[PATCH 0/4] Fix for Coverity issues
Ryan Long
thisisryanlong at gmail.com
Thu Feb 11 20:27:38 UTC 2021
Hi,
I created some macros to assert the status returned from function calls,
and use that status based on Gedare and Joel's suggestions. I
implemented the macros in consolesimpletask.c. I fixed some issues for
the 'Dereference before null check' in a couple of files. This mainly
entailed moving around the dereferencing of values.
Thanks,
Ryan
Ryan Long (4):
assert.h: Add macros to assert status and use it
consolesimpletask.c: Fix Coverity Unchecked return value
rtems-debugger-threads.c: Fix Coverity Dereference before null check
rtems-debugger-target.c: Fix Coverity Dereference before null check
cpukit/include/rtems/score/assert.h | 30 +++++++++++++++++++++++++++++
cpukit/libcsupport/src/consolesimpletask.c | 7 +++++--
cpukit/libdebugger/rtems-debugger-target.c | 5 +++--
cpukit/libdebugger/rtems-debugger-threads.c | 14 +++++++++++---
4 files changed, 49 insertions(+), 7 deletions(-)
1.8.3.1
