[5 PATCH] powerpc/motorola_power: Link all text sections into the executable image
Chris Johns
chrisj at rtems.org
Wed Feb 24 21:36:47 UTC 2021
On 25/2/21 3:33 am, Gedare Bloom wrote:
> On Tue, Feb 23, 2021 at 11:07 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> - The change to building all code with code and data sections means
>> we have a section per function. Make sure all functions are
>> placed in the text section.
>> Closes #4266
>> bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds | 2 +-
>> 1 file changed, 1 insertion(+), 1 deletion(-)
>> diff --git a/bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds b/bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds
>> index 0ee7447546..a87a07cfd7 100644
>> --- a/bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds
>> +++ b/bsps/powerpc/motorola_powerpc/bootloader/ppcboot.lds
>> @@ -38,6 +38,7 @@ SECTIONS
>> BYTE(0x75); BYTE(0x78); /* Partition name */
>> . = 0x400;
>> *(.text)
>> + *(.text*)
> Minor point, it should be sufficient to just have *(.text*) no need
> then for (*.text)
Yes and it does work as this was my first change then I wondered if the .text
parts in bootloader.o should be placed before the others as it is in the version
without the extra compile options so I made the script have the second step. The
change here makes this happen.
Also the read only sections below have this so it is consistent.
>> *(.sdata2)
>> *(.rodata)
>> *(.rodata*)
>> @@ -98,4 +99,3 @@ SECTIONS
>> *(.comment)
>> 2.24.1
>> devel mailing list
>> devel at rtems.org
