[PATCH] tests/validation: Fix 64bit test failure
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Mon Feb 15 15:12:15 UTC 2021
The ts-validation-0 test currently fails on 64bit BSPs due to a
limitation of the message structure. Changing the max message size to a
size_t type and adjusting the expected value in the test resolves this.
Closes #4179.
 cpukit/include/rtems/rtems/message.h                | 2 +-
 cpukit/include/rtems/score/coremsgimpl.h            | 2 +-
 cpukit/score/src/coremsg.c                          | 2 +-
 spec/build/bsps/aarch64/a53/tsta53.yml              | 3 ---
 spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml   | 3 ---
 testsuites/validation/tc-message-construct-errors.c | 2 +-
 6 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/rtems/message.h b/cpukit/include/rtems/rtems/message.h
index 14083b8cd0..7bb48ba35a 100644
--- a/cpukit/include/rtems/rtems/message.h
+++ b/cpukit/include/rtems/rtems/message.h
@@ -51,7 +51,7 @@ typedef struct {
    * @brief This member defines the maximum number of pending messages supported
    *   by the message queue.
-  uint32_t maximum_pending_messages;
+  size_t maximum_pending_messages;
    * @brief This member defines the maximum message size supported by the message
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index 6f6a01bea6..c7a424c08c 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -144,7 +144,7 @@ void *_CORE_message_queue_Workspace_allocate(
 Status_Control _CORE_message_queue_Initialize(
   CORE_message_queue_Control          *the_message_queue,
   CORE_message_queue_Disciplines       discipline,
-  uint32_t                             maximum_pending_messages,
+  size_t                               maximum_pending_messages,
   size_t                               maximum_message_size,
   CORE_message_queue_Allocate_buffers  allocate_buffers,
   const void                          *arg
diff --git a/cpukit/score/src/coremsg.c b/cpukit/score/src/coremsg.c
index cf7f44ed17..530f05719a 100644
--- a/cpukit/score/src/coremsg.c
+++ b/cpukit/score/src/coremsg.c
@@ -35,7 +35,7 @@ RTEMS_STATIC_ASSERT(
   const void                          *arg
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index 9135fac7f4..4ecef03641 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -4,9 +4,6 @@ actions:
     # expected to fail, don't compile these
     minimum: exclude
-    # test broken under 64bit due to SIZE_MAX differences
-    validation-0: exclude
     # don't compile due to toolchain issues
     spconfig01: exclude
     spmisc01: exclude
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index d0efba65cd..45fdc503aa 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
     # expected to fail
     minimum: exclude
-    validation-0: expected-fail
     spconfig01: exclude
     spmisc01: exclude
diff --git a/testsuites/validation/tc-message-construct-errors.c b/testsuites/validation/tc-message-construct-errors.c
index 5820855ac4..903ff534fa 100644
--- a/testsuites/validation/tc-message-construct-errors.c
+++ b/testsuites/validation/tc-message-construct-errors.c
@@ -278,7 +278,7 @@ static void RtemsMessageReqConstructErrors_Pre_MaxPending_Prepare(
     case RtemsMessageReqConstructErrors_Pre_MaxPending_Big: {
-      ctx->config.maximum_pending_messages = UINT32_MAX;
+      ctx->config.maximum_pending_messages = SIZE_MAX;
       break;
2.20.1
