[6-freebsd-12 PATCH v2 2/2] bsp/motorola_powerpc: Add dc and ukphy support
chrisj at rtems.org
chrisj at rtems.org
Tue Feb 16 02:10:50 UTC 2021
- Add the dc net dev to the BSP
- Add the ukphy support
Closes # 4246
freebsd/sys/dev/dc/if_dc.c | 7 ++++
freebsd/sys/dev/dc/if_dcreg.h | 7 ++++
rtemsbsd/include/bsp/nexus-devices.h | 4 +++
.../include/machine/rtems-bsd-nexus-bus.h | 32 +++++++++++++++++++
4 files changed, 50 insertions(+)
diff --git a/freebsd/sys/dev/dc/if_dc.c b/freebsd/sys/dev/dc/if_dc.c
index 7fc0ef54..b36967da 100644
--- a/freebsd/sys/dev/dc/if_dc.c
+++ b/freebsd/sys/dev/dc/if_dc.c
@@ -156,6 +156,10 @@ MODULE_DEPEND(dc, miibus, 1, 1, 1);
* Various supported device vendors/types and their names.
static const struct dc_type dc_devs[] = {
+#ifdef __rtems__
+ { DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21140A), 0,
+ "Intel 21140A 10/100BaseTX" },
+#endif /* __rtems__ */
{ DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21143), 0,
"Intel 21143 10/100BaseTX" },
{ DC_DEVID(DC_VENDORID_DAVICOM, DC_DEVICEID_DM9009), 0,
@@ -2076,6 +2080,9 @@ dc_attach(device_t dev)
dc_eeprom_width(sc);
switch (sc->dc_info->dc_devid) {
+#ifdef __rtems__
+ case DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21140A):
case DC_DEVID(DC_VENDORID_DEC, DC_DEVICEID_21143):
sc->dc_type = DC_TYPE_21143;
sc->dc_flags |= DC_TX_POLL | DC_TX_USE_TX_INTR;
diff --git a/freebsd/sys/dev/dc/if_dcreg.h b/freebsd/sys/dev/dc/if_dcreg.h
index 9ae26cc6..836e70f8 100644
--- a/freebsd/sys/dev/dc/if_dcreg.h
+++ b/freebsd/sys/dev/dc/if_dcreg.h
@@ -824,6 +824,13 @@ struct dc_softc {
#define DC_VENDORID_DEC 0x1011
+#ifdef __rtems__
+ * DEC/Intel 21140 PCI device ID
+#define DC_DEVICEID_21140A 0x0009
* DEC/Intel 21143 PCI device ID
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index c3c43dc9..d813addd 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -199,6 +199,8 @@ RTEMS_BSD_DRIVER_PCI_IGB;
RTEMS_BSD_DRIVER_PCI_EM;
RTEMS_BSD_DRIVER_PCI_RE;
RTEMS_BSD_DRIVER_REPHY;
+RTEMS_BSD_DRIVER_PCI_DC;
+RTEMS_BSD_DRIVER_DCPHY;
#elif defined(LIBBSP_POWERPC_QORIQ_BSP_H)
@@ -240,6 +242,8 @@ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
#elif defined(LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H)
RTEMS_BSD_DRIVER_PC_LEGACY;
+RTEMS_BSD_DRIVER_UKPHY;
#endif /* LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H */
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 5c95d2c3..752bc559 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -486,10 +486,26 @@ extern "C" {
SYSINIT_DRIVER_REFERENCE(re, pci);
#endif /* RTEMS_BSD_DRIVER_PCI_RE */
+ * DEC Tulip Driver
+#if !defined(RTEMS_BSD_DRIVER_PCI_DC)
+ #define RTEMS_BSD_DRIVER_PCI_DC \
+ SYSINIT_DRIVER_REFERENCE(dc, pci);
+#endif /* RTEMS_BSD_DRIVER_PCI_DC */
** MMI Physical Layer Support.
+ * UK PHY (for unknown PHY devices)
+#if !defined(RTEMS_BSD_DRIVER_UKPHY)
+ #define RTEMS_BSD_DRIVER_UKPHY \
+ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
+#endif /* RTEMS_BSD_DRIVER_UKPHY */
* E1000 PHY
@@ -522,6 +538,22 @@ extern "C" {
SYSINIT_DRIVER_REFERENCE(micphy, miibus);
#endif /* RTEMS_BSD_DRIVER_PHY_MIC */
+ * DC PHY.
+#if !defined(RTEMS_BSD_DRIVER_DCPHY)
+ #define RTEMS_BSD_DRIVER_DCPHY \
+ SYSINIT_DRIVER_REFERENCE(dcphy, miibus);
+#endif /* RTEMS_BSD_DRIVER_DCPHY */
+ * PN PHY.
+#if !defined(RTEMS_BSD_DRIVER_PNPHY)
+ #define RTEMS_BSD_DRIVER_PNPHY \
+ SYSINIT_DRIVER_REFERENCE(pnphy, miibus);
+#endif /* RTEMS_BSD_DRIVER_PNPHY */
#ifdef __cplusplus
#endif /* __cplusplus */
2.24.1
