[PATCH v2] tests/validation: Fix 64bit test failure
Wed Feb 24 16:54:32 UTC 2021
On Wed, Feb 24, 2021 at 2:52 AM Sebastian Huber
> On 16/02/2021 06:51, Sebastian Huber wrote:
> > The issue can be fixed in two ways.
> > 1. We change the API, so that the error condition can happen also on
> > 64-bit architectures (current patch).
> > 2. We change the specification and implementation, so that this error
> > condition is removed on 64-bit architectures. In the implementation,
> > this is easy. In the specification, this is a bit more difficult since
> > I would have to introduce a new option which enables or disables parts
> > of the specification based on the word size of the architecture
> > (similar to RTEMS_SMP). This is the main reason why I didn't fix the
> > issue immediately
> How do we want to address this issue? Change the API or the
> specification, etc.?
I'd lean toward 1, except without digging in the details I think the
proposed patch is wrong to use size_t, and the implementation check of
SIZE_MAX. We shouldn't use size_t for a counting variable, that is
wrong. size_t has an implied type of number of bytes. The check should
be against UINT32_MAX if the variable type is uint32_t.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
