[PATCH 2/2] This adds a way to print the host triplet
Wed Feb 24 19:57:31 UTC 2021
Is there  a patch 1/2?
On Wed, Feb 24, 2021 at 11:23 AM Robin Mueller
<robin.mueller.m at gmail.com> wrote:
> Can be useful for cross-compiling toolchains
>  source-builder/sb/setbuilder.py | 14 +++++++++++++-
>  1 file changed, 13 insertions(+), 1 deletion(-)
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index b0e2b23..e480ad5 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> @@ -673,6 +673,16 @@ def list_bset_cfg_files(opts, configs):
>          return True
>      return False
> +def list_host(opts):
> +    if opts.get_arg('--list-host'):
> +        print('Displaying host operating system information: ')
> +        print('Operating system: %s' % macro_expand(opts.defaults, '%{_os}'))
> +        print('Number of processors: %s' % macro_expand(opts.defaults, '%{_ncpus}'))
> +        print('Build architecture: %s' % macro_expand(opts.defaults, '%{_host_arch}'))
> +        print('Host triplet: %s' % macro_expand(opts.defaults, '%{_host}'))
> +        return True
> +    return False
>  def run():
>      import sys
>      ec = 0
> @@ -683,6 +693,7 @@ def run():
>                      '--list-bsets':    'List available build sets',
>                      '--list-configs':  'List available configuration files.',
>                      '--list-deps':     'List the dependent files.',
> +                    '--list-host':     'List host information and the host triplet.',
>                      '--bset-tar-file': 'Create a build set tar file',
>                      '--pkg-tar-files': 'Create package tar files',
>                      '--no-report':     'Do not create a package report.',
> @@ -718,7 +729,8 @@ def run():
>              deps = []
>          else:
>              deps = None
> -        if not list_bset_cfg_files(opts, configs):
> +        if not list_bset_cfg_files(opts, configs) and not list_host(opts):
>              prefix = macro_expand(opts.defaults, '%{_prefix}')
>              if opts.canadian_cross():
>                  opts.disable_install()
> 2.23.0.windows.1
> devel mailing list
> devel at rtems.org
