[PATCH v2 2/3] bsps/xilinx_zynq: Add SPI driver to waf
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Sun Feb 14 11:22:30 UTC 2021
Yes, my bad.
When changing that compared to version 1 of the patch, I wanted to remove the references to cadence-spi, but instead removed the ones to cadence-i2c :-/
I will send in a new patchset.
Best regards,
   Jan
> -----Original Message-----
> From: Kinsey Moore <kinsey.moore at oarcorp.com>
> Sent: Saturday, February 13, 2021 6:16 PM
> To: Sommer, Jan <Jan.Sommer at dlr.de>; devel at rtems.org
> Subject: RE: [PATCH v2 2/3] bsps/xilinx_zynq: Add SPI driver to waf
> The header locations in spec/build/bsps/arm/xilinx-zynq/obj.yml don't look
> correct due to the relocation and should probably be removed entirely since
> they're now broken out into spec/build/bsps/objdevspizynq.yml, instead.
> Kinsey
> From: devel <devel-bounces at rtems.org> On Behalf Of Jan Sommer
> Sent: Saturday, February 13, 2021 08:19
> To: devel at rtems.org
> Subject: [PATCH v2 2/3] bsps/xilinx_zynq: Add SPI driver to waf
>  spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml  |  2 ++
>  spec/build/bsps/arm/xilinx-zynq/grp.yml        |  2 ++
>  spec/build/bsps/arm/xilinx-zynq/obj.yml        |  4 ++--
>  .../bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml |  2 ++
>  spec/build/bsps/objdevspizynq.yml              | 18 ++++++++++++++++++
>  5 files changed, 26 insertions(+), 2 deletions(-)  create mode 100644
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> index 552723c61c..c952b4f59e 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
> @@ -33,6 +33,8 @@ links:
>    uid: ../../objirq
>  - role: build-dependency
>    uid: ../../objdevserialzynq
> +- role: build-dependency
> +  uid: ../../objdevspizynq
>    uid: ../../optcachedata
> diff --git a/spec/build/bsps/arm/xilinx-zynq/grp.yml
> b/spec/build/bsps/arm/xilinx-zynq/grp.yml
> index 74adbd7fa7..0bbee1922c 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/grp.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/grp.yml
> @@ -57,6 +57,8 @@ links:
>    uid: ../../objirq
>    uid: linkcmds
> diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml
> b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> index 6602b20a03..8b7e65ed40 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> @@ -14,9 +14,9 @@ install:
>    - bsps/arm/xilinx-zynq/include/tm27.h
>  - destination: ${BSP_INCLUDEDIR}/bsp
>    source:
> -  - bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
> -  - bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
>    - bsps/arm/xilinx-zynq/include/bsp/i2c.h
> +  - bsps/arm/xilinx-zynq/include/bsp/cadence-spi.h
> +  - bsps/arm/xilinx-zynq/include/bsp/cadence-spi-regs.h
>    - bsps/arm/xilinx-zynq/include/bsp/irq.h
>  links: []
>  source:
> diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
> b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
> index 51d3268e99..d4e8cbc1ce 100644
> --- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
> +++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
> @@ -69,6 +69,8 @@ links:
>    uid: ../../objirq
>    uid: ../../opto2
> diff --git a/spec/build/bsps/objdevspizynq.yml
> b/spec/build/bsps/objdevspizynq.yml
> new file mode 100644
> index 0000000000..b778e756e1
> --- /dev/null
> +++ b/spec/build/bsps/objdevspizynq.yml
> @@ -0,0 +1,18 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: objects
> +cflags: []
> +copyrights:
> +- Copyright (C) 2021 German Aerospace Center (DLR)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}/dev/spi
> +  source:
> +  - bsps/include/dev/spi/cadence-spi-regs.h
> +  - bsps/include/dev/spi/cadence-spi.h
> +links: []
> +source:
> +- bsps/shared/dev/spi/cadence-spi.c
> +type: build
> 2.17.1
> devel mailing list
> devel at rtems.org
