[PATCH v2 2/4] rtems: New errors for rtems_signal_catch()
Fri Feb 19 17:15:27 UTC 2021
On Fri, Feb 19, 2021 at 2:40 AM Sebastian Huber
> Ensure that no invalid modes are set during ASR processing.
> Update #4244.
>  cpukit/include/rtems/rtems/modesimpl.h | 48 ++++++++++++++++++++++++++
>  cpukit/rtems/src/signalcatch.c         | 15 ++++++++
>  cpukit/rtems/src/taskmode.c            | 14 +++-----
>  3 files changed, 67 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/modesimpl.h b/cpukit/include/rtems/rtems/modesimpl.h
> index 2b5e00f600..fe7f5e5721 100644
> --- a/cpukit/include/rtems/rtems/modesimpl.h
> +++ b/cpukit/include/rtems/rtems/modesimpl.h
> @@ -19,6 +19,9 @@
>  #define _RTEMS_RTEMS_MODESIMPL_H
>  #include <rtems/rtems/modes.h>
> +#include <rtems/score/schedulerimpl.h>
> +#include <rtems/score/smpimpl.h>
> +#include <rtems/score/threadimpl.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -85,6 +88,51 @@ RTEMS_INLINE_ROUTINE ISR_Level _Modes_Get_interrupt_level (
>    return ( mode_set & RTEMS_INTERRUPT_MASK );
> +#if defined(RTEMS_SMP) || CPU_ENABLE_ROBUST_THREAD_DISPATCH == TRUE
> + * @brief Checks if support for the interrupt level is implemented.
implemented by whom?
> + * @param mode_set is the most set which specifies the interrupt level to
> + *   check.
> + * @return Returns true, if support for the interrupt level is implemented,
> + *   otherwise returns false.
> +RTEMS_INLINE_ROUTINE bool _Modes_Is_interrupt_level_implemented(
Sorry, processing my email out of order, so some comments duplicated.
I think supported is better than implemented
> +  rtems_mode mode_set
> +  return _Modes_Get_interrupt_level( mode_set ) == 0
> +#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
> +    || !_SMP_Need_inter_processor_interrupts()
> +#endif
> +#endif
> + * @brief Checks if support for the preempt mode is implemented.
add "requested" before preempt, and "by the scheduler" to end of this sentence
> + * @param mode_set is the most set which specifies the preempt mode to check.
> + * @param the_thread is the thread to check.
> + * @return Returns true, if support for the preempt mode is implemented,
> +RTEMS_INLINE_ROUTINE bool _Modes_Is_preempt_mode_implemented(
> +  rtems_mode            mode_set,
> +  const Thread_Control *the_thread
> +  return _Modes_Is_preempt( mode_set ) ||
> +    _Scheduler_Is_non_preempt_mode_supported(
> +      _Thread_Scheduler_get_home( the_thread )
Possibly note somewhere that we always assume schedulers support
preemption. It probably goes without saying, but might help novices
who come across this code.
> +#endif
>  #ifdef __cplusplus
>  #endif
> diff --git a/cpukit/rtems/src/signalcatch.c b/cpukit/rtems/src/signalcatch.c
> index 8ee22e5ec1..55dc7de667 100644
> --- a/cpukit/rtems/src/signalcatch.c
> +++ b/cpukit/rtems/src/signalcatch.c
> @@ -22,6 +22,7 @@
>  #endif
>  #include <rtems/rtems/signalimpl.h>
> +#include <rtems/rtems/modesimpl.h>
>  #include <rtems/rtems/tasksdata.h>
> @@ -37,7 +38,21 @@ rtems_status_code rtems_signal_catch(
>    ASR_Information    *asr;
>    ISR_lock_Context    lock_context;
> +  if ( !_Modes_Is_interrupt_level_implemented( mode_set ) ) {
> +    return RTEMS_NOT_IMPLEMENTED;
> +#endif
>    executing = _Thread_State_acquire_for_executing( &lock_context );
> +  if ( !_Modes_Is_preempt_mode_implemented( mode_set, executing ) ) {
> +    _Thread_State_release( executing, &lock_context );
> +#endif
>    api = executing->API_Extensions[ THREAD_API_RTEMS ];
>    asr = &api->Signal;
>    asr->handler = asr_handler;
> diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
> index 77338723b8..1275576968 100644
> --- a/cpukit/rtems/src/taskmode.c
> +++ b/cpukit/rtems/src/taskmode.c
> @@ -50,11 +50,8 @@ rtems_status_code rtems_task_mode(
>    if (
> -    ( mask & RTEMS_PREEMPT_MASK ) != 0
> -      && !_Modes_Is_preempt( mode_set )
> -      && !_Scheduler_Is_non_preempt_mode_supported(
> -        _Thread_Scheduler_get_home( executing )
> +    ( mask & RTEMS_PREEMPT_MASK ) != 0 &&
> +    !_Modes_Is_preempt_mode_implemented( mode_set, executing )
> @@ -62,11 +59,8 @@ rtems_status_code rtems_task_mode(
>    if (
> -    ( mask & RTEMS_INTERRUPT_MASK ) != 0
> -      && _Modes_Get_interrupt_level( mode_set ) != 0
> -#if CPU_ENABLE_ROBUST_THREAD_DISPATCH == FALSE
> -      && _SMP_Need_inter_processor_interrupts()
> -#endif
> +    ( mask & RTEMS_INTERRUPT_MASK ) != 0 &&
> +    !_Modes_Is_interrupt_level_implemented( mode_set )
> 2.26.2
> devel mailing list
> devel at rtems.org
