[6-freebsd-12 PATCH 2/2] bsp/motorola_powerpc: Add dc and ukphy support
Chris Johns
chrisj at rtems.org
Tue Feb 16 02:10:39 UTC 2021
On 16/2/21 1:02 pm, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Add the dc net dev to the BSP
> - Add the ukphy support
> Closes # 4246
> freebsd/sys/dev/dc/if_dc.c | 10 ++++--
> freebsd/sys/dev/dc/if_dcreg.h | 7 ++++
> rtemsbsd/include/bsp/nexus-devices.h | 4 +++
> .../include/machine/rtems-bsd-nexus-bus.h | 32 +++++++++++++++++++
> 4 files changed, 50 insertions(+), 3 deletions(-)
> diff --git a/freebsd/sys/dev/dc/if_dc.c b/freebsd/sys/dev/dc/if_dc.c
> index 7fc0ef54..4cb61fa5 100644
> --- a/freebsd/sys/dev/dc/if_dc.c
> +++ b/freebsd/sys/dev/dc/if_dc.c
> @@ -156,6 +156,10 @@ MODULE_DEPEND(dc, miibus, 1, 1, 1);
> * Various supported device vendors/types and their names.
> static const struct dc_type dc_devs[] = {
> +#ifdef __rtems__
> + { DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21140A), 0,
> + "Intel 21140A 10/100BaseTX" },
> +#endif /* __rtems__ */
> { DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21143), 0,
> "Intel 21143 10/100BaseTX" },
> { DC_DEVID(DC_VENDORID_DAVICOM, DC_DEVICEID_DM9009), 0,
> @@ -2076,6 +2080,9 @@ dc_attach(device_t dev)
> dc_eeprom_width(sc);
> switch (sc->dc_info->dc_devid) {
> +#ifdef __rtems__
> + case DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21140A):
> case DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21143):
> sc->dc_type = DC_TYPE_21143;
> sc->dc_flags |= DC_TX_POLL | DC_TX_USE_TX_INTR;
> @@ -2449,7 +2456,6 @@ dc_attach(device_t dev)
> error = mii_attach(dev, &sc->dc_miibus, ifp, dc_ifmedia_upd,
> dc_ifmedia_sts, BMSR_DEFCAPMASK, phy, MII_OFFSET_ANY, 0);
> if (error && DC_IS_INTEL(sc)) {
> sc->dc_pmode = tmp;
> if (sc->dc_pmode != DC_PMODE_SIA)
> @@ -2503,7 +2509,6 @@ dc_attach(device_t dev)
> /* Hook interrupt last to avoid having to lock softc */
> error = bus_setup_intr(dev, sc->dc_irq, INTR_TYPE_NET | INTR_MPSAFE,
> NULL, dc_intr, sc, &sc->dc_intrhand);
Whitespace, I will send v2.
> if (error) {
> device_printf(dev, "couldn't set up irq\n");
> ether_ifdetach(ifp);
> @@ -2602,7 +2607,6 @@ dc_list_tx_init(struct dc_softc *sc)
> ld->dc_tx_list[i].dc_next = htole32(DC_TXDESC(sc, nexti));
> cd->dc_tx_chain[i] = NULL;
> cd->dc_tx_prod = cd->dc_tx_cons = cd->dc_tx_cnt = 0;
> cd->dc_tx_pkts = 0;
> bus_dmamap_sync(sc->dc_tx_ltag, sc->dc_tx_lmap,
> diff --git a/freebsd/sys/dev/dc/if_dcreg.h b/freebsd/sys/dev/dc/if_dcreg.h
> index 9ae26cc6..836e70f8 100644
> --- a/freebsd/sys/dev/dc/if_dcreg.h
> +++ b/freebsd/sys/dev/dc/if_dcreg.h
> @@ -824,6 +824,13 @@ struct dc_softc {
> #define DC_VENDORID_DEC 0x1011
> +#ifdef __rtems__
> + * DEC/Intel 21140 PCI device ID
> +#define DC_DEVICEID_21140A 0x0009
> * DEC/Intel 21143 PCI device ID
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index c3c43dc9..d813addd 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -199,6 +199,8 @@ RTEMS_BSD_DRIVER_PCI_IGB;
> RTEMS_BSD_DRIVER_PCI_EM;
> RTEMS_BSD_DRIVER_PCI_RE;
> RTEMS_BSD_DRIVER_REPHY;
> +RTEMS_BSD_DRIVER_PCI_DC;
> +RTEMS_BSD_DRIVER_DCPHY;
> #elif defined(LIBBSP_POWERPC_QORIQ_BSP_H)
> @@ -240,6 +242,8 @@ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
> #elif defined(LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H)
> RTEMS_BSD_DRIVER_PC_LEGACY;
> +RTEMS_BSD_DRIVER_UKPHY;
> #endif /* LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H */
> diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> index 5c95d2c3..752bc559 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> @@ -486,10 +486,26 @@ extern "C" {
> SYSINIT_DRIVER_REFERENCE(re, pci);
> #endif /* RTEMS_BSD_DRIVER_PCI_RE */
> + * DEC Tulip Driver
> +#if !defined(RTEMS_BSD_DRIVER_PCI_DC)
> + #define RTEMS_BSD_DRIVER_PCI_DC \
> + SYSINIT_DRIVER_REFERENCE(dc, pci);
> +#endif /* RTEMS_BSD_DRIVER_PCI_DC */
> ** MMI Physical Layer Support.
> + * UK PHY (for unknown PHY devices)
> +#if !defined(RTEMS_BSD_DRIVER_UKPHY)
> + #define RTEMS_BSD_DRIVER_UKPHY \
> + SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
> +#endif /* RTEMS_BSD_DRIVER_UKPHY */
> * E1000 PHY
> @@ -522,6 +538,22 @@ extern "C" {
> SYSINIT_DRIVER_REFERENCE(micphy, miibus);
> #endif /* RTEMS_BSD_DRIVER_PHY_MIC */
> + * DC PHY.
> +#if !defined(RTEMS_BSD_DRIVER_DCPHY)
> + #define RTEMS_BSD_DRIVER_DCPHY \
> + SYSINIT_DRIVER_REFERENCE(dcphy, miibus);
> +#endif /* RTEMS_BSD_DRIVER_DCPHY */
> + * PN PHY.
> +#if !defined(RTEMS_BSD_DRIVER_PNPHY)
> + #define RTEMS_BSD_DRIVER_PNPHY \
> + SYSINIT_DRIVER_REFERENCE(pnphy, miibus);
> +#endif /* RTEMS_BSD_DRIVER_PNPHY */
> #ifdef __cplusplus
> #endif /* __cplusplus */
