[PATCH rtems-docs] user/bsps: Mention fixed console baud rate for zynq
Chris Johns
chrisj at rtems.org
Sat Feb 20 22:57:05 UTC 2021
On 20/2/21 3:59 am, Gedare Bloom wrote:
> On Fri, Feb 19, 2021 at 1:21 AM Jan Sommer <jan.sommer at dlr.de> wrote:
>> user/bsps/arm/xilinx-zynq.rst | 14 ++++++++++++++
>> 1 file changed, 14 insertions(+)
>> diff --git a/user/bsps/arm/xilinx-zynq.rst b/user/bsps/arm/xilinx-zynq.rst
>> index 365c336..dcc0649 100644
>> --- a/user/bsps/arm/xilinx-zynq.rst
>> +++ b/user/bsps/arm/xilinx-zynq.rst
>> @@ -37,6 +37,20 @@ to return the peripheral clock. Normally this is half the CPU
>> clock. This function is declared ``weak`` so you can override the
>> default behaviour by providing it in your application.
>> +Console
>> +The console driver for the UARTs will always be set to a baud rate
>> +of 115200 with 8 bit characters, 1 stop bit and no parity bits
>> +during start up.
>> +Previous configurations programmed into the hardware by the Xilinx
>> +tools or a bootloader will be overwritten.
>> +The settings for parity and stop bits can be changes by the user
>> +application. The baud rate is hard coded to 115200 and can not be
>> +changed.
> Only 1 blank line here please. Chris to approve the content, I think
> he has the most to say on this topic :)
It is OK for master because it is what we have. Joel and I have been discussing
the issue of the hardcoded baudrate and the issues it presents. If we decide
something needs to change this documentation can change.
The issue is there are 2 UARTs on the zync and if one is used for the console
the fixed rate is fine however if one is used for another purpose not being able
to set the baudrate is a bug in RTEMS.
