[PATCH v1 1/1] bsps/shared: Allow setting baud rate for zynq uart
Jan Sommer
jan.sommer at dlr.de
Mon Feb 22 15:43:37 UTC 2021
bsps/shared/dev/serial/zynq-uart.c | 42 +++++++++++++++++++++++++++---
1 file changed, 39 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 8f17d3ca65..124f9e032d 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -144,14 +144,50 @@ static bool zynq_uart_set_attributes(
zynq_uart_context *ctx = (zynq_uart_context *) context;
volatile zynq_uart *regs = ctx->regs;
+ int32_t baud;
uint32_t brgr = 0;
uint32_t bauddiv = 0;
uint32_t mode = 0;
int rc;
- rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
- if (rc != 0)
- return rc;
+ * Determine the baud rate
+ switch (term->c_ospeed) {
+ case B0: baud = 0; break;
+ case B50: baud = 50; break;
+ case B75: baud = 75; break;
+ case B110: baud = 110; break;
+ case B134: baud = 134; break;
+ case B150: baud = 150; break;
+ case B200: baud = 200; break;
+ case B300: baud = 300; break;
+ case B600: baud = 600; break;
+ case B1200: baud = 1200; break;
+ case B1800: baud = 1800; break;
+ case B2400: baud = 2400; break;
+ case B4800: baud = 4800; break;
+ case B9600: baud = 9600; break;
+ case B19200: baud = 19200; break;
+ case B38400: baud = 38400; break;
+ case B57600: baud = 57600; break;
+ case B115200: baud = 115200; break;
+ case B230400: baud = 230400; break;
+ case B460800: baud = 460800; break;
+ case B921600: baud = 921600; break;
+ default: baud = -1; break;
+ if (baud < 0) {
+ errno = EINVAL;
+ return -1;
+ if (baud > 0) {
+ rc = zynq_cal_baud_rate(baud, &brgr, &bauddiv, regs->mode);
+ if (rc != 0)
+ return rc;
* Configure the mode register
2.17.1
