calling task wants to wait for the semaphore to become available or
-    return immediately if the semaphore is not currently available.  With
-    either ``RTEMS_WAIT`` or ``RTEMS_NO_WAIT``, if the current semaphore count
-    is positive, then it is decremented by one and the semaphore is
-    successfully acquired by returning immediately with a successful return
-    code.
-    If the calling task chooses to return immediately and the current semaphore
-    count is zero or negative, then a status code is returned indicating that
-    the semaphore is not available. If the calling task chooses to wait for a
-    semaphore and the current semaphore count is zero or negative, then it is
-    decremented by one and the calling task is placed on the semaphore's wait
-    queue and blocked.  If the semaphore was created with the
-    ``RTEMS_PRIORITY`` attribute, then the calling task is inserted into the
-    queue according to its priority.  However, if the semaphore was created
-    with the ``RTEMS_FIFO`` attribute, then the calling task is placed at the
-    rear of the wait queue.  If the binary semaphore was created with the
-    ``RTEMS_INHERIT_PRIORITY`` attribute, then the priority of the task
-    currently holding the binary semaphore is guaranteed to be greater than or
-    equal to that of the blocking task.  If the binary semaphore was created
-    with the ``RTEMS_PRIORITY_CEILING`` attribute, a task successfully obtains
-    the semaphore, and the priority of that task is greater than the ceiling
-    priority for this semaphore, then the priority of the task obtaining the
-    semaphore is elevated to that of the ceiling.
-    The timeout parameter specifies the maximum interval the calling task is
-    willing to be blocked waiting for the semaphore.  If it is set to
-    ``RTEMS_NO_TIMEOUT``, then the calling task will wait forever.  If the
-    semaphore is available or the ``RTEMS_NO_WAIT`` option component is set,
-    then timeout is ignored.
-    In case a semaphore is not available, then ``RTEMS_UNSATISFIED`` will be
-    returned.  This happens immediately in case ``RTEMS_NO_WAIT`` is specified,
-    or as a result of another task invoking the ``rtems_semaphore_flush``
-    directive in case ``RTEMS_WAIT`` is specified.
-    Deadlock situations are detected for MrsP semaphores and the
-    ``RTEMS_UNSATISFIED`` status code will be returned in SMP configurations in
-    this case.
-NOTES:
-    The following semaphore acquisition option constants are defined by RTEMS:
-    .. list-table::
-     * - ``RTEMS_WAIT``
-       - task will wait for semaphore (default)
-     * - ``RTEMS_NO_WAIT``
-       - task should not wait
-    Attempting to obtain a global semaphore which does not reside on the local
-    node will generate a request to the remote node to access the semaphore.
-    If the semaphore is not available and ``RTEMS_NO_WAIT`` was not specified,
-    then the task must be blocked until the semaphore is released.  A proxy is
-    allocated on the remote node to represent the task until the semaphore is
-    released.
-    A clock tick is required to support the timeout functionality of this
-    directive.
-    It is not allowed to obtain a MrsP semaphore more than once by one task at
-    a time (nested access) and the ``RTEMS_UNSATISFIED`` status code will be
-    returned in SMP configurations in this case.
+.. _InterfaceRtemsSemaphoreObtain:
+rtems_semaphore_obtain()
+Obtains the semaphore.
+.. code-block:: c
+    rtems_status_code rtems_semaphore_obtain(
+      rtems_id       id,
+      rtems_option   option_set,
+      rtems_interval timeout
+``id``
+``option_set``
+    This parameter is the option set.
+``timeout``
+    This parameter is the timeout in clock ticks if the :c:macro:`RTEMS_WAIT`
+    option is set.  Use :c:macro:`RTEMS_NO_TIMEOUT` to wait potentially
+    forever.
+This directive obtains the semaphore specified by ``id``.
