[6-freebsd-12 PATCH 1/2] rtemsbsd/bus: Add PCI support to the nexus bus
Wed Feb 17 02:20:18 UTC 2021
I have looked into this some more with Joel. Comments below ..
On 16/2/21 5:49 pm, Chris Johns wrote:
> Hi Sebastian,
> Thank you for the review.
> On 16/2/21 5:05 pm, Sebastian Huber wrote:
>> On 16/02/2021 03:02, chrisj at rtems.org wrote:
>>> + * Values for the bus space tag, not to be used directly by MI code.
>>> +#define    BSP_BUS_SPACE_IO    0    /* space is i/o space */
>>> +#define    BSP_BUS_SPACE_MEM    1    /* space is mem space */
>>> + * BSP PCI Support
>>> + * The RTEMS Nexus bus support can optionaly support PCI spaces that
>>> + * mapped to BSP speciic address spaces. Add the following define to
>>> + * the BSP header file to enable this support:
>>> + *  #define BSP_HAS_PCI
>>> + * If enabled a BSP must the following IO region calls:
>>> + * inb  : read 8 bits
>>> + * outb : write 8 bits
>>> + * inw  : read 16 bits
>>> + * outw : write 16 bits
>>> + * inl  : read 32 bits
>>> + * outl : write 32 bits
>>> + * The BSP needs to provide the DRAM address space offset
>>> + * PCI_DRAM_OFFSET. This is the base address of the DRAM as seen by a
>>> + * PCI master.
>> Why is it not possible to account for this offset in the bus_space_handle_t bsh?
> How do I do that?
I have figured this out. We can avoid tags (for now).
> FYI some testing with the zynq in qemu results in the PHY failing to initialise.
> It will need a closer look.
I am yet to see what the issue was here.
>> I thought the purpose of the bus_space_tag_t bst was to select different
>> instructions to access the memory space.
> Instructions or a mix of buses? I am still learning my way around this bus
> design but I would have thought tags can handle specific discontinuous buses
> mixed into the same linear address space. That is the drivers offsets are all
> relative to a specific bus. The PCI reports addresses that are relative to that
> buses base address and this is what PCI drivers use.
Given the defined resources I am not sure you fully mix things without using
tags. As I will discuss below endian issues with a specific bus can be a reason.
>> The generic file is for systems with memory mapped access only.
> The bus.h is per arch so if I specialise it for the PowerPC all BSPs in the
> PowerPC arch come across and in the end it becomes the same thing. I cannot see
> a way specialise this per BSP and I am not sure it is needed.
I am coming the conclusion the current bus.h is not suitable for the PowerPC
architecture in general as is. There maybe younger devices with more advanced
bus structures optimised for a specific niche however we also need to balance
the fact we have decades of proven operation in important systems we need to
maintain. Some how we need to find a path all LibBSD PowerPC users are OK with.
We need to look at using the `eieio` instruction. I am reluctant to stop using
it even if testing shows it is OK. These systems are older PowerPC systems and
playing around at the low level after all this time would concern me.
The factor that has come to light with my testing is the PCI bus and devices are
in LE and the PowerPC is BE. This means a suitability sized volatile pointer to
memory does not work. With the VME PowerPC boards I think we are OK with LibBSD
as the devices it will interact with will all be PCI and we force all IO to be LE.
>> It also
>> includes <bsp.h> and thus <rtems.h> in a file which is included all over the place.
> The buf.h header inlines calls which is fine but if we need an offset from a BSP
> the BSP header is needed. We only export from a BSP as a single header.
> I could not see an easy way to have a BSP indicate it has PCI support in LibBSD.
We need to decide if we let the BSP define a set of calls that can be used. This
would mean including `bsp.h` in `bus.h` as I have done. I would rework the
implementation to default to a volatile memory pointer if the BSP has not
provided a BSP specific replacement.
Another alternative is to have a PowerPC specific `bus.h` and then basically do
the same thing only with the LE and BE present in that file then somehow
figuring out how to select the one needed.
I prefer the first option with the increased build time due to including bsp.h,
rtems.h etc.
