[PATCH 1/2] rtems: Add rtems_get_build_label()
Sebastian Huber
Thu Feb 25 15:17:18 UTC 2021
Update #4269.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/config.h | 33 ++++++++++++++++++-
cpukit/sapi/src/getbuildlabel.c | 50 +++++++++++++++++++++++++++++
spec/build/cpukit/cpuopts.yml | 2 ++
spec/build/cpukit/librtemscpu.yml | 1 +
spec/build/cpukit/optbuildlabel.yml | 16 +++++++++
6 files changed, 102 insertions(+), 1 deletion(-)
create mode 100644 cpukit/sapi/src/getbuildlabel.c
create mode 100644 spec/build/cpukit/optbuildlabel.yml
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index a31cd31596..143a0ee4f5 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1062,6 +1062,7 @@ librtemscpu_a_SOURCES += sapi/src/extensiondelete.c
librtemscpu_a_SOURCES += sapi/src/extensionident.c
librtemscpu_a_SOURCES += sapi/src/fatal.c
librtemscpu_a_SOURCES += sapi/src/fatalsrctext.c
+librtemscpu_a_SOURCES += sapi/src/getbuildlabel.c
librtemscpu_a_SOURCES += sapi/src/getconfigmax.c
librtemscpu_a_SOURCES += sapi/src/getcopyrightnotice.c
librtemscpu_a_SOURCES += sapi/src/getversionstring.c
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index a3eec39584..2f1a7ecfa4 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -10,7 +10,7 @@
- * Copyright (C) 2009, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2009, 2021 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -93,6 +93,37 @@ extern "C" {
* configuration option values, for example rtems_resource_unlimited().
+/* Generated from spec:/rtems/config/if/get-build-label */
+ * @ingroup RTEMSAPIConfig
+ * @brief Gets the RTEMS build label.
+ * The build label is a user-provided string defined by the build
+ * configuration.
+ * @return Returns the pointer to the RTEMS build label.
+ * @par Notes
+ * The build label can be used to distinguish test suite results obtained from
+ * different build configurations. A use case is to record test results with
+ * performance data to track performance regressions. For this a database of
+ * performance limits is required. The build label and the target hash
+ * obtained from rtems_get_target_hash() can be used as a key to obtain
+ * performance limits.
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within any runtime context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+const char *rtems_get_build_label( void );
/* Generated from spec:/rtems/config/if/get-copyright-notice */
diff --git a/cpukit/sapi/src/getbuildlabel.c b/cpukit/sapi/src/getbuildlabel.c
new file mode 100644
index 0000000000..3e8d2a4e3b
--- /dev/null
+++ b/cpukit/sapi/src/getbuildlabel.c
@@ -0,0 +1,50 @@
+ * @file
+ * @ingroup RTEMSImplClassic
+ * @brief This source file contains the implementation of
+ * rtems_get_build_label().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/config.h>
+#ifdef RTEMS_BUILD_LABEL
+ return RTEMS_BUILD_LABEL;
+#else
+ return "DEFAULT";
+#endif
diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
index 4b2a818b64..e0da529c50 100644
--- a/spec/build/cpukit/cpuopts.yml
+++ b/spec/build/cpukit/cpuopts.yml
@@ -33,6 +33,8 @@ links:
uid: optinstall
- role: build-dependency
uid: optada
+- role: build-dependency
+ uid: optbuildlabel
uid: optdebug
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 8bd108bea8..c31fa8f5ec 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1338,6 +1338,7 @@ source:
- cpukit/sapi/src/extensionident.c
- cpukit/sapi/src/fatal.c
- cpukit/sapi/src/fatalsrctext.c
+- cpukit/sapi/src/getbuildlabel.c
- cpukit/sapi/src/getconfigmax.c
- cpukit/sapi/src/getcopyrightnotice.c
- cpukit/sapi/src/getversionstring.c
diff --git a/spec/build/cpukit/optbuildlabel.yml b/spec/build/cpukit/optbuildlabel.yml
index 0000000000..f039089622
--- /dev/null
+++ b/spec/build/cpukit/optbuildlabel.yml
@@ -0,0 +1,16 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- define: null
+build-type: option
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+default: DEFAULT
+default-by-variant: []
+description: |
+ Defines the build label returned by rtems_get_build_label().
+enabled-by: true
+format: '{}'
+links: []
+name: RTEMS_BUILD_LABEL
+type: build
2.26.2
