[PATCH rtems-libbsd 1/2] racoon/session: Honor file descriptor maximum
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Feb 25 15:01:02 UTC 2021
Dynamically allocate a big enough file descriptor set for select(). A
better solution would be to use kqueue() instead of select().
.../racoon/rtems-bsd-racoon-session-data.h | 6 +--
ipsec-tools/src/racoon/session.c | 40 +++++++++++++++++++
2 files changed, 43 insertions(+), 3 deletions(-)
diff --git a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
index b869a1518..196107a35 100644
--- a/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
+++ b/ipsec-tools/src/racoon/rtems-bsd-racoon-session-data.h
@@ -2,11 +2,11 @@
#include <rtems/linkersets.h>
#include "rtems-bsd-racoon-data.h"
/* session.c */
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set active_mask);
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static fd_set preset_mask);
+RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static _types_fd_set *allocated_active_mask);
+RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static _types_fd_set *allocated_preset_mask);
RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int nfds);
RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static int signals[]);
RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static sig_atomic_t volatile volatile sigreq[]);
-RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor fd_monitors[]);
+RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor *allocated_fd_monitors);
RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct fd_monitor_list fd_monitor_tree[]);
RTEMS_LINKER_RWSET_CONTENT(bsd_prog_racoon, static struct sched scflushsa);
diff --git a/ipsec-tools/src/racoon/session.c b/ipsec-tools/src/racoon/session.c
index 65124c15e..90120c761 100644
--- a/ipsec-tools/src/racoon/session.c
+++ b/ipsec-tools/src/racoon/session.c
@@ -65,6 +65,10 @@
#include <sys/stat.h>
#include <paths.h>
#include <err.h>
+#ifdef __rtems__
+#include <sys/param.h>
+#include <rtems/libio_.h>
+#endif /* __rtems__ */
#include <netinet/in.h>
#include <resolv.h>
@@ -123,8 +127,16 @@ static void check_sigreq __P((void));
static void check_flushsa __P((void));
static int close_sockets __P((void));
+#ifndef __rtems__
static fd_set preset_mask, active_mask;
static struct fd_monitor fd_monitors[FD_SETSIZE];
+#else /* __rtems__ */
+static fd_set *allocated_preset_mask, *allocated_active_mask;
+static struct fd_monitor *allocated_fd_monitors;
+#define preset_mask (*allocated_preset_mask)
+#define active_mask (*allocated_active_mask)
+#define fd_monitors (allocated_fd_monitors)
static TAILQ_HEAD(fd_monitor_list, fd_monitor) fd_monitor_tree[NUM_PRIORITIES];
static int nfds = 0;
@@ -134,7 +146,11 @@ static struct sched scflushsa = SCHED_INITIALIZER();
void
monitor_fd(int fd, int (*callback)(void *, int), void *ctx, int priority)
+#ifndef __rtems__
if (fd < 0 || fd >= FD_SETSIZE) {
+ if (fd < 0 || fd >= rtems_libio_number_iops) {
plog(LLV_ERROR, LOCATION, NULL, "fd_set overrun");
exit(1);
@@ -158,7 +174,11 @@ monitor_fd(int fd, int (*callback)(void *, int), void *ctx, int priority)
void
unmonitor_fd(int fd)
+#ifndef __rtems__
exit(1);
@@ -186,7 +206,22 @@ session(void)
struct fd_monitor *fdm;
nfds = 0;
+#ifndef __rtems__
FD_ZERO(&preset_mask);
+ allocated_preset_mask = calloc(sizeof(fd_set),
+ howmany(rtems_libio_number_iops, sizeof(fd_set) * 8));
+ if (allocated_preset_mask == NULL)
+ errx(1, "failed to allocate preset_mask");
+ allocated_active_mask = calloc(sizeof(fd_set),
+ if (allocated_active_mask == NULL)
+ errx(1, "failed to allocate active_mask");
+ allocated_fd_monitors = calloc(
+ rtems_libio_number_iops, sizeof(struct fd_monitor));
+ if (allocated_fd_monitors == NULL)
+ errx(1, "failed to allocate fd_monitors");
for (i = 0; i < NUM_PRIORITIES; i++)
TAILQ_INIT(&fd_monitor_tree[i]);
@@ -356,6 +391,11 @@ close_session()
flushsainfo();
close_sockets();
backupsa_clean();
+#ifdef __rtems__
+ free(allocated_preset_mask); allocated_preset_mask = NULL;
+ free(allocated_active_mask); allocated_active_mask = NULL;
+ free(allocated_fd_monitors); allocated_fd_monitors = NULL;
plog(LLV_INFO, LOCATION, NULL, "racoon process %d shutdown\n", getpid());
2.26.2
