Should we document a time zone for the RTEMS epoch?
Joel Sherrill
joel at rtems.org
Wed Feb 10 16:56:09 UTC 2021
On Wed, Feb 10, 2021, 10:53 AM Sebastian Huber <
> On 10/02/2021 17:47, Joel Sherrill wrote:
> > On Wed, Feb 10, 2021, 10:30 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 10/02/2021 07:53, Sebastian Huber wrote:
> > > Hello,
> > > I try to update the clock manager documentation and noticed that
> > there
> > > is no time zone specified for the RTEMS epoch. In the timecounter
> > > initialization we use:
> > > static struct timehands th0 = {
> > > #ifdef __rtems__
> > > .th_bintime = { .sec = TOD_SECONDS_1970_THROUGH_1988 },
> > > .th_microtime = { TOD_SECONDS_1970_THROUGH_1988, 0 },
> > > .th_nanotime = { TOD_SECONDS_1970_THROUGH_1988, 0 },
> > > .th_boottime = { .sec = TOD_SECONDS_1970_THROUGH_1988 - 1 },
> > > #endif /* __rtems__ */
> > > Since Unix epoch is 1970-01-01T00:00:00Z, this basically defines
> > that
> > > the RTEMS epoch is 1988-01-01T00:00:00Z. Should this be documented?
> > > The current implementation also implies that the time reported by
> > > RTEMS is in UTC (modulo leap seconds).
> > I tried to document the clocks provided by RTEMS, see tail of
> > (glossary.rst):
> > https://lists.rtems.org/pipermail/devel/2021-February/064451.html
> > <https://lists.rtems.org/pipermail/devel/2021-February/064451.html>
> > Is it sufficient to reference the epoch entry in various clock get
> > time method pages?
> The relevant epoch and clock is now referenced in the directives.
> > And should there be discussion somewhere about TZ environment variable
> > and the methods in newlib which account for that.
> I think a time zone is simply not accounted for in the RTEMS Classic
> API. With the setting above I guess the time zone is fixed to UTC.
By default clock_gettime is also UTC. You have to go through the C Library
time methods to get timezones
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/f73f569d/attachment.html>
