[PATCH] STM32H7 doc update
Gedare Bloom
gedare at rtems.org
Thu Feb 18 20:00:12 UTC 2021
On Wed, Jan 13, 2021 at 5:28 PM Robin Mueller <robin.mueller.m at gmail.com> wrote:
> Added doc for board variation, added some fixes
> from code review. (typo and line width formatting)
> user/bsps/arm/stm32h7.rst | 18 +++++++++++++++++-
> 1 file changed, 17 insertions(+), 1 deletion(-)
> diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
> index 3eee511..e1b9d8c 100644
> --- a/user/bsps/arm/stm32h7.rst
> +++ b/user/bsps/arm/stm32h7.rst
> @@ -11,16 +11,32 @@ This BSP supports the
> The BSP is known to run on these boards:
> * `STM32H743I-EVAL 2 <https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_
> +* `STM32H743ZI-Nucleo <https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_
> Clock Driver
> -The clock driver uses the `ARMv7-M Systick` module.
> +The clock driver uses the `ARMv7-M Systick` module. The HSE (external
> +oscillator) value can also be different for different evaluation or custom
> +boards, so it is recommended to check the default values of the BSP.
> Console Driver
> The console driver supports the on-chip UART and USART modules.
> +Different board variations use different GPIO pins and blocks for the default
> +communication UART and it is recommended to check whether the default
> +configuration provided is valid in the BSP.
> +To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
> +users can supply ``STM32H743ZI_NUCLEO == True`` to ``config.ini`` when
Should this be one equal sign?
> +building the BSP.
> +Alternatively, users can supply the configuration structs defined in ``hal.h``
> +in the applicaton for other boards. For the console driver, the
> +``stm32h7_usartX_config`` structs are used to configure the GPIO pins and other
> +parameters. The default implementations can be found in
> +``bsps/arm/stm32ht/console`` in the RTEMS sources.
> Network Interface Driver
> 2.23.0.windows.1
> devel mailing list
> devel at rtems.org
