[PATCH 05/10] score: Add Hash Handler
Wed Feb 24 13:57:25 UTC 2021
Update #4267.
 cpukit/include/rtems/score/hash.h | 168 ++++++++++++++++++++++++++++++
 cpukit/score/src/hash.c           |  76 ++++++++++++++
 spec/build/cpukit/librtemscpu.yml |   1 +
 3 files changed, 245 insertions(+)
 create mode 100644 cpukit/include/rtems/score/hash.h
 create mode 100644 cpukit/score/src/hash.c
diff --git a/cpukit/include/rtems/score/hash.h b/cpukit/include/rtems/score/hash.h
new file mode 100644
index 0000000000..8a269cc548
--- /dev/null
+++ b/cpukit/include/rtems/score/hash.h
@@ -0,0 +1,168 @@
+ * @file
+ * @ingroup RTEMSScoreHash
+ * @brief This header file provides the interfaces of the
+ *   @ref RTEMSScoreHash.
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef _RTEMS_SCORE_HASH_H
+#define _RTEMS_SCORE_HASH_H
+#include <rtems/score/basedefs.h>
+#include <sha256.h>
+#include <string.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSScoreHash Hash Handler
+ * @brief This group contains the Hash Handler implementation.
+ * @brief This constant represents the size of a hash string.
+ * Accounts for a NUL termination of the hash string.
+#define HASH_CONTROL_STRING_SIZE 45
+ * @brief This type represents a hash value.
+ * The hash value is produced by _Hash_Finalize().
+typedef struct {
+   * @brief This member contains the hash value encoded as a base64url string.
+   * The string is NUL-terminated.
+  char chars[ HASH_CONTROL_STRING_SIZE ];
+} Hash_Control;
+ * @brief Gets the hash value as a NUL-terminated string.
+ * @param hash is the hash value.
+ * @return Returns the hash value as a NUL-terminated string.
+RTEMS_INLINE_ROUTINE const char *_Hash_Get_string( const Hash_Control *hash )
+  return &hash->chars[ 0 ];
+ * @brief This type represents the context to compute a hash value.
+typedef struct {
+   * @brief This member contains the hash algorithm context.
+  SHA256_CTX Context;
+   * @brief This member references a hash value if needed.
+  Hash_Control *hash;
+   * @brief This member contains an index into the hash value bytes if needed.
+  size_t index;
+} Hash_Context;
+ * @brief Initializes the hash context.
+ * @param[out] context is the hash context to initialize.
+RTEMS_INLINE_ROUTINE void _Hash_Initialize( Hash_Context *context )
+  SHA256_Init( &context->Context );
+ * @brief Adds the data to the hash value.
+ * @param[in, out] context is the hash context.
+ * @param begin is the begin address of the data to add.
+ * @param size is the size of the data in bytes.
+RTEMS_INLINE_ROUTINE void _Hash_Add_data(
+  Hash_Context *context,
+  const void   *begin,
+  size_t        size
+  SHA256_Update( &context->Context, begin, size );
+ * @brief Adds the string to the hash value.
+ * @param str is the string to add.
+RTEMS_INLINE_ROUTINE void _Hash_Add_string(
+  const char   *str
+  SHA256_Update( &context->Context, str, strlen( str ) );
+ * @brief Finalizes the hash value computation and produces the hash value.
+ * @param[out] hash is the hash control to store the produced hash value.
+void _Hash_Finalize( Hash_Context *context, Hash_Control *hash );
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_HASH_H */
diff --git a/cpukit/score/src/hash.c b/cpukit/score/src/hash.c
index 0000000000..42ea7f0582
--- /dev/null
+++ b/cpukit/score/src/hash.c
@@ -0,0 +1,76 @@
+ * @file
+ * @brief This source file the implementation of _Hash_Finalize().
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/hash.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/io.h>
+#include <limits.h>
+static void _Hash_Put_char( int c, void *arg )
+  Hash_Context *context;
+  size_t        index;
+  context = arg;
+  index = context->index;
+  _Assert( index < sizeof( context->hash->chars ) );
+  context->hash->chars[ context->index ] = (char) c;
+  context->index = index + 1;
+  unsigned char digest[ 32 ];
+  int           n;
+  SHA256_Final( digest, &context->Context );
+  context->hash = hash;
+  context->index = 0;
+  hash->chars[ sizeof( *hash ) - 1 ] = '\0';
+  n = _IO_Base64url(
+    _Hash_Put_char,
+    context,
+    digest,
+    sizeof( digest ),
+    NULL,
+    INT_MAX
+  _Assert_Unused_variable_equals( n, sizeof( *hash ) - 1 );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index c79d046af1..0eac92906c 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1399,6 +1399,7 @@ source:
 - cpukit/score/src/debugisthreaddispatchingallowed.c
 - cpukit/score/src/freechain.c
 - cpukit/score/src/futex.c
+- cpukit/score/src/hash.c
 - cpukit/score/src/heap.c
 - cpukit/score/src/heapallocate.c
 - cpukit/score/src/heapextend.c
2.26.2