+The **option set** specified in ``option_set`` is built through a *bitwise or*
+of the option constants described below.  Not all combinations of options are
+allowed.  Some options are mutually exclusive.  If mutually exclusive options
+are combined, the behaviour is undefined.  Options not mentioned below are not
+evaluated by this directive and have no effect. Default options can be selected
+by using the :c:macro:`RTEMS_DEFAULT_OPTIONS` constant.
+The calling task can **wait** or **try to obtain** the semaphore according to
+the mutually exclusive :c:macro:`RTEMS_WAIT` and :c:macro:`RTEMS_NO_WAIT`
+options.
+* **Waiting to obtain** the semaphore is the default and can be emphasized
+  through the use of the :c:macro:`RTEMS_WAIT` option.  The ``timeout``
+  parameter defines how long the calling task is willing to wait.  Use
+  :c:macro:`RTEMS_NO_TIMEOUT` to wait potentially forever, otherwise set a
+  timeout interval in clock ticks.
+* **Trying to obtain** the semaphore is selected by the
+  :c:macro:`RTEMS_NO_WAIT` option.  If this option is defined, then the
+  ``timeout`` parameter is ignored.  When the semaphore cannot be immediately
+  obtained, then the :c:macro:`RTEMS_UNSATISFIED` status is returned.
+With either :c:macro:`RTEMS_WAIT` or :c:macro:`RTEMS_NO_WAIT` if the current
+semaphore count is positive, then it is decremented by one and the semaphore is
+successfully obtained by returning immediately with the
+:c:macro:`RTEMS_SUCCESSFUL` status code.
+If the calling task chooses to return immediately and the current semaphore
+count is zero, then the :c:macro:`RTEMS_UNSATISFIED` status code is returned
+indicating that the semaphore is not available.
+If the calling task chooses to wait for a semaphore and the current semaphore
+count is zero, then the calling task is placed on the semaphore's wait queue
+and blocked.  If a local, binary semaphore was created with the
+:c:macro:`RTEMS_INHERIT_PRIORITY` attribute, then the priority of the task
+currently holding the binary semaphore will inherit the current priority set of
+the blocking task.  The priority inheritance is carried out recursively.  This
+means, that if the task currently holding the binary semaphore is blocked on
+another local, binary semaphore using the priority inheritance locking
+protocol, then the owner of this semaphore will inherit the current priority
+sets of both tasks, and so on.  A task has a current priority for each
+scheduler.
+:c:macro:`RTEMS_UNSATISFIED`
+    The semaphore could not be obtained immediately.
+:c:macro:`RTEMS_INCORRECT_STATE`
+    Acquiring of the local, binary semaphore by the calling task would have
+    cased a deadlock.
+    The calling task attempted to recursively obtain a local, binary semaphore
+    using the MrsP locking protocol.
+    The semaphore was flushed while the calling task was waiting to obtain the
+    semaphore.
+:c:macro:`RTEMS_TIMEOUT`
+    The timeout happened while the calling task was waiting to obtain the
+    semaphore.
+:c:macro:`RTEMS_OBJECT_WAS_DELETED`
+    The semaphore was deleted while the calling task was waiting to obtain the
+    semaphore.
+.. rubric:: NOTES:
+If a local, binary semaphore was created with the
+:c:macro:`RTEMS_PRIORITY_CEILING` or
+:c:macro:`RTEMS_MULTIPROCESSOR_RESOURCE_SHARING` attribute, a task successfully
+obtains the semaphore, and the priority of that task is greater than the
+ceiling priority for this semaphore, then the priority of the task acquiring
+the semaphore is elevated to that of the ceiling.
+Deadlock situations are detected for local, binary semaphores.  If a deadlock
+is detected, then the directive immediately returns the
+:c:macro:`RTEMS_INCORRECT_STATE` status code.
+It is not allowed to recursively obtain (nested access) a local, binary
+semaphore using the MrsP locking protocol and any attempt to do this will just
+return the :c:macro:`RTEMS_INCORRECT_STATE` status code.  This error can only
+happen in SMP configurations.
