[PATCH] Update motorola_power to irq-generic interrupt management
chrisj at rtems.org chrisj at rtems.org
Fri Feb 12 20:00:37 UTC 2021
- Add support to the BSP to enable irq-generic management
- Update the powerpc shared irq code to support irq-generic. This
  is an option in option for existing powerpc bsps. This change
  should be simpler now
- Fix a number of issues in ISA IRQ controller handling by porting
  fixes from the i386 (PC) BSP
Closes #4238
Closes #4239
 bsps/powerpc/include/bsp/irq_supp.h           |   5 +
 .../motorola_powerpc/include/bsp/irq.h        |  15 +-
 .../powerpc/motorola_powerpc/start/bspstart.c |   9 +-
 bsps/powerpc/shared/irq/i8259.c               | 155 ++++++++++++++----
 bsps/powerpc/shared/irq/irq_init.c            |  15 +-
 bsps/powerpc/shared/irq/openpic_i8259_irq.c   |  27 ++-
 bsps/powerpc/shared/irq/ppc-irq-generic.c     | 118 +++++++++++++
 .../bsps/powerpc/motorola_powerpc/grp.yml     |   2 +-
 .../bsps/powerpc/motorola_powerpc/obj.yml     |   3 +-
 9 files changed, 291 insertions(+), 58 deletions(-)
 create mode 100644 bsps/powerpc/shared/irq/ppc-irq-generic.c
diff --git a/bsps/powerpc/include/bsp/irq_supp.h b/bsps/powerpc/include/bsp/irq_supp.h
index 65af48c87f..fbb16d6211 100644
--- a/bsps/powerpc/include/bsp/irq_supp.h
+++ b/bsps/powerpc/include/bsp/irq_supp.h
@@ -50,6 +50,11 @@ extern int  BSP_disable_irq_at_pic(const rtems_irq_number irqLine);
 extern int  BSP_setup_the_pic(rtems_irq_global_settings* config);
+ * Set up for the irq-generic.h interface.
+int BSP_rtems_irq_generic_set(rtems_irq_global_settings* config);
 /* IRQ dispatcher to be defined by the PIC driver; note that it MUST
  * implement shared interrupts.
  * Note also that the exception frame passed to this handler is not very
diff --git a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
index 3690dbbff7..cbb6ff69cf 100644
--- a/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
+++ b/bsps/powerpc/motorola_powerpc/include/bsp/irq.h
@@ -19,9 +19,17 @@
 #ifndef BSP_POWERPC_IRQ_H
 #define BSP_POWERPC_IRQ_H
+#ifndef BSP_SHARED_HANDLER_SUPPORT
 #define BSP_SHARED_HANDLER_SUPPORT      1
+#endif
 #include <rtems/irq.h>
-#include <bsp/irq-default.h>
+ * Switch to using the generic support. Remove this when all BSPs have
+ * been converted.
+#define BSP_POWERPC_IRQ_GENERIC_SUPPORT 1
  * 8259 edge/level control definitions at VIA
@@ -107,6 +115,8 @@ extern "C" {
 #define BSP_IRQ_NUMBER			(BSP_MISC_IRQ_MAX_OFFSET + 1)
 #define BSP_LOWEST_OFFSET		(BSP_ISA_IRQ_LOWEST_OFFSET)
 #define BSP_MAX_OFFSET			(BSP_MISC_IRQ_MAX_OFFSET)
+#define BSP_INTERRUPT_VECTOR_MIN	(BSP_LOWEST_OFFSET)
+#define BSP_INTERRUPT_VECTOR_MAX	(BSP_MAX_OFFSET)
  * Some ISA IRQ symbolic name definition
@@ -191,6 +201,9 @@ int BSP_irq_ack_at_i8259s           	(const rtems_irq_number irqLine);
 int BSP_irq_enabled_at_i8259s        	(const rtems_irq_number irqLine);
+unsigned short BSP_irq_suspend_i8259s(unsigned short mask);
+void BSP_irq_resume_i8259s(unsigned short in_progress_save);
 extern void BSP_rtems_irq_mng_init(unsigned cpuId);
 extern void BSP_i8259s_init(void);
diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
index e74b02c446..ab48858c46 100644
--- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
