Revisiting Minimum with Static Allocation
Joel Sherrill
joel at rtems.org
Wed Feb 10 20:55:28 UTC 2021
On Wed, Feb 10, 2021 at 2:36 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Feb 10, 2021 at 10:57 AM Joel Sherrill <joel at rtems.org> wrote:
>> Hi
>> The minimum sample is intended to show how to construct the minimum
>> footprint RTEMS application. I suspect that with Sebastian's recent work on
>> static allocation and reducing footprint, the minimum sample may be able to
>> benefit from tweaking.
>> I just checked rtl22xx_t and it is < 16K code and 272 bytes of data. :)
>> Hello tends to be in the 64K range. Perhaps a static allocation hello
>> variant.
>> Just wanting users to have good examples. A discussion at the Flight
>> Software Workshop mentioned RTEMS was big but it doesn't seem to be if you
>> look at executables which reflect those minimum feature sets.
>> Hoping Sebastian has magic settings to apply so these numbers are as good
>> as possible.
>> This is a good idea. A "useful" minimum configuration with static
> objects, or maybe even a couple of them, could be helpful to identify
> reasonable bottom ends of the spectrum we can conceivably support.
It is important marketing. RTEMS is seen as big and full of functionality
and we don't have any examples to say "hey RTEMS is small too". It's all
just a matter of what functionality you use.
FWIW size is misleading on some of our executables because the BSS
sometimes is sized to end_ram.
--joel
>> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210210/05427f8a/attachment.html>
