Coverity Reports on Passing NULL to fileno()
Wed Feb 17 18:21:31 UTC 2021
On 17/02/2021 18:58, Joel Sherrill wrote:
> I don't want to ignore calls to fileno() and other methods from RTEMS
> code that potentially could pass a NULL in. I only see a few options:
>   + Use an rtems_fileno() wrapper which does check for NULL. I don't
> like this because it opens a path of doing this for any libc method
> that takes a pointer.
> + Mark these as ignored in Coverity. I don't like this because it
> always feels like we could be papering over something.
> + Add an RTEMS assert() ahead of these suspect calls so at least debug
> mode flags them and Coverity is happier.
> + Add nonnull attribute to the headers for the various parameters in
> libc that shouldn't be null. I don't think this will catch all stupid
> cases of passing NULL but may be sufficient to catch some. I have no
> idea if this will make Coverity happy or not.
> I think aiming for the last two since they seem reasonable and
> straightforward.
The nonnull attribute could have unpleasant side effects:
http://www.rkoucha.fr/tech_corner/nonnull_gcc_attribute.html
I would place assertions in the code. This looks like a case by case
analysis is necessary.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
