[PATCH 00/10] Add build and target hash for test results
Wed Feb 24 18:49:32 UTC 2021
On Wed, Feb 24, 2021 at 11:36 AM Sebastian Huber
> On 24/02/2021 19:22, Gedare Bloom wrote:
> > On Wed, Feb 24, 2021 at 6:57 AM Sebastian Huber
> >> This patch set adds the new directives rtems_get_build_hash() and
> >> rtems_get_target_hash() which can be used to differentiate test suite
> >> results.  See also the following discussion:
> >> https://lists.rtems.org/pipermail/devel/2020-November/063226.html
> >> Sebastian Huber (10):
> >>    build: Generate build hash
> >>    rtems: Add rtems_get_build_hash()
> >>    libtest: Report build hash
> >>    score: Add _IO_Base64url()
> >>    score: Add Hash Handler
> >>    rtems: Add rtems_get_target_hash()
> >>    Add system initialization step for target hash
> >>    bsps: Add default rtems_get_target_hash()
> >>    libtest: Report target hash
> >>    libtest: Print SHA256 hash in base64url
> > Is there a good reason to use SHA256 over a lighter weight algorithm?
> > I guess I wonder about the overhead and value of using it.
> > We don't need cryptographic security here, we just need a reasonably
> > non-colliding checksum. The speed of hashing will matter for running
> > testsuites.
> SHA256 is currently the best algorithm for 32-bit targets we have in the
> RTEMS sources. It is also selected for the next Git hash. I don't think
> the time to calculate the hash really matters and I want to avoid any
> discussions if MD5 is sufficient or not.
OK, from a code existence argument this is fine. I could even see a
possibility to fold in the source code hashes in the future to make a
"secure" checksum that can be verified at boot-time.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