+If the semaphore was created with the :c:macro:`RTEMS_PRIORITY` attribute, then
+the calling task is inserted into the wait queue according to its priority.
+However, if the semaphore was created with the :c:macro:`RTEMS_FIFO` attribute,
+then the calling task is placed at the rear of the wait queue.
+Attempting to obtain a global semaphore which does not reside on the local node
+will generate a request to the remote node to access the semaphore.  If the
+semaphore is not available and :c:macro:`RTEMS_NO_WAIT` was not specified, then
+the task must be blocked until the semaphore is released.  A proxy is allocated
+on the remote node to represent the task until the semaphore is released.
+* When a local, counting semaphore or a local, simple binary semaphore is
+  accessed and the :c:macro:`RTEMS_NO_WAIT` option is set, the directive may be
+  called from within interrupt context.
+* When a local semaphore is accessed and the request can be immediately
+  satisfied, the directive may be called from within device driver
+  initialization context.
+* When the request cannot be immediately satisfied and the
+  :c:macro:`RTEMS_WAIT` option is set, the calling task blocks at some point
+  during the directive call.
+* The timeout functionality of the directive requires a :term:`clock tick`.
+* When the directive operates on a remote object, the directive sends a message
+  to the remote node and waits for a reply.  This will preempt the calling
+  task.
+.. Generated from spec:/rtems/sem/if/release
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_release()
 .. index:: release a semaphore
 .. index:: unlock a semaphore
-.. index:: rtems_semaphore_release
-.. _rtems_semaphore_release:
-SEMAPHORE_RELEASE - Release a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_release(
-            rtems_id id
-    .. list-table::
-       - semaphore released successfully
-     * - ``RTEMS_NOT_OWNER_OF_RESOURCE``
-       - calling task does not own semaphore
-     * - ``RTEMS_INCORRECT_STATE``
-       - invalid unlock order
-DESCRIPTION:
-    This directive releases the semaphore specified by id.  The semaphore count
-    is incremented by one.  If the count is zero or negative, then the first
-    task on this semaphore's wait queue is removed and unblocked.  The
-    unblocked task may preempt the running task if the running task's
-    preemption mode is enabled and the unblocked task has a higher priority
-    than the running task.
-NOTES:
-    The calling task may be preempted if it causes a higher priority task to be
-    made ready for execution.
-    Releasing a global semaphore which does not reside on the local node will
-    generate a request telling the remote node to release the semaphore.
-    If the task to be unblocked resides on a different node from the semaphore,
-    then the semaphore allocation is forwarded to the appropriate node, the
-    waiting task is unblocked, and the proxy used to represent the task is
-    reclaimed.
-    The outermost release of a local, binary, priority inheritance or priority
-    ceiling semaphore may result in the calling task having its priority
-    lowered.  This will occur if the calling task holds no other binary
-    semaphores and it has inherited a higher priority.
-    The MrsP semaphores must be released in the reversed obtain order,
-    otherwise the ``RTEMS_INCORRECT_STATE`` status code will be returned in SMP
-    configurations in this case.
+.. _InterfaceRtemsSemaphoreRelease:
+rtems_semaphore_release()
+Releases the semaphore.
+.. code-block:: c
+    rtems_status_code rtems_semaphore_release( rtems_id id );
+``id``
+This directive releases the semaphore specified by ``id``.  If the semaphore's
+wait queue is not empty, then
+* the first task on the wait queue is removed and unblocked, the semaphore's
+  count is not changed, otherwise
+* the semaphore's count is incremented by one for counting semaphores and set
+  to one for binary and simple binary semaphores.
+:c:macro:`RTEMS_NOT_OWNER_OF_RESOURCE`
+    The calling task was not the owner of the semaphore.
+:c:macro:`RTEMS_INTERNAL_ERROR`
+    The semaphore's count already had the maximum value of `UINT32_MAX
+    <https://en.cppreference.com/w/c/types/integer>`_.
+.. rubric:: NOTES:
+The calling task may be preempted if it causes a higher priority task to be
+made ready for execution.