+++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
@@ -27,6 +27,7 @@
 #include <bsp/pci.h>
 #include <bsp/openpic.h>
 #include <bsp/irq.h>
+#include <bsp/irq-generic.h>
 #include <libcpu/bat.h>
 #include <libcpu/pte121.h>
 #include <libcpu/cpuIdent.h>
@@ -334,10 +335,8 @@ static void bsp_early( void )
   bsp_clicks_per_usec 	 = BSP_bus_frequency/(BSP_time_base_divisor * 1000);
-   * Initalize RTEMS IRQ system
-  BSP_rtems_irq_mng_init(0);
+  /* Initalize interrupt support */
+  bsp_interrupt_initialize();
   /* Activate the page table mappings only after
    * initializing interrupts because the irq_mng_init()
@@ -360,7 +359,6 @@ static void bsp_early( void )
   printk("Exit from bspstart\n");
 #endif
 RTEMS_SYSINIT_ITEM(
   bsp_early,
   RTEMS_SYSINIT_BSP_EARLY,
@@ -370,6 +368,7 @@ RTEMS_SYSINIT_ITEM(
 void bsp_start( void )
   /* Initialization was done by bsp_early() */
 RTEMS_SYSINIT_ITEM(
diff --git a/bsps/powerpc/shared/irq/i8259.c b/bsps/powerpc/shared/irq/i8259.c
index 7363e87ba0..6a0b855981 100644
--- a/bsps/powerpc/shared/irq/i8259.c
+++ b/bsps/powerpc/shared/irq/i8259.c
@@ -12,6 +12,19 @@
 #include <bsp.h>
+#define PIC_EOSI        0x60    ///< End of Specific Interrupt (EOSI)
+#define PIC_EOI         0x20    ///< Generic End of Interrupt (EOI)
+/* Operation control word type 3.  Bit 3 (0x08) must be set. Even address. */
+#define PIC_OCW3_RIS        0x01            /* 1 = read IS, 0 = read IR */
+#define PIC_OCW3_RR         0x02            /* register read */
+#define PIC_OCW3_P          0x04            /* poll mode command */
+/* 0x08 must be 1 to select OCW3 vs OCW2 */
+#define PIC_OCW3_SEL        0x08            /* must be 1 */
+/* 0x10 must be 0 to select OCW3 vs ICW1 */
+#define PIC_OCW3_SMM        0x20            /* special mode mask */
+#define PIC_OCW3_ESMM       0x40            /* enable SMM */
 | Cache for 1st and 2nd PIC IRQ line's status (enabled or disabled) register.
@@ -19,91 +32,140 @@
  * lower byte is interrupt mask on the master PIC.
  * while upper bits are interrupt on the slave PIC.
-volatile rtems_i8259_masks i8259s_cache = 0xfffb;
+static rtems_i8259_masks i8259s_imr_cache = 0xFFFB;
+static rtems_i8259_masks i8259s_in_progress = 0;
+static inline
+void BSP_i8259s_irq_update_master_imr( void )
+  rtems_i8259_masks mask = i8259s_in_progress | i8259s_imr_cache;
+  outport_byte( PIC_MASTER_IMR_IO_PORT, mask & 0xff );
+static inline
+void BSP_i8259s_irq_update_slave_imr( void )
+  outport_byte( PIC_SLAVE_IMR_IO_PORT, ( mask >> 8 ) & 0xff );
+ * Is the IRQ valid?
+static inline bool BSP_i8259s_irq_valid(const rtems_irq_number irqLine)
+  return ((int)irqLine >= BSP_ISA_IRQ_LOWEST_OFFSET) &&
+    ((int)irqLine <= BSP_ISA_IRQ_MAX_OFFSET);
+ * Read the IRR register. The default.
+static inline uint8_t BSP_i8259s_irq_int_request_reg(uint32_t ioport)
+  uint8_t isr;
+  inport_byte(ioport, isr);
+  return isr;
+ * Read the ISR register. Keep the default of the IRR.
+static inline uint8_t BSP_i8259s_irq_in_service_reg(uint32_t ioport)
+  uint8_t isr;
+  outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR | PIC_OCW3_RIS);
+  outport_byte(ioport, PIC_OCW3_SEL | PIC_OCW3_RR);
+  return isr;
 |         Function:  BSP_irq_disable_at_i8259s
 |      Description: Mask IRQ line in appropriate PIC chip.
