Device Drivers Which Include mkdir("/dev")
Gedare Bloom
gedare at rtems.org
Sat Feb 20 18:29:47 UTC 2021
On Fri, Feb 19, 2021 at 5:26 PM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Feb 19, 2021, 5:32 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 20/2/21 7:56 am, Joel Sherrill wrote:
>> > On Fri, Feb 19, 2021 at 2:51 PM Gedare Bloom <gedare at rtems.org
>> > <mailto:gedare at rtems.org>> wrote:
>> > I think the suggestion is to provide a catch-all rather than try to add new
>> > faults for every possible condition. This mkdir is a pretty esoteric fault
>> > that is unlikely to happen in properly developed code.
>> > Then why shouldn't this just be a debug _Assert and value not check deliberately?
>> Will the call ever fail in production? Could a user configure RTEMS in a manner
>> that generates the failure?
>> > Isn't an assert something that should not happen in a properly designed BSP. In
>> > this case, it would be the sysinit magic that would be utterly broken.
>> I would not step out as far as utterly broken but yes I see your point. There
>> are other places where we have taken this approach.
>> If the lack of making a directory in GRLIB is handled by errors in the other
>> dependent calls then why not add some documentation to the BSP.
> Confirmation appreciated but it is making the directory to out a device node. The device node create will fail if there isn't a directory so this will return an error.
> https://git.rtems.org/rtems/tree/bsps/shared/grlib/pci/gr_rasta_io.c#n577
> Which means an assert is ok
I think an assert that /dev exists is fine within device drivers that
want to create device nodes on /dev. It's not their responsibility to
create the /dev tree, right?
>> Chris
