About Chains in RTEMS
    Richi Dubey
    richidubey at gmail.com
    Thu Feb 25 09:47:15 UTC 2021
Hi,
When I am debugging the call to _Chain_Append_unprotected (from line 92
<https://git.rtems.org/rtems/tree/testsuites/sptests/sp02/init.c#n92> of
sp02, rtems_task_delete -> _Thread_Close ->...->_Thread_Cancel -> ...
->_Scheduler_Unblock -> ... _Scheduler_strong_APA_Insert_ready
-> _Chain_Append_unprotected), I see a weird chain behavior where there's
some kind of cycle:
(gdb) p _Chain_Tail(the_chain)
$20 = (Chain_Node *) 0x200768 <_Configuration_Scheduler_strong_APA_dflt+40>
(gdb) p _Chain_Tail(the_chain)->previous
$21 = (Chain_Node *) 0x2014e8 <_RTEMS_tasks_Objects+2024>
(gdb) p (_Chain_Tail(the_chain)->previous)->previous
$22 = (Chain_Node *) 0x200fe0 <_RTEMS_tasks_Objects+736>
(gdb) p ((_Chain_Tail(the_chain)->previous)->previous)->previous
$23 = (Chain_Node *) 0x2014e8 <_RTEMS_tasks_Objects+2024>
(gdb) p
(((_Chain_Tail(the_chain)->previous)->previous)->previous)->previous
$24 = (Chain_Node *) 0x200fe0 <_RTEMS_tasks_Objects+736>
sp02 is a single processor test and I am trying to run it on the Strong APA
SMP scheduler. Can someone please give an insight into what might be
causing this? The Strong APA scheduler does not affect the functioning of
the chain, it only uses the chain using standard function headers defined
in chain.h
Thanks,
Richi.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210225/b05b74de/attachment.html>
