Should we document a time zone for the RTEMS epoch?
Wed Feb 10 16:30:22 UTC 2021
On 10/02/2021 07:53, Sebastian Huber wrote:
> Hello,
> I try to update the clock manager documentation and noticed that there
> is no time zone specified for the RTEMS epoch. In the timecounter
> initialization we use:
> static struct timehands th0 = {
> #ifdef __rtems__
>     .th_bintime = { .sec = TOD_SECONDS_1970_THROUGH_1988 },
>     .th_microtime = { TOD_SECONDS_1970_THROUGH_1988, 0 },
>     .th_nanotime = { TOD_SECONDS_1970_THROUGH_1988, 0 },
>     .th_boottime = { .sec = TOD_SECONDS_1970_THROUGH_1988 - 1 },
> #endif /* __rtems__ */
> Since Unix epoch is 1970-01-01T00:00:00Z, this basically defines that
> the RTEMS epoch is 1988-01-01T00:00:00Z. Should this be documented?
> The current implementation also implies that the time reported by
> RTEMS is in UTC (modulo leap seconds).
I tried to document the clocks provided by RTEMS, see tail of
(glossary.rst):
https://lists.rtems.org/pipermail/devel/2021-February/064451.html
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