+The outermost release of a local, binary semaphore using the priority
+inheritance, priority ceiling, or MrsP locking protocol may result in the
+calling task having its priority lowered.  This will occur if the highest
+priority of the calling task was available due to the ownership of the released
+semaphore.  If a task was on the semaphore's wait queue, then the priority
+associated with the semaphore will be transferred to the new owner.
+Releasing a global semaphore which does not reside on the local node will
+generate a request telling the remote node to release the semaphore.
+If the task to be unblocked resides on a different node from the semaphore,
+then the semaphore allocation is forwarded to the appropriate node, the waiting
+task is unblocked, and the proxy used to represent the task is reclaimed.
+  accessed, the directive may be called from within interrupt context.
+* When a local semaphore is accessed, the directive may be called from within
+  device driver initialization context.
+* The directive may unblock another task which may preempt the calling task.
+  task.
+.. Generated from spec:/rtems/sem/if/flush
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_flush()
 .. index:: flush a semaphore
 .. index:: unblock all tasks waiting on a semaphore
-.. index:: rtems_semaphore_flush
-.. _rtems_semaphore_flush:
+.. _InterfaceRtemsSemaphoreFlush:
+rtems_semaphore_flush()
+Flushes the semaphore.
+.. code-block:: c
+    rtems_status_code rtems_semaphore_flush( rtems_id id );
+``id``
+This directive unblocks all tasks waiting on the semaphore specified by ``id``.
+The semaphore's count is not changed by this directive.  Tasks which are
+unblocked as the result of this directive will return from the
+:ref:`InterfaceRtemsSemaphoreObtain` directive with a status code of
+:c:macro:`RTEMS_UNSATISFIED` to indicate that the semaphore was not obtained.
-SEMAPHORE_FLUSH - Unblock all tasks waiting on a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_flush(
-            rtems_id id
-    .. list-table::
-       - operation not defined for the protocol of the semaphore
-       - not supported for remote semaphores
+    Flushing a semaphore using the MrsP locking protocol is undefined
+    behaviour.
-DESCRIPTION:
-    This directive unblocks all tasks waiting on the semaphore specified by id.
-    Since there are tasks blocked on the semaphore, the semaphore's count is
-    not changed by this directive and thus is zero before and after this
-    directive is executed.  Tasks which are unblocked as the result of this
-    directive will return from the ``rtems_semaphore_obtain`` directive with a
-    status code of ``RTEMS_UNSATISFIED`` to indicate that the semaphore was not
-    obtained.
+.. rubric:: NOTES:
-    This directive may unblock any number of tasks.  Any of the unblocked tasks
-    may preempt the running task if the running task's preemption mode is
-    enabled and an unblocked task has a higher priority than the running task.
+then the waiting task is unblocked, and the proxy used to represent the task is
+reclaimed.
-NOTES:
+It is not allowed to flush a local, binary semaphore using the MrsP locking
+protocol and any attempt to do this will just return the
+:c:macro:`RTEMS_NOT_DEFINED` status code.  This error can only happen in SMP
+configurations.
-    then the waiting task is unblocked, and the proxy used to represent the
-    task is reclaimed.
+For barrier synchronization, the :ref:`RTEMSAPIClassicBarrier` offers a cleaner
+alternative to using the semaphore flush directive.  Unlike POSIX barriers,
+they have a manual release option.
-    It is not allowed to flush a MrsP semaphore and the ``RTEMS_NOT_DEFINED``
-    status code will be returned in SMP configurations in this case.
+Using the semaphore flush directive for condition synchronization in concert
+with another semaphore may be subject to the lost wake-up problem.  The
+following attempt to implement a condition variable is broken.
-    Using the ``rtems_semaphore_flush`` directive for condition synchronization
-    in concert with another semaphore may be subject to the lost wake-up
-    problem.  The following attempt to implement a condition variable is
-    broken.
