splinkersets01 test assumptions
Sebastian Huber
Wed Feb 17 06:15:13 UTC 2021
On 16/02/2021 22:26, Kinsey Moore wrote:
> In verifying AArch64/ILP32 on hardware I ran across quite a few
> alignment issues,
> some of which were caused by the use of SUBALIGN() in the linker
> scripts mentioned here:
> https://devel.rtems.org/ticket/4178 <https://devel.rtems.org/ticket/4178>
> SUBALIGN() was necessary for two reasons:
> * libc sysinit linker sets (this can be fixed in the sysinit handler
> struct)
> * splinkersets01 could not be made to pass on ILP32 as-is without
> SUBALIGN
In the ld documentation we have:
https://sourceware.org/binutils/docs/ld/Forced-Input-Alignment.html#index-SUBALIGN_0028subsection_005falign_0029
"You can force input section alignment within an output section by using
SUBALIGN. The value specified overrides any alignment given by input
sections, whether larger or smaller."
I think the use of SUBALIGN() is a bug and should be removed. Why do you
want to override the alignment of the input sections?
> It seems that splinkersets01 makes the assumption that linker sets are
> aligned to no more
> than the size of a pointer. For ILP32, this is not the case since
> AArch64 hardware is very
> sensitive to misaligned accesses and many structs in linker sections
> need to be aligned to
> 8-byte boundaries to avoid throwing exceptions. Some may even need to
> be aligned to
> 16-byte boundaries depending on the structure, but this doesn’t apply
> to splinkersets01.
> The resultant alignment padding causes many assertions in
> splinkersets01 to fail.
The linker sets should use the alignment of the item type. This is done
by defining zero length arrays:
#define RTEMS_LINKER_ROSET( set, type ) \
type const RTEMS_LINKER_SET_BEGIN( set )[ 0 ] \
RTEMS_SECTION( ".rtemsroset." #set ".begin" ) RTEMS_USED; \
type const RTEMS_LINKER_SET_END( set )[ 0 ] \
RTEMS_SECTION( ".rtemsroset." #set ".end" ) RTEMS_USED
In standard C such arrays are not defined, but GCC does the right thing:
cat test-linkersets.c
#define RTEMS_USED __attribute__(( __used__ ))
#define RTEMS_SECTION( _section ) __attribute__(( __section__( _section ) ))
#define RTEMS_LINKER_SET_BEGIN( set ) \
_Linker_set_##set##_begin
#define RTEMS_LINKER_SET_END( set ) \
_Linker_set_##set##_end
struct s { __attribute__((__aligned__(256))) int i; };
RTEMS_LINKER_ROSET( i, int );
RTEMS_LINKER_ROSET( ll, long long );
RTEMS_LINKER_ROSET( s, struct s );
aarch64-rtems6-gcc -O2 -S -o - test-linkersets.c
.arch armv8-a
.file "test-linkersets.c"
.text
.global _Linker_set_s_end
.global _Linker_set_s_begin
.global _Linker_set_ll_end
.global _Linker_set_ll_begin
.global _Linker_set_i_end
.global _Linker_set_i_begin
.section .rtemsroset.i.begin,"a"
.align 3
.type _Linker_set_i_begin, %object
.size _Linker_set_i_begin, 0
_Linker_set_i_begin:
.section .rtemsroset.i.end,"a"
.align 3
.type _Linker_set_i_end, %object
.size _Linker_set_i_end, 0
_Linker_set_i_end:
.section .rtemsroset.ll.begin,"a"
.align 3
.type _Linker_set_ll_begin, %object
.size _Linker_set_ll_begin, 0
_Linker_set_ll_begin:
.section .rtemsroset.ll.end,"a"
.align 3
.type _Linker_set_ll_end, %object
.size _Linker_set_ll_end, 0
_Linker_set_ll_end:
.section .rtemsroset.s.begin,"a"
.align 8
.type _Linker_set_s_begin, %object
.size _Linker_set_s_begin, 0
_Linker_set_s_begin:
.section .rtemsroset.s.end,"a"
.align 8
.type _Linker_set_s_end, %object
.size _Linker_set_s_end, 0
_Linker_set_s_end:
.ident "GCC: (GNU) 10.2.1 20210205 (RTEMS 6, RSB
61dcadee0825867ebe51f9f367430ef75b8fe9c0, Newlib d4a756f)"
aarch64-rtems6-gcc -O2 -S -o - test-linkersets.c -mabi=ilp32
.arch armv8-a
.text
.align 3
.align 3
_Linker_set_i_end:
.align 3
.align 3
_Linker_set_ll_end:
.align 8
.align 8
_Linker_set_s_end:
> I’m trying to find a way to make everything work together, but I’d
> like some input.
> The highlights with ILP32/LibBSD/hardware:
> * current codebase: stuffs a struct into a linker section with bad
> alignment and throws an exception
> * drop SUBALIGN and fix the sysinit issue: splinkersets01 fails, all
> other tests pass, code runs
> Paths forward:
> * disable splinkersets01 for AArch64/ILP32 BSPs
> * attempt to detect section alignment and adjust splinkersets01 as
> necessary
> * splitting the section up for different alignments would require
> touching every linker script
> Hopefully I’m just missing something.
I would remove the SUBALIGN() from the linker script. You can also add a
new test case for splinkersets01 similar to struct s from above. Then we
should check if the test fails on aarch64 and why it fails.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
