Device Drivers Which Include mkdir("/dev")
Gedare Bloom
gedare at rtems.org
Thu Feb 18 17:51:57 UTC 2021
On Thu, Feb 18, 2021 at 10:20 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Feb 18, 2021 at 11:06 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Feb 18, 2021 at 8:56 AM Joel Sherrill <joel at rtems.org> wrote:
>> > Hi
>> > There are a lot of Coverity issues related to device drivers which call mkdir("/dev") and ignore the return value. My first thought was that they should have (void) added since /dev could have been created by an earlier driver.
>> > Then it occurred to me that libcsupport/src/base_fs.c includes mkdir("/dev") and a fatal error if it cannot create it.
>> > Doesn't this mean that every call to mkdir("/dev") in a BSP or device driver is redundant? They should be removed since the base FS contents are always in place before any device drivers are called.
>> > Thoughts?
>> Seems reasonable. You could probably add an assert that /dev exists.
> The creation of the device node will fail if /dev does not exist so I think that
> is covered.
> I think the call is pointless and changing it to stat() to make sure it exists
> just adds bulk to the driver/BSP dependencies.
> I think just deleting it seems prudent. There is an error path if it doesn't
> exist.
ok. I was just suggesting conversion to an assert since that is some
good practice when you have a belief/assumption but aren't totally
convinced. It's fine with me either way. assert(mkdir("/dev") == -1)
or just delete it.
> --joel
>> > --joel
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