+.. code-block:: c
+    :linenos:
-    .. code-block:: c
+    #include <rtems.h>
+    #include <assert.h>
-        #include <rtems.h>
-        #include <assert.h>
+    void cnd_wait( rtems_id cnd, rtems_id mtx )
+      rtems_status_code sc;
-        void cnd_wait( rtems_id cnd, rtems_id mtx )
-          rtems_status_code sc;
+      sc = rtems_semaphore_release( mtx );
+      assert( sc == RTEMS_SUCCESSFUL );
-          sc = rtems_semaphore_release( mtx );
-          assert( sc == RTEMS_SUCCESSFUL );
+      // Here, a higher priority task may run and satisfy the condition.
+      // We may never wake up from the next semaphore obtain.
-           * Here, a higher priority task may run and satisfy the condition. We
-           * may never wake up from the next semaphore obtain.
+      sc = rtems_semaphore_obtain( cnd, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+      assert( sc == RTEMS_UNSATISFIED );
-          sc = rtems_semaphore_obtain( cnd, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
-          assert( sc == RTEMS_UNSATISFIED );
+      sc = rtems_semaphore_obtain( mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
-          sc = rtems_semaphore_obtain( mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT );
+    void cnd_broadcast( rtems_id cnd )
-        void cnd_broadcast( rtems_id cnd )
+      sc = rtems_semaphore_flush( cnd );
-          sc = rtems_semaphore_flush( cnd );
-    For barrier synchronization, the :ref:`barrier_manager` offers a cleaner
-    alternative to using the `rtems_semaphore_flush` directive.  Unlike POSIX
-    barriers, they have a manual release option.
+  task.
+.. Generated from spec:/rtems/sem/if/set-priority
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_semaphore_set_priority()
 .. index:: set priority by scheduler for a semaphore
-.. index:: rtems_semaphore_set_priority
-.. _rtems_semaphore_set_priority:
-SEMAPHORE_SET_PRIORITY - Set priority by scheduler for a semaphore
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_semaphore_set_priority(
-            rtems_id             semaphore_id,
-            rtems_id             scheduler_id,
-            rtems_task_priority  new_priority,
-            rtems_task_priority *old_priority
-    .. list-table::
-       - successful operation
-       - invalid semaphore or scheduler id
-       - ``old_priority`` is NULL
-     * - ``RTEMS_INVALID_PRIORITY``
-       - invalid new priority value
-       - operation not defined for the protocol ofthe semaphore
-DESCRIPTION:
-    This directive sets the priority value with respect to the specified
-    scheduler of a semaphore.
-    The special priority value ``RTEMS_CURRENT_PRIORITY`` can be used to get
-    the current priority value without changing it.
-    The interpretation of the priority value depends on the protocol of the
-    semaphore object.
-    - The Multiprocessor Resource Sharing Protocol needs a ceiling priority per
-      scheduler instance.  This operation can be used to specify these priority
-      values.
-    - For the Priority Ceiling Protocol the ceiling priority is used with this
-      operation.
-    - For other protocols this operation is not defined.
-EXAMPLE:
-    .. code-block:: c
-        :linenos:
-        #include <stdlib.h>
-        #define SCHED_A rtems_build_name(' ', ' ', ' ', 'A')
-        #define SCHED_B rtems_build_name(' ', ' ', ' ', 'B')
-        static void Init(rtems_task_argument arg)
-            rtems_id            semaphore_id;
-            rtems_id            scheduler_a_id;
-            rtems_id            scheduler_b_id;
-            rtems_task_priority prio;
-            /* Get the scheduler identifiers */
-            sc = rtems_scheduler_ident(SCHED_A, &scheduler_a_id);
-            assert(sc == RTEMS_SUCCESSFUL);
-            sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
-            /* Create a MrsP semaphore object */
-            sc = rtems_semaphore_create(
-                rtems_build_name('M', 'R', 'S', 'P'),
-                1,
-                RTEMS_MULTIPROCESSOR_RESOURCE_SHARING | RTEMS_BINARY_SEMAPHORE,
-                1,
-                &semaphore_id
-             * The ceiling priority values per scheduler are equal to the value specified
-             * for object creation.
