[PATCH 05/13] posix: Remove superfluous check
Fri Feb 19 06:55:56 UTC 2021
On 18/02/2021 20:25, Joel Sherrill wrote:
>     > -   * api may be NULL in case of a thread close in progress
>     > -  if ( !api )
>     > -    return;
>     I believe you, but should we replace this with an assert for now?
> And a comment explaining why it can't be NULL.
This is not the only place which uses
api = executing->API_Extensions[ THREAD_API_POSIX ];
or
api = executing->API_Extensions[ THREAD_API_RTEMS ];
I don't think it makes sense to add a comment to all these places.
While looking at this, I think we should remove this API_Extensions
indirection and add the structures directly to Thread_Control. This
makes the code more efficient, simpler, faster, and easier to debug.
We just have to move a couple of typedefs to score to define these
structures in thread.h.
#if defined(RTEMS_POSIX_API)
  * This defines the POSIX API support structure associated with
  * each thread in a system with POSIX configured.
typedef struct {
    * @brief Control block for the sporadic server scheduling policy.
   struct {
     /** The thread of this sporadic control block */
     Thread_Control *thread;
      * @brief This is the timer which controls when the thread executes
at high
      * and low priority when using the sporadic server scheduling policy.
     Watchdog_Control Timer;
      * @brief The low priority when using the sporadic server scheduling
      * policy.
     Priority_Node Low_priority;
      * @brief Replenishment period for sporadic server.
     struct timespec sched_ss_repl_period;
      * @brief Initial budget for sporadic server.
     struct timespec sched_ss_init_budget;
      * @brief Maximum pending replenishments.
      * Only used by pthread_getschedparam() and pthread_getattr_np().
     int sched_ss_max_repl;
   } Sporadic;
   /** This is the set of signals which are currently unblocked. */
   sigset_t                signals_unblocked;
   /** This is the set of signals which are currently pending. */
   sigset_t                signals_pending;
    * @brief Signal post-switch action in case signals are pending.
   Thread_Action           Signal_action;
} POSIX_API_Control;
  *  This is the API specific information required by each thread for
  *  the RTEMS API to function correctly.
typedef struct {
   /** This field contains the event control for this task. */
   Event_Control            Event;
   /** This field contains the system event control for this task. */
   Event_Control            System_event;
   /** This field contains the Classic API Signal information for this
task. */
   ASR_Information          Signal;
}  RTEMS_API_Control;
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
