[PATCH v2 1/1] bsps/shared: Allow setting baud rate for zynq uart
Jan Sommer jan.sommer at dlr.de
Mon Feb 22 16:23:16 UTC 2021
 bsps/shared/dev/serial/zynq-uart.c | 14 +++++++++++---
 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 8f17d3ca65..dd5a6e1cb8 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -144,14 +144,22 @@ static bool zynq_uart_set_attributes(
   zynq_uart_context *ctx = (zynq_uart_context *) context;
   volatile zynq_uart *regs = ctx->regs;
+  int32_t baud;
   uint32_t brgr = 0;
   uint32_t bauddiv = 0;
   uint32_t mode = 0;
   int rc;
-  rc = zynq_cal_baud_rate(115200, &brgr, &bauddiv, regs->mode);
-  if (rc != 0)
-    return rc;
+   * Determine the baud rate
+  baud = rtems_termios_baud_to_number(term->c_ospeed);
+  if (baud > 0) {
+    rc = zynq_cal_baud_rate(baud, &brgr, &bauddiv, regs->mode);
+    if (rc != 0)
+      return rc;
    * Configure the mode register
2.17.1