-            prio = RTEMS_CURRENT_PRIORITY;
-            sc = rtems_semaphore_set_priority(semaphore_id, scheduler_a_id, prio, &prio);
-            assert(prio == 1);
-            /* Check the old value and set a new ceiling priority for scheduler B */
-            prio = 2;
-            sc = rtems_semaphore_set_priority(semaphore_id, scheduler_b_id, prio, &prio);
-            /* Check the ceiling priority values */
-            assert(prio == 2);
-            sc = rtems_semaphore_delete(semaphore_id);
-            exit(0);
-        #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-        #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-        #define CONFIGURE_MAXIMUM_TASKS 1
-        #define CONFIGURE_MAXIMUM_SEMAPHORES 1
-        #define CONFIGURE_MAXIMUM_PROCESSORS 2
-        #define CONFIGURE_SCHEDULER_SIMPLE_SMP
-        #include <rtems/scheduler.h>
-        RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(a);
-        RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(b);
-        #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
-            RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(a, SCHED_A), \
-            RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(b, SCHED_B)
-        #define CONFIGURE_SCHEDULER_ASSIGNMENTS \
-            RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
-            RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY)
-        #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-        #define CONFIGURE_INIT
-        #include <rtems/confdefs.h>
+.. _InterfaceRtemsSemaphoreSetPriority:
+rtems_semaphore_set_priority()
+Sets the priority by scheduler for the semaphore.
+.. code-block:: c
+    rtems_status_code rtems_semaphore_set_priority(
+      rtems_id             semaphore_id,
+      rtems_id             scheduler_id,
+      rtems_task_priority  new_priority,
+      rtems_task_priority *old_priority
+``semaphore_id``
+``scheduler_id``
+    This parameter is the identifier of the scheduler corresponding to the new
+    priority.
+``new_priority``
+    This parameter is the new priority corresponding to the specified
+    scheduler.
+``old_priority``
+    This parameter is the pointer to a task priority variable.  When the
+    directive call is successful, the old priority of the semaphore
+    corresponding to the specified scheduler will be stored in this variable.
+This directive sets the priority of the semaphore specified by
+``semaphore_id``.  The priority corresponds to the scheduler specified by
+``scheduler_id``.
+The special priority value :c:macro:`RTEMS_CURRENT_PRIORITY` can be used to get
+the current priority without changing it.
+The availability and use of a priority depends on the class and locking
+protocol of the semaphore:
+* For local, binary semaphores using the MrsP locking protocol, the ceiling
+  priority for each scheduler can be set by this directive.
+* For local, binary semaphores using the priority ceiling protocol, the ceiling
+  priority can be set by this directive.
+* For other semaphore classes and locking protocols, setting a priority is
+  undefined behaviour.
+    The ``old_priority`` parameter was `NULL
+    There was no scheduler associated with the identifier specified by
+    ``scheduler_id``.
+    ``semaphore_id``.
+    The ``new_priority`` parameter was invalid.
+    Setting a priority for the class or locking protocol of the semaphore is
+.. rubric:: NOTES:
+Please have a look at the following example:
+.. code-block:: c
+    :linenos:
+    #define SCHED_A rtems_build_name( ' ', ' ', ' ', 'A' )
+    #define SCHED_B rtems_build_name( ' ', ' ', ' ', 'B' )
+    static void Init( rtems_task_argument arg )
+      rtems_id            semaphore_id;
+      rtems_id            scheduler_a_id;
+      rtems_id            scheduler_b_id;
+      rtems_task_priority prio;
+      (void) arg;
+      // Get the scheduler identifiers
+      sc = rtems_scheduler_ident( SCHED_A, &scheduler_a_id );
+      sc = rtems_scheduler_ident( SCHED_B, &scheduler_b_id );
+      // Create a local, binary semaphore using the MrsP locking protocol
+      sc = rtems_semaphore_create(
+        rtems_build_name( 'M', 'R', 'S', 'P' ),
+        1,
+        RTEMS_BINARY_SEMAPHORE | RTEMS_MULTIPROCESSOR_RESOURCE_SHARING,
+        1,
+        &semaphore_id
+      // The ceiling priority for each scheduler is equal to the priority
+      // specified for the semaphore creation.
