[PATCH 01/10] build: Generate build hash
Sebastian Huber
Thu Feb 25 15:18:47 UTC 2021
On 25/02/2021 09:42, Sebastian Huber wrote:
>> Should we look to use a list that is contained? A list that effects
>> the code on
>> the target? In a purest sense a hash created from the CU pieces in
>> all target
>> libraries would be ideal however this is recursive.
> This is a good idea. Maybe we should iterate over all start files and
> libraries generated by the build and then create a hash of all
> executable sections. Then we recompile one object with a command line
> define with the build hash and replace this object in librtemscpu.a.
I will drop for now the introduction of a rtems_get_build_hash() in
favour of a rtems_get_build_label() since my waf skills are not good
enough to do the above task.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
