[PATCH 4/4] rtems-debugger-target.c: Fix Coverity Dereference before null check
Ryan Long thisisryanlong at gmail.com
Thu Feb 11 20:27:42 UTC 2021
Fixes CID #1468682 where target is dereferenced before it has been
checked as to whether it is null or not in the
rtems_debugger_target_swbreak_control function.
 cpukit/libdebugger/rtems-debugger-target.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-target.c b/cpukit/libdebugger/rtems-debugger-target.c
index e495170..3726a6c 100644
--- a/cpukit/libdebugger/rtems-debugger-target.c
+++ b/cpukit/libdebugger/rtems-debugger-target.c
@@ -171,17 +171,18 @@ int
 rtems_debugger_target_swbreak_control(bool insert, DB_UINT addr, DB_UINT kind)
   rtems_debugger_target*         target = rtems_debugger->target;
-  rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
   size_t                         swbreak_size;
   uint8_t*                       loc = (void*) addr;
   size_t                         i;
   int                            r;
-  if (target == NULL || swbreaks == NULL || kind != target->breakpoint_size) {
+  if (target == NULL || target->swbreaks.block == NULL ||
+      kind != target->breakpoint_size) {
     errno = EIO;
     return -1;
+  rtems_debugger_target_swbreak* swbreaks = target->swbreaks.block;
   swbreak_size =
     sizeof(rtems_debugger_target_swbreak) + target->breakpoint_size;
1.8.3.1