+      prio = RTEMS_CURRENT_PRIORITY;
+      sc = rtems_semaphore_set_priority( semaphore_id, scheduler_a_id, prio, &prio );
+      assert( prio == 1 );
+      // Check the old value and set a new ceiling priority for scheduler B
+      prio = 2;
+      sc = rtems_semaphore_set_priority( semaphore_id, scheduler_b_id, prio, &prio );
+      // Check the ceiling priority values
+      assert( prio == 2 );
+      sc = rtems_semaphore_delete( semaphore_id );
+      rtems_shutdown_executive( 0 );
+    #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+    #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+    #define CONFIGURE_MAXIMUM_TASKS 1
+    #define CONFIGURE_MAXIMUM_SEMAPHORES 1
+    #define CONFIGURE_MAXIMUM_PROCESSORS 2
+    #define CONFIGURE_SCHEDULER_SIMPLE_SMP
+    #include <rtems/scheduler.h>
+    RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( a );
+    RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP( b );
+    #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+        RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( a, SCHED_A ), \
+        RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( b, SCHED_B )
+    #define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+        RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
+        RTEMS_SCHEDULER_ASSIGN( 1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY )
+    #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+    #define CONFIGURE_INIT
+    #include <rtems/confdefs.h>
+* The directive may be called from within interrupt context.
+* The directive may change the priority of another task which may preempt the
+  calling task.
diff --git a/c-user/semaphore/introduction.rst b/c-user/semaphore/introduction.rst
index dee298b..9c36834 100644
--- a/c-user/semaphore/introduction.rst
+++ b/c-user/semaphore/introduction.rst
@@ -1,25 +1,55 @@
+.. Generated from spec:/rtems/sem/if/group
+.. _SemaphoreManagerIntroduction:
 Introduction
-The semaphore manager utilizes standard Dijkstra
-counting semaphores to provide synchronization and mutual
-exclusion capabilities.  The directives provided by the
-semaphore manager are:
+.. The following list was generated from:
+.. spec:/rtems/sem/if/create
+.. spec:/rtems/sem/if/ident
+.. spec:/rtems/sem/if/delete
+.. spec:/rtems/sem/if/obtain
+.. spec:/rtems/sem/if/release
+.. spec:/rtems/sem/if/flush
+.. spec:/rtems/sem/if/set-priority
+The Semaphore Manager utilizes standard Dijkstra counting semaphores to provide
+synchronization and mutual exclusion capabilities. The directives provided by
+the Semaphore Manager are:
-- :ref:`rtems_semaphore_create`
+* :ref:`InterfaceRtemsSemaphoreCreate` - Creates a semaphore.
-- :ref:`rtems_semaphore_ident`
+* :ref:`InterfaceRtemsSemaphoreIdent` - Identifies a semaphore by the object
+  name.
-- :ref:`rtems_semaphore_delete`
+* :ref:`InterfaceRtemsSemaphoreDelete` - Deletes the semaphore.
-- :ref:`rtems_semaphore_obtain`
+* :ref:`InterfaceRtemsSemaphoreObtain` - Obtains the semaphore.
-- :ref:`rtems_semaphore_release`
+* :ref:`InterfaceRtemsSemaphoreRelease` - Releases the semaphore.
-- :ref:`rtems_semaphore_flush`
+* :ref:`InterfaceRtemsSemaphoreFlush` - Flushes the semaphore.
-- :ref:`rtems_semaphore_set_priority`
+* :ref:`InterfaceRtemsSemaphoreSetPriority` - Sets the priority by scheduler
+  for the semaphore.
2.26.2
