[PATCH 06/13] rtems: Remove unused _Modes_Mask_changed()
Sebastian Huber
Wed Feb 17 19:30:21 UTC 2021
Update #4244.
cpukit/include/rtems/rtems/modesimpl.h | 14 --------------
1 file changed, 14 deletions(-)
diff --git a/cpukit/include/rtems/rtems/modesimpl.h b/cpukit/include/rtems/rtems/modesimpl.h
index 5a147b10b9..db98cb419f 100644
--- a/cpukit/include/rtems/rtems/modesimpl.h
+++ b/cpukit/include/rtems/rtems/modesimpl.h
@@ -35,20 +35,6 @@ extern "C" {
- * @brief Checks if any of the mode flags in mask are set in mode_set.
- * This function returns TRUE if any of the mode flags in mask
- * are set in mode_set, and FALSE otherwise.
-RTEMS_INLINE_ROUTINE bool _Modes_Mask_changed (
- rtems_mode mode_set,
- rtems_mode masks
- return ( mode_set & masks ) ? true : false;
* @brief Checks if mode_set says that Asynchronous Signal Processing is disabled.
2.26.2
