How do we know what priority of the Init task is?
Heinz Junkes
junkes at fhi-berlin.mpg.de
Tue Feb 23 07:36:03 UTC 2021
I would have a similar question ;-)
What is the priority of the POSIX_Init - Task (as Posix-Prio)?
Danke Heinz
> On 23. Feb 2021, at 06:43, Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> Just confirming, The initial priority is 1, and when converted to _RTEMS_Priority_To_core, it becomes 2 (because of the append indicator added by default map priority). Right?
> On Tue, Nov 17, 2020 at 11:19 PM Richi Dubey <richidubey at gmail.com> wrote:
> Awesome, thanks!
> On Tue, Nov 17, 2020 at 9:53 PM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Nov 17, 2020, 9:50 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> Sometimes the priority of the Init task is not mentioned in the source code of the test suites of the headers files included in it (ex. see tm24). Can someone please let me know how we can understand what the priority of the Init task is? Is there a constant value for Init's priority when it's not explicitly mentioned?
> Yes. It defaults to 1. This is defaulted in one of the confdef subfiles now and documented in the configuring a system chapter if the Classic API Guide
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210223/73d458f4/attachment.bin>