-| Global Variables: i8259s_cache
+| Global Variables: i8259s_imr_cache, i8259s_in_progress
 |        Arguments: vector_offset - number of IRQ line to mask.
-|          Returns: original state or -1 on error.
+|          Returns: 0 is OK.
-int BSP_irq_disable_at_i8259s    (const rtems_irq_number irqLine)
+int BSP_irq_disable_at_i8259s(const rtems_irq_number irqLine)
   unsigned short        mask;
   rtems_interrupt_level level;
-  int                   rval;
-  if ( ((int)irqLine < BSP_ISA_IRQ_LOWEST_OFFSET) ||
-       ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET)
+  if (!BSP_i8259s_irq_valid(irqLine))
     return -1;
   rtems_interrupt_disable(level);
   mask = 1 << irqLine;
-  rval = i8259s_cache & mask ? 0 : 1;
-  i8259s_cache |= mask;
+  i8259s_imr_cache |= mask;
   if (irqLine < 8)
-    outport_byte(PIC_MASTER_IMR_IO_PORT, i8259s_cache & 0xff);
+    BSP_i8259s_irq_update_master_imr();
   else
-    outport_byte(PIC_SLAVE_IMR_IO_PORT, ((i8259s_cache & 0xff00) >> 8));
+    BSP_i8259s_irq_update_slave_imr();
   rtems_interrupt_enable(level);
-  return rval;
+  return 0;
 |         Function:  BSP_irq_enable_at_i8259s
 |      Description: Unmask IRQ line in appropriate PIC chip.
 |        Arguments: irqLine - number of IRQ line to mask.
 |          Returns: Nothing.
-int BSP_irq_enable_at_i8259s    (const rtems_irq_number irqLine)
+int BSP_irq_enable_at_i8259s(const rtems_irq_number irqLine)
-  unsigned short        mask;
+  unsigned short        mask;
+  uint8_t               isr;
+  uint8_t               irr;
-       ((int)irqLine > BSP_ISA_IRQ_MAX_OFFSET )
     return 1;
-  mask = ~(1 << irqLine);
-  i8259s_cache &= mask;
+  mask = 1 << irqLine;
+  i8259s_imr_cache &= ~mask;
   if (irqLine < 8)
+    isr = BSP_i8259s_irq_in_service_reg(PIC_MASTER_COMMAND_IO_PORT);
+    irr = BSP_i8259s_irq_int_request_reg(PIC_MASTER_COMMAND_IO_PORT);
   else
+    isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
+    irr = BSP_i8259s_irq_int_request_reg(PIC_SLAVE_COMMAND_IO_PORT);
+  if (((isr ^ irr) & mask) != 0)
+    printk("powerpc: isr=%x irr=%x\n", isr, irr);
   return 0;
 } /* mask_irq */
-int BSP_irq_enabled_at_i8259s        	(const rtems_irq_number irqLine)
+int BSP_irq_enabled_at_i8259s(const rtems_irq_number irqLine)
     return 1;
   mask = (1 << irqLine);
-  return  (~(i8259s_cache & mask));
+  return  (~(i8259s_imr_cache & mask));
@@ -113,24 +175,47 @@ int BSP_irq_enabled_at_i8259s        	(const rtems_irq_number irqLine)
 |        Arguments: irqLine - number of IRQ line to acknowledge.
 |          Returns: Nothing.
-int BSP_irq_ack_at_i8259s  	(const rtems_irq_number irqLine)
+int BSP_irq_ack_at_i8259s(const rtems_irq_number irqLine)
+  uint8_t slave_isr = 0;
   if (irqLine >= 8) {
-    outport_byte(PIC_MASTER_COMMAND_IO_PORT, SLAVE_PIC_EOSI);
-    outport_byte(PIC_SLAVE_COMMAND_IO_PORT, (PIC_EOSI | (irqLine - 8)));
-  else {
-    outport_byte(PIC_MASTER_COMMAND_IO_PORT, (PIC_EOSI | irqLine));
+   outport_byte(PIC_SLAVE_COMMAND_IO_PORT, PIC_EOI);
+   slave_isr = BSP_i8259s_irq_in_service_reg(PIC_SLAVE_COMMAND_IO_PORT);
+   * Only issue the EOI to the master if there are no more interrupts in
+   * service for the slave. i8259a data sheet page 18, The Special Fully Nested
+   * Mode, b.
