Remaining Waf Conversion Tickets for Community and GSoC Students
Chris Johns
chrisj at rtems.org
Wed Feb 10 23:00:14 UTC 2021
On 11/2/21 2:36 am, Sebastian Huber wrote:
> On 10/02/2021 16:19, Joel Sherrill wrote:
>> On Wed, Feb 10, 2021 at 8:40 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> On 10/02/2021 15:27, Joel Sherrill wrote:
>> > On Tue, Feb 9, 2021 at 11:20 PM Sebastian Huber
>> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>> > On 08/02/2021 10:40, Chris Johns wrote:
>> > >> It is written in Python 3.6.
>> > > We still need to support python 2. Maybe having this file
>> > support both could be
>> > > part of the project.
>> > I think this BSP builder is a development tool which can use
>> > Python 3.
>> > It is useful to maintain RTEMS, but it is not a tool
>> required for end
>> > users of RTEMS to develop applications. Independent of this, the
>> > Python
>> > 2 end of life was a year ago.
>> > It is still the default Python on CentOS7 which is an even
>> longer LTS
>> > release
>> > based on the recent CentOS changes. I would consider it a primary
>> > test tool
>> > which should work on all hosts.
>> According to this web site Python 3 is available since CentOS 7.7
>> though
>> the standard repository:
>> |yum update -y ||yum install -y python3 We should make a list of
>> host computer systems
>> we would like to support and then check if Python 3 is available. |||
>> This is different from what I have been doing. I have been using the
>> software collection for python3. The software collections do not change the
>> base environment and you have to explicitly switch to them. I do this when
>> working on the documentation.
>> scl enable rh-python36 bash
>> I installed python3. I now have this for tab-completion for python:
>> $ python
>> python python2.7 python2-config python3.6
>> python-config
>> python2 python2.7-config python3 python3.6m
>> python_count
>> Will the RTEMS Python code pick the Python3 automatically?
This is covered here ....
https://docs.rtems.org/branches/master/user/hosts/python.html
I use virtual environments and I suggest you and others do as well. The virtual
environment you select will control which python you use.
I am against shebang changes to a specific version.
