[PATCH v2 0/4] Avoid potential recursion in ASR handling
Sebastian Huber
Fri Feb 19 09:40:34 UTC 2021
This patch set fixes a potential issue with a recursion in the ASR
handling. The main issue is that _Signal_Action_handler() used
rtems_task_mode() to save, set, and restore the task mode during ASR
processing. This is effectively a recursive call to thread dispatching
which may result in the next level of ASR processing.
v2:
Address review comments.
Sebastian Huber (4):
rtems: Remove _Modes_Set_interrupt_level()
rtems: New errors for rtems_signal_catch()
rtems: Add _Modes_Apply_timeslice_to_thread()
rtems: Avoid potential recursion in ASR handling
cpukit/include/rtems/rtems/modesimpl.h | 67 ++++++++++++++++--
cpukit/rtems/src/signalcatch.c | 15 ++++
cpukit/rtems/src/signalsend.c | 98 ++++++++++++++++++++++++--
cpukit/rtems/src/taskmode.c | 25 ++-----
4 files changed, 174 insertions(+), 31 deletions(-)
2.26.2