+  if (slave_isr == 0)
+    outport_byte(PIC_MASTER_COMMAND_IO_PORT, PIC_EOI);
   return 0;
 } /* ackIRQ */
+  unsigned short in_progress_save = i8259s_in_progress;
+  i8259s_in_progress |= mask;
+  return in_progress_save;
+  i8259s_in_progress = in_progress_save;
-   * init master 8259 interrupt controller
+   * Always mask at least current interrupt to prevent re-entrance
   outport_byte(PIC_MASTER_COMMAND_IO_PORT, 0x11); /* Start init sequence */
   outport_byte(PIC_MASTER_IMR_IO_PORT, 0x00);/* Vector base  = 0 */
diff --git a/bsps/powerpc/shared/irq/irq_init.c b/bsps/powerpc/shared/irq/irq_init.c
index 1042c9d1a8..233c659b85 100644
--- a/bsps/powerpc/shared/irq/irq_init.c
+++ b/bsps/powerpc/shared/irq/irq_init.c
@@ -280,6 +280,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
   int known_cpi_isa_bridge = 0;
 #endif
   int i;
+  int r;
    * First initialize the Interrupt management hardware
@@ -351,7 +352,19 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
     initial_config.irqBase	= BSP_LOWEST_OFFSET;
     initial_config.irqPrioTbl	= irqPrioTable;
-    if (!BSP_rtems_irq_mngt_set(&initial_config)) {
+#ifdef BSP_POWERPC_IRQ_GENERIC_SUPPORT
+#ifdef TRACE_IRQ_INIT
+    printk("RTEMS IRQ management: irq-generic\n");
+#endif
+    r = BSP_rtems_irq_generic_set(&initial_config);
+#else
+    printk("RTEMS IRQ management: legacy\n");
+#endif
+    r = BSP_rtems_irq_mngt_set(&initial_config);
+#endif
+    if (!r) {
        * put something here that will show the failure...
diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
index 513b9ac3e0..2617555658 100644
--- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
+++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
@@ -15,6 +15,7 @@
 #include <bsp.h>
 #include <bsp/irq_supp.h>
 #ifndef BSP_HAS_NO_VME
 #include <bsp/VMEConfig.h>
 #endif
@@ -234,15 +235,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
 #if BSP_ISA_IRQ_NUMBER > 0
   register unsigned isaIntr;                  /* boolean */
   register unsigned oldMask = 0;	      /* old isa pic masks */
-  register unsigned newMask;                  /* new isa pic masks */
 #endif
   if (excNum == ASM_DEC_VECTOR) {
-  	bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER, default_rtems_entry.hdl);
+    bsp_interrupt_handler_dispatch(BSP_DECREMENTER);
+#else
+    bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER, default_rtems_entry.hdl);
+#endif
     return 0;
 #if BSP_PCI_IRQ_NUMBER > 0
@@ -274,7 +275,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
 #ifdef BSP_PCI_ISA_BRIDGE_IRQ
-#if 0 == BSP_PCI_IRQ_NUMBER
+#if 0 == BSP_PCI_IRQ_NUMBER
 #error "Configuration Error -- BSP w/o PCI IRQs MUST NOT define BSP_PCI_ISA_BRIDGE_IRQ"
 #endif
   isaIntr = (irq == BSP_PCI_ISA_BRIDGE_IRQ);
@@ -289,11 +290,7 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
      * store current PIC mask
-    oldMask = i8259s_cache;
-    newMask = oldMask | irq_mask_or_tbl [irq];
-    i8259s_cache = newMask;
+    oldMask = BSP_irq_suspend_i8259s(irq_mask_or_tbl [irq]);
     BSP_irq_ack_at_i8259s (irq);
 	if ( OpenPIC )
@@ -303,13 +300,15 @@ int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
 #endif
   /* dispatch handlers */
+  bsp_interrupt_handler_dispatch(irq);
+#else
   bsp_irq_dispatch_list(rtems_hdl_tbl, irq, default_rtems_entry.hdl);
+#endif
   if (isaIntr)  {
-    i8259s_cache = oldMask;
+    BSP_irq_resume_i8259s(oldMask);
   else
 #endif
diff --git a/bsps/powerpc/shared/irq/ppc-irq-generic.c b/bsps/powerpc/shared/irq/ppc-irq-generic.c
new file mode 100644
index 0000000000..fc364f06a8
--- /dev/null
+++ b/bsps/powerpc/shared/irq/ppc-irq-generic.c
@@ -0,0 +1,118 @@
+ * @file
+ * @ingroup RTEMSBSPsPowerPC
+ * @brief Generic Interrupt suppoer
+ * Copyright (C) 2021 Chris Johns. All rights reserved.
