sifive risc-v hifive unleashed bsp (qemu)
Sat Feb 13 03:59:59 UTC 2021
On Fri, Feb 12, 2021, 8:47 PM Rohan kumar <krohan8870 at gmail.com> wrote:
> I will look into this in more detail and get back to you but in mean time
> I want to contribute to any issues so can you suggest any thats need to be
> solved or how do I look for from my own.
Projects or just smaller issues?
There is a tag in the ticketing system for small projects but this query
makes me wonder if some should be closed. Deciding a ticket is dead is
good. :)
https://devel.rtems.org/query?status=accepted&status=assigned&status=new&status=reopened&keywords=~Small&col=id&col=summary&col=status&col=owner&col=type&col=priority&col=milestone&order=priority
Looking at Coverity is a quick way to find a small task. Some tickets
geared to adding a test aren't bad.
--joel
> Thanks
> Sanskar
> On Fri, Feb 12, 2021, 3:01 PM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
>> On Fri, 12 Feb 2021 at 11:24, Sanskar Khandelwal <kdsanskar07 at gmail.com>
>> wrote:
>> > Hello joel,
>> > 1. #4162 : sifive risc-v hifive unleashed bsp (qemu)
>> > As you mentioned this a good project i thought to search more about
>> this project I learned a lot while doing so but I still don't understand
>> what is the goal of this project (the description on the ticket is not very
>> detailed ) also I don't have any idea on how to make approach for this
>> project right now so if you can clear both my doubt it will be big help.
>> You'd need to identify the devices for this platform that QEMU
>> supports (e.g., networking, UART, flash, etc?) and propose some
>> timeline to implement (a subset of) them. That would be part of your
>> proposal evaluation.
>> > Also as you mention that this can be a big task for a gsoc time frame I
>> am thinking that I can do some of it after gsoc too.
>> > Also I looked for some more open projects and found these interesting
>> so I wanted to know if these are open for participation for gsoc and what's
>> their status and what further enhancement you are looking at each of them.
>> > 2. #3337 : RISC-V Port in Supervisor Mode
>> > 3. #4182 : Port Rust to RTEMS
>> > Another thing is that while I am learning more about these projects I
>> want to contribute, so if you can tell me about any issue that I can work
>> on, it will be nice. I think this will help get me more familiar with rtems
>> too.
>> > Thanks
>> > Sanskar
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210212/53e32687/attachment-0001.html>
