[PATCH v1 1/2] score: Enforce stack_end alignment
Fri Feb 19 07:07:43 UTC 2021
On 19/02/2021 07:12, Sebastian Huber wrote:
> On 18/02/2021 19:59, Kinsey Moore wrote:
>> The size of the reserved TLS space is not guaranteed to adhere to stack
>> alignment requirements which can cause stack_end to become misaligned.
>> This enforces the alignment of stack_end.
>>   cpukit/score/src/threadinitialize.c | 4 ++++
>>   1 file changed, 4 insertions(+)
>> diff --git a/cpukit/score/src/threadinitialize.c
>> b/cpukit/score/src/threadinitialize.c
>> index 05c30c3d43..ad5dccbbb2 100644
>> --- a/cpukit/score/src/threadinitialize.c
>> +++ b/cpukit/score/src/threadinitialize.c
>> @@ -108,6 +108,10 @@ bool _Thread_Initialize(
>>         ( ( (uintptr_t) stack_end + tls_align - 1 ) & ~( tls_align -
>> 1 ) );
>>   +  /* Enforce stack alignment */
>> +  stack_end = (char *)((uintptr_t) stack_end &
>> +    ~( (uintptr_t) CPU_STACK_ALIGNMENT - 1 ));
>>     _Stack_Initialize(
>>       &the_thread->Start.Initial_stack,
>>       stack_begin,
> I think the bug is in _TLS_Get_allocation_size(). It assumes
> CPU_HEAP_ALIGNMENT >= CPU_STACK_ALIGNMENT. It should probably use the
> maximum of these two values.
There is also an issue in the stack allocation, for example
static rtems_status_code _RTEMS_tasks_Allocate_and_prepare_stack(
   Thread_Configuration    *thread_config,
   const rtems_task_config *config
   size_t size;
   thread_config->stack_free = _Stack_Free;
   size = _Stack_Ensure_minimum( config->storage_size );
   size = _Stack_Extend_size( size, thread_config->is_fp );
   thread_config->stack_size = size;
   thread_config->stack_area = _Stack_Allocate( size );
   if ( thread_config->stack_area == NULL ) {
     return RTEMS_UNSATISFIED;
   return RTEMS_SUCCESSFUL;
and
/* Generated from spec:/rtems/task/if/storage-alignment */
  * @ingroup RTEMSAPIClassicTasks
  * @brief This constant defines the recommended alignment of a task storage
  *   area in bytes.
  * @par Notes
  * Use it with RTEMS_ALIGNED() to define the alignment of a statically
  * allocated task storage area.
#define RTEMS_TASK_STORAGE_ALIGNMENT CPU_HEAP_ALIGNMENT
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
