[PATCH 06/10] rtems: Add rtems_get_target_hash()
Wed Feb 24 13:57:26 UTC 2021
Update #4267.
 cpukit/include/rtems/config.h | 33 +++++++++++++++++++++++++++++++++
 1 file changed, 33 insertions(+)
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 969a2fddb8..1c35417970 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -384,6 +384,39 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
 uintptr_t rtems_configuration_get_stack_space_size( void );
+/* Generated from spec:/rtems/config/if/get-target-hash */
+ * @ingroup RTEMSAPIConfig
+ * @brief Gets the RTEMS target hash.
+ * The target hash is calculated from BSP-specific values which characterize a
+ * target system.
+ * @return Returns the pointer to the RTEMS target hash.
+ * @par Notes
+ * @parblock
+ * For example, the device tree, settings of the memory controller, processor
+ * and bus frequencies, a serial number of a chip may be used to calculate the
+ * target hash.
+ * The target hash can be used to distinguish test suite results obtained from
+ * different target systems.
+ * @endparblock
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within any runtime context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+const char *rtems_get_target_hash( void );
 /* Generated from spec:/rtems/config/if/get-ticks-per-timeslice */
2.26.2
