[PATCH 0/4] RISC-V: NOEL-V BSP
Daniel Hellstrom daniel at gaisler.com
Fri Feb 12 15:10:07 UTC 2021
Hi,
Thanks all for your comments. The logs have been attached, I'm a bit
unsure why the PSXKEY07 was reported as a failure from the log, we
should probably double check that can get back to you.
/Daniel
On 2021-02-09 16:59, Sebastian Huber wrote:
> On 08/02/2021 20:44, Daniel Hellstrom wrote:
>>    # FAIL: ttest01 OK FAIL 0x0000000000000005 0x0000000000000000
>>    # FAIL: ttest02 OK FAIL 0x0000000000000005 0x0000000000000000
>>    # FAIL: psxkey07 OK FAIL 0x0000000000000005 0x0000000000000000
> These tests should not fail. What are the error messages? It would be
> worth to debug the failures.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210212/afcbb66b/attachment.html>
*** BEGIN OF TEST TTEST 1 ***
*** TEST VERSION: 6.0.0.b26618919e410d368d59e8fb4f9535cf70107de0
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
*** TEST TOOLS: 10.2.1 20210119 (RTEMS 6, RSB 71178999b6221a97a6d1c4d28f1d437a07d31317, Newlib 62e739b)
A:ttest01
S:Platform:RTEMS
S:Compiler:*
S:Version:*
S:BSP:*
S:RTEMS_DEBUG:*
S:RTEMS_MULTIPROCESSING:*
S:RTEMS_POSIX_API:*
S:RTEMS_PROFILING:*
S:RTEMS_SMP:*
B:zalloc_auto
P:0:0:UI1:test-malloc.c:35
P:1:0:UI1:test-malloc.c:36
P:2:0:UI1:test-malloc.c:26
E:zalloc_auto:N:3:F:0:D:0.001000
B:wrong_step
P:0:0:UI1:test-plan.c:6
F:1:0:UI1:test-plan.c:7:planned step (2)
E:wrong_step:N:2:F:1:D:0.001000
B:verbosity_changes
F:3:0:UI1:test-verbosity.c:12:normal: check fails -> with output
P:4:0:UI1:test-verbosity.c:14
F:5:0:UI1:test-verbosity.c:15:verbose: check fails -> with output
E:verbosity_changes:N:6:F:3:D:0.001000
B:timer
P:0:0:UI1:test-rtems.c:26
P:1:0:UI1:test-rtems.c:29
P:2:0:UI1:test-rtems.c:39
P:3:0:ISR:test-rtems.c:14
P:4:0:ISR:test-rtems.c:15
P:5:0:UI1:test-rtems.c:44
P:6:0:UI1:test-rtems.c:45
P:7:0:UI1:test-rtems.c:48
E:timer:N:8:F:0:D:0.001000
B:time_to_string
P:0:0:UI1:test-time.c:11
P:1:0:UI1:test-time.c:12
P:2:0:UI1:test-time.c:13
P:3:0:UI1:test-time.c:14
P:4:0:UI1:test-time.c:17
P:5:0:UI1:test-time.c:18
E:time_to_string:N:6:F:0:D:0.001000
B:time
P:0:0:UI1:test-time.c:55
P:1:0:UI1:test-time.c:56
P:2:0:UI1:test-time.c:57
P:3:0:UI1:test-time.c:58
P:4:0:UI1:test-time.c:61
P:5:0:UI1:test-time.c:63
P:6:0:UI1:test-time.c:64
P:7:0:UI1:test-time.c:67
P:8:0:UI1:test-time.c:69
P:9:0:UI1:test-time.c:70
P:10:0:UI1:test-time.c:73
P:11:0:UI1:test-time.c:75
P:12:0:UI1:test-time.c:76
P:13:0:UI1:test-time.c:79
P:14:0:UI1:test-time.c:81
P:15:0:UI1:test-time.c:82
P:16:0:UI1:test-time.c:85
P:17:0:UI1:test-time.c:87
P:18:0:UI1:test-time.c:88
P:19:0:UI1:test-time.c:91
P:20:0:UI1:test-time.c:93
P:21:0:UI1:test-time.c:94
P:22:0:UI1:test-time.c:97
P:23:0:UI1:test-time.c:99
P:24:0:UI1:test-time.c:100
P:25:0:UI1:test-time.c:103
P:26:0:UI1:test-time.c:105
P:27:0:UI1:test-time.c:106
P:28:0:UI1:test-time.c:109
P:29:0:UI1:test-time.c:111
P:30:0:UI1:test-time.c:112
P:31:0:UI1:test-time.c:115
P:32:0:UI1:test-time.c:117
P:33:0:UI1:test-time.c:118
P:34:0:UI1:test-time.c:121
P:35:0:UI1:test-time.c:123
P:36:0:UI1:test-time.c:124
P:37:0:UI1:test-time.c:127
P:38:0:UI1:test-time.c:129
P:39:0:UI1:test-time.c:130
E:time:N:40:F:0:D:0.001000
B:ticks
P:0:0:UI1:test-time.c:147
P:1:0:UI1:test-time.c:151
P:2:0:UI1:test-time.c:152
FAILED:80:*ctx->c == c
