splinkersets01 test assumptions
Sebastian Huber
Wed Feb 17 15:45:33 UTC 2021
On 17/02/2021 16:32, Kinsey Moore wrote:
>> .section .rtemsroset.s.begin,"a"
>> .align 8
>> .type _Linker_set_s_begin, %object
>> .size _Linker_set_s_begin, 0
>> _Linker_set_s_begin:
>> .section .rtemsroset.s.end,"a"
>> .align 8
>> .type _Linker_set_s_end, %object
>> .size _Linker_set_s_end, 0
>> _Linker_set_s_end:
>> .ident "GCC: (GNU) 10.2.1 20210205 (RTEMS 6, RSB
>> 61dcadee0825867ebe51f9f367430ef75b8fe9c0, Newlib d4a756f)"
>>> <snip>
>> I would remove the SUBALIGN() from the linker script. You can also add a
>> new test case for splinkersets01 similar to struct s from above. Then we
>> should check if the test fails on aarch64 and why it fails.
> The example above actually shows the issue I'm having in _Linker_set_i_begin and _Linker_set_i_end. The alignment expands for the larger struct, but does not shrink for data types smaller than 8 bytes, leaving padding that the test interprets as additional space in the linker set.
I still don't see why a larger alignment is an issue. The begin/end
objects have a size of zero. Where do you observe a padding?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