+ * are met:
+#include <stdlib.h>
+#include <rtems.h>
+#include <rtems/bspIo.h> /* for printk */
+#include <libcpu/spr.h>
+#include <bsp/irq_supp.h>
+#include <bsp/vectors.h>
+SPR_RW(BOOKE_TSR)
+SPR_RW(PPC405_TSR)
+/* legacy mode for bookE DEC exception;
+ * to avoid the double layer of function calls
+ * (dec_handler_bookE -> C_dispatch_irq_handler -> user handler)
+ * it is preferrable for the user to hook the DEC
+ * exception directly.
+ * However, the legacy mode works with less modifications
+ * of user code.
+static int C_dispatch_dec_handler_bookE (BSP_Exception_frame *frame, unsigned int excNum)
+  /* clear interrupt; we must do this
+   * before C_dispatch_irq_handler()
+   * re-enables MSR_EE.
+   * Note that PPC405 uses a different SPR# for TSR
+  if ( ppc_cpu_is_bookE()==PPC_BOOKE_405)
+    _write_PPC405_TSR( BOOKE_TSR_DIS );
+  else
+    _write_BOOKE_TSR( BOOKE_TSR_DIS );
+  return C_dispatch_irq_handler(frame, ASM_DEC_VECTOR);
+ * RTEMS Global Interrupt Handler Management Routines
+  int r;
+  r = BSP_setup_the_pic(config);
+  if (!r)
+    return r;
+  ppc_exc_set_handler(ASM_EXT_VECTOR, C_dispatch_irq_handler);
+  if ( ppc_cpu_is_bookE() ) {
+    /* bookE decrementer interrupt needs to be cleared BEFORE
+     * dispatching the user ISR (because the user ISR is called
+     * with EE enabled)
+     * We do this so that existing DEC handlers can be used
+     * with minor modifications.
+    ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, C_dispatch_dec_handler_bookE);
+  } else {
+    ppc_exc_set_handler(ASM_DEC_VECTOR, C_dispatch_irq_handler);
+  return 1;
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
+  bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+  BSP_enable_irq_at_pic(vector);
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
+  BSP_disable_irq_at_pic(vector);
+rtems_status_code bsp_interrupt_facility_initialize(void)
+   * Initalize RTEMS IRQ system
+  BSP_rtems_irq_mng_init(0);
+  return RTEMS_SUCCESSFUL;
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
index f256fec10f..a3ad2b115d 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/grp.yml
@@ -10,7 +10,7 @@ links:
 - role: build-dependency
   uid: ../../obj
-  uid: ../../objirqdflt
+  uid: ../../objirq
   uid: ../crti
diff --git a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
index 07ee6fa721..ae7b9f96e2 100644
--- a/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
+++ b/spec/build/bsps/powerpc/motorola_powerpc/obj.yml
@@ -39,7 +39,7 @@ source:
 - bsps/powerpc/shared/irq/irq_init.c
 - bsps/powerpc/shared/irq/openpic.c
 - bsps/powerpc/shared/irq/openpic_i8259_irq.c
-- bsps/powerpc/shared/irq/ppc-irq-legacy.c
+- bsps/powerpc/shared/irq/ppc-irq-generic.c
 - bsps/powerpc/shared/mmu/bat.c
 - bsps/powerpc/shared/mmu/mmuAsm.S
 - bsps/powerpc/shared/mmu/pte121.c
@@ -57,5 +57,6 @@ source:
 - bsps/powerpc/shared/start/zerobss.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
 - bsps/shared/dev/rtc/rtc-support.c
+- bsps/shared/irq/irq-default-handler.c
 - bsps/shared/start/bspfatal-default.c
 type: build
2.24.1