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 6.0.0.b26618919e410d368d59e8fb4f9535cf70107de0
RTEMS tools: 10.2.1 20210119 (RTEMS 6, RSB 71178999b6221a97a6d1c4d28f1d437a07d31317, Newlib 62e739b)
executing thread ID: 0x08a010001
executing thread name: UI1
*** BEGIN OF TEST TTEST 2 ***
A:TTEST 2
S:Platform:RTEMS
S:Compiler:10.2.1 20210119 (RTEMS 6, RSB 71178999b6221a97a6d1c4d28f1d437a07d31317, Newlib 62e739b)
S:Version:6.0.0.b26618919e410d368d59e8fb4f9535cf70107de0
S:BSP:noel64imafd
S:RTEMS_DEBUG:0
S:RTEMS_MULTIPROCESSING:0
S:RTEMS_POSIX_API:1
S:RTEMS_PROFILING:0
S:RTEMS_SMP:0
B:TestThreadSwitch
P:0:0:UI1:init.c:224
P:1:0:UI1:init.c:225
P:2:0:UI1:init.c:226
P:3:0:UI1:init.c:227
P:4:0:UI1:init.c:231
P:5:0:UI1:init.c:232
P:6:0:UI1:init.c:233
P:7:0:UI1:init.c:234
P:8:0:UI1:init.c:238
P:9:0:UI1:init.c:239
P:10:0:UI1:init.c:240
P:11:0:UI1:init.c:241
P:12:0:UI1:init.c:247
P:13:0:UI1:init.c:247
P:14:0:UI1:init.c:247
P:15:0:UI1:init.c:247
P:16:0:UI1:init.c:247
P:17:0:UI1:init.c:247
P:18:0:UI1:init.c:251
P:19:0:UI1:init.c:252
P:20:0:UI1:init.c:253
P:21:0:UI1:init.c:254
P:22:0:UI1:init.c:256
P:23:0:UI1:init.c:257
P:24:0:UI1:init.c:259
P:25:0:UI1:init.c:260
P:26:0:UI1:init.c:269
P:27:0:UI1:init.c:270
P:28:0:UI1:init.c:271
P:29:0:UI1:init.c:272
P:30:0:UI1:init.c:269
P:31:0:UI1:init.c:270
P:32:0:UI1:init.c:271
P:33:0:UI1:init.c:272
P:34:0:UI1:init.c:269
P:35:0:UI1:init.c:270
P:36:0:UI1:init.c:271
P:37:0:UI1:init.c:272
P:38:0:UI1:init.c:269
P:39:0:UI1:init.c:270
P:40:0:UI1:init.c:271
P:41:0:UI1:init.c:272
P:42:0:UI1:init.c:269
P:43:0:UI1:init.c:270
P:44:0:UI1:init.c:271
P:45:0:UI1:init.c:272
P:46:0:UI1:init.c:269
P:47:0:UI1:init.c:270
P:48:0:UI1:init.c:271
P:49:0:UI1:init.c:272
P:50:0:UI1:init.c:269
P:51:0:UI1:init.c:270
P:52:0:UI1:init.c:271
P:53:0:UI1:init.c:272
P:54:0:UI1:init.c:269
P:55:0:UI1:init.c:270
P:56:0:UI1:init.c:271
P:57:0:UI1:init.c:272
P:58:0:UI1:init.c:269
P:59:0:UI1:init.c:270
P:60:0:UI1:init.c:271
P:61:0:UI1:init.c:272
E:TestThreadSwitch:N:62:F:0:D:0.668895
B:TestInterruptTimeout
P:0:0:UI1:init.c:130
E:TestInterruptTimeout:N:1:F:0:D:0.053247
B:TestInterruptFatal
P:0.0:0:UI1:init.c:138
E:TestInterruptFatal:N:1:F:0:D:0.011445
B:TestInterruptDone
F:0:0:UI1:init.c:114:8 == 4
F:1:0:UI1:init.c:114:8 == 4
F:2:0:UI1:init.c:114:8 == 4
F:3:0:UI1:init.c:114:8 == 4
F:4:0:UI1:init.c:114:8 == 4
F:5:0:UI1:init.c:114:8 == 4
F:6:0:UI1:init.c:114:8 == 4
F:7:0:UI1:init.c:114:8 == 4
F:8:0:UI1:init.c:114:8 == 4
F:9:0:UI1:init.c:114:8 == 4
E:TestInterruptDone:N:10:F:10:D:100.161578
B:TestInterruptBlocked
P:0.0:0:IDLE:init.c:190
P:0.1:0:UI1:init.c:166
P:0:0:UI1:init.c:209
E:TestInterruptBlocked:N:3:F:0:D:0.034862
Z:TTEST 2:C:5:N:77:F:10:D:101.081697
Y:ReportHash:SHA256:8727f5f8d17ac526af717674e9da4cdcb9240e506312179e122a2e335ffce566
*** FATAL ***
*** BEGIN OF TEST PSXKEY 7 ***
Init - Mutex 1 create - OK
Init - Mutex 2 create - OK
Init - Condition variable 1 create - OK
Init - Condition variable 2 create - OK
Init - pthread Key create - OK
Init - 10 pthreads have been created - OK
Init - 10 pthreads have been setted key data - OK
Init - sleep - let threads run - OK
Init - 10 pthreads have been got key data - OK
Init - pthread Key delete - OK
Init - Mutex1 delete - OK
Init - Mutex2 delete - OK
Init - Condition variable 1 delete - OK
Init - Condition variable 2 delete - OK
*** END OF TEST PSXKEY 7 ***
*** FATAL ***
