[PATCH v2 07/12] c-user: Add control block acronyms
Gedare Bloom
gedare at rtems.org
Wed Feb 10 16:48:57 UTC 2021
On Wed, Feb 10, 2021 at 9:28 AM Sebastian Huber <
> Update #3993.
> c-user/glossary.rst | 14 +++++++++++++-
> 1 file changed, 13 insertions(+), 1 deletion(-)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index c3907f5..65e1fd7 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -1,7 +1,7 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> .. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
> -.. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
> +.. Copyright (C) 2017, 2021 embedded brains GmbH (
> .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> Glossary
> @@ -59,6 +59,9 @@ Glossary
> A term used to describe a task that has been unblocked and may be
> scheduled to the CPU.
> + BCB
> + This term is an acronym for Barrier Control Block.
> big endian
> A data representation scheme in which the bytes composing a
> numeric value
> are arranged such that the most significant byte is at the lowest
> @@ -190,6 +193,9 @@ Glossary
> The state entered by a task after it is created and before it has
> been
> started.
> + DPCB
DPMCB?
> + This term is an acronym for Dual-Ported Memory Control Block.
> dual-ported
> A term used to describe memory which can be accessed at two
> different
> addresses.
> @@ -219,6 +225,9 @@ Glossary
> error code
> This term has the same meaning as :term:`status code`.
> + ESCB
> + This term is an acronym for Extension Set Control Block.
> events
> A method for task communication and synchronization. The
> directives
> provided by the event manager are used to service events.
> @@ -492,6 +501,9 @@ Glossary
> A data structure associated with each partition used by RTEMS to
> manage
> that partition.
> + PCB
> + This term is an acronym for Period Control Block.
> pending
> A term used to describe a task blocked waiting for an event,
> message,
> semaphore, or signal.
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/148f29d6/attachment.html>
