[PATCH v2] tests/validation: Fix 64bit test failure
Wed Feb 24 17:30:16 UTC 2021
On Wed, Feb 24, 2021 at 9:58 AM Sebastian Huber
> On 24/02/2021 17:54, Gedare Bloom wrote:
> > On Wed, Feb 24, 2021 at 2:52 AM Sebastian Huber
> >> On 16/02/2021 06:51, Sebastian Huber wrote:
> >>> The issue can be fixed in two ways.
> >>> 1. We change the API, so that the error condition can happen also on
> >>> 64-bit architectures (current patch).
> >>> 2. We change the specification and implementation, so that this error
> >>> condition is removed on 64-bit architectures. In the implementation,
> >>> this is easy. In the specification, this is a bit more difficult since
> >>> I would have to introduce a new option which enables or disables parts
> >>> of the specification based on the word size of the architecture
> >>> (similar to RTEMS_SMP). This is the main reason why I didn't fix the
> >>> issue immediately
> >> How do we want to address this issue? Change the API or the
> >> specification, etc.?
> > I'd lean toward 1, except without digging in the details I think the
> > proposed patch is wrong to use size_t, and the implementation check of
> > SIZE_MAX. We shouldn't use size_t for a counting variable, that is
> > wrong. size_t has an implied type of number of bytes. The check should
> > be against UINT32_MAX if the variable type is uint32_t.
> This is exactly the problem. Internally, this uint32_t variable is used
> to compute the allocation size in size_t, which is uint64_t on 64-bit
> architectures and an overflow cannot happen.
These limits are ridiculous, even on a 32-bit machine no one is going
to be allocated a 4 GiB message.
We should consider specifying the API more tightly. The maximum
message sizes are currently only constrained by the Workspace Size or
(for Global) the MPCI message limits. Maybe we should make the
maximum_pending_messages as uint16_t or even uint8_t, then the
overflow can't happen on 32-bit machine either.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
