[PATCH 3/4 v2] bsp/riscv: work area size based on stack pointer
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Fri Feb 12 09:11:26 UTC 2021
On Fri, 12 Feb 2021 at 10:50, Daniel Hellstrom <daniel at gaisler.com> wrote:
> From: Martin Aberg <maberg at gaisler.com>
> Remember the initial stack pointer in start.S. It can later be used to
> determine top of RAM.
>  bsps/riscv/include/bsp/start.h                     | 65 ++++++++++++++++++++++
>  bsps/riscv/shared/start/bspgetworkarea-fromstack.c | 53 ++++++++++++++++++
>  bsps/riscv/shared/start/start.S                    | 25 +++++++++
>  3 files changed, 143 insertions(+)
>  create mode 100644 bsps/riscv/include/bsp/start.h
>  create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> diff --git a/bsps/riscv/include/bsp/start.h b/bsps/riscv/include/bsp/start.h
> new file mode 100644
> index 0000000..6c9d57d
> --- /dev/null
> +++ b/bsps/riscv/include/bsp/start.h
> @@ -0,0 +1,65 @@
> + * @file
> + * @ingroup RTEMSBSPsRISCVSharedStart
> + * @brief RISC-V start definitions.
> + * Copyright (c) 2021 Cobham Gaisler AB.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> + * SUCH DAMAGE.
> +#ifndef LIBBSP_RISCV_SHARED_START_H
> +#define LIBBSP_RISCV_SHARED_START_H
> + * @defgroup RTEMSBSPsRISCVSharedStart Start Support
> + * @brief Start support.
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * This variable is initialized by the first CPU entering the BSP start code.
> + * The value is the stack pointer at entry.
> +extern uintptr_t riscv_start_stack_pointer;
> +#ifdef __cplusplus
> +#endif
> +#endif /* LIBBSP_RISCV_SHARED_START_H */
> diff --git a/bsps/riscv/shared/start/bspgetworkarea-fromstack.c b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> index 0000000..6885a77
> --- /dev/null
> +++ b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
> @@ -0,0 +1,53 @@
> + *  This set of routines are the BSP specific initialization
> + *  support routines.
> + *  COPYRIGHT (c) 1989-2020.
> + *  On-Line Applications Research Corporation (OAR),
> + *  Cobham Gaisler AB.
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#include <bsp.h>
> +#include <bsp/start.h>
> +#include <bsp/bootcard.h>
> +#include <rtems/sysinit.h>
> + *  These are provided by the linkcmds for ALL of the BSPs which use this file.
> +extern char WorkAreaBase[];
> +extern char RamEnd[];
> +static Memory_Area _Memory_Areas[ 1 ];
> +static void bsp_memory_initialize( void )
> +  char *end;
> +  /* top of RAM inidicated by initial stack pointer */
> +  end = (char *) riscv_start_stack_pointer;
> +  if (end == 0) {
> +    /* fall back to linker symbol if not set */
> +    end = RamEnd;
> +  _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
> +RTEMS_SYSINIT_ITEM(
> +  bsp_memory_initialize,
> +  RTEMS_SYSINIT_MEMORY,
> +  RTEMS_SYSINIT_ORDER_MIDDLE
> +static const Memory_Information _Memory_Information =
> +  MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
> +const Memory_Information *_Memory_Get( void )
> +  return &_Memory_Information;
> diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
> index 04a62a2..6f40279 100644
> --- a/bsps/riscv/shared/start/start.S
> +++ b/bsps/riscv/shared/start/start.S
> @@ -35,6 +35,16 @@
>  #include <bsp/linker-symbols.h>
>  #include <bspopts.h>
> +#if __riscv_xlen == 32
> +#define PTR_ALIGN 2
> +#define PTR_SIZE 4
> +#define PTR_VALUE .word
> +#elif __riscv_xlen == 64
> +#define PTR_ALIGN 3
> +#define PTR_SIZE 8
> +#define PTR_VALUE .dword
> +#endif
Since that's an architecture thing, I wonder if we can just include
cpu.h that already does have macros for pointer sizes and stack
alignments https://github.com/RTEMS/rtems/blob/master/cpukit/score/cpu/riscv/include/rtems/score/cpu.h#L70
Similarly, can we define something like "define ASM_CPU_POINTER
[d]word" in asm.h (the same file where SREG, LADDR, etc are defined).
>  PUBLIC(_start)
>         .section        .bsp_start_text, "wax", @progbits
> @@ -59,6 +69,9 @@ SYM(_start):
>         LADDR   t0, _RISCV_Exception_handler
>         csrw    mtvec, t0
> +       /* Save stack pointer so it can mark end of work area later on */
> +       mv      t3, sp
>         /* Load stack pointer and branch to secondary processor start if necessary */
>  #ifdef RTEMS_SMP
>         LADDR   sp, _ISR_Stack_area_begin
> @@ -74,6 +87,9 @@ SYM(_start):
>         LADDR   sp, _ISR_Stack_area_end
>  #endif
> +       LADDR   t0, riscv_start_stack_pointer
> +       SREG    t3, 0(t0)
>  #ifdef BSP_START_COPY_FDT_FROM_U_BOOT
>         mv      a0, a1
>         call    bsp_fdt_copy
> @@ -145,3 +161,12 @@ SYM(_start):
>  #endif
>  #endif /* RTEMS_SMP */
> +       .section        .data, "aw"
> +       .align  PTR_ALIGN
> +       .globl  riscv_start_stack_pointer
> +       .type   riscv_start_stack_pointer, @object
> +       .size   riscv_start_stack_pointer, PTR_SIZE
> +riscv_start_stack_pointer:
> +       PTR_VALUE       0
> 2.7.4
> devel mailing list
> devel at rtems.org
