[PATCH 3/4] rtems-debugger-threads.c: Fix Coverity Dereference before null check
Ryan Long
thisisryanlong at gmail.com
Thu Feb 11 20:27:41 UTC 2021
Fixes CID #1468681, 1468690, and 1468694 by checking if threads is null in
the rtems_debugger_thread_find_index, rtems_debugger_thread_system_resume,
and rtems_debugger_thread_continue_all functions.
cpukit/libdebugger/rtems-debugger-threads.c | 14 +++++++++++---
1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-threads.c b/cpukit/libdebugger/rtems-debugger-threads.c
index 84a9faa..5b96e5f 100644
--- a/cpukit/libdebugger/rtems-debugger-threads.c
+++ b/cpukit/libdebugger/rtems-debugger-threads.c
@@ -148,9 +148,9 @@ int
rtems_debugger_thread_find_index(rtems_id id)
rtems_debugger_threads* threads = rtems_debugger->threads;
- rtems_debugger_thread* current = rtems_debugger_thread_current(threads);
int r = -1;
if (threads != NULL) {
+ rtems_debugger_thread* current = rtems_debugger_thread_current(threads);
size_t i;
for (i = 0; i < threads->current.level; ++i) {
if (id == 0 || current[i].id == id) {
@@ -347,8 +347,11 @@ rtems_debugger_thread_system_resume(bool detaching)
rtems_debugger_thread* current;
int r = 0;
+ if (threads == NULL) {
+ return r;
- if (threads != NULL && current != NULL) {
+ if (current != NULL) {
size_t i;
if (rtems_debugger_verbose())
rtems_debugger_printf("rtems-db: sys: : resuming\n");
@@ -430,8 +433,13 @@ rtems_debugger_thread_continue_all(void)
int r = 0;
+ r = -1;
+ errno = EIO;
+ return r;
size_t i;
rtems_debugger_thread* thread = ¤t[i];
1.8.3.1
