BSP Builder Results :(
junkes
junkes at fhi-berlin.mpg.de
Thu Feb 25 21:33:52 UTC 2021
With RTEMS6, frozen CPU even with the ubuntu mkimage:
MVME2500=> setenv tfile hello
MVME2500=> run rtems_myTests
reading mvme2500.dtb
12363 bytes read in 13 ms (928.7 KiB/s)
Speed: 1000, full duplex
Using eTSEC1 device
TFTP from server 141.14.128.9; our IP address is 141.14.128.89
Filename 'hello.img'.
Load address: 0x10000000
Loading: ######
6.2 MiB/s
done
Bytes transferred = 77800 (12fe8 hex)
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 10000000 ...
Image Name: RTEMS
Created: 2021-02-25 20:30:19 UTC
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 77736 Bytes = 75.9 KiB
Load Address: 00004000
Entry Point: 00004000
Verifying Checksum ... OK
## Flattened Device Tree blob at 20000000
Booting using the fdt blob at 0x20000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 03ff9000, end 03fff04a ... OK
------------> no more output ...
On 2021-02-25 20:52, junkes wrote:
> I have now done the whole thing again the "old way"
> (master, checkout 5
> ./bootstrap -c && ./rtems-bootstrap
> cd ..
> mkdir -p build/b-qoriq_e500
> cd build/b-qoriq_e500
> ../../kernel/configure --prefix=/home/junkes/MVME2500_testing/rtems/5
> --target=powerpc-rtems5 --enable-rtemsbsp=qoriq_e500 --enable-posix
> --enable-c++ --disable-networking --enable-tests
> make -j17 all
> make install
> with RTEMS 5 and have come to the same result (frozen CPU).
> Then instead of using mkimage.pl I used my standard way:
> powerpc-rtems5-objcopy -O binary
> b-qoriq_e500/powerpc-rtems5/c/qoriq_e500/testsuites/samples/hello.exe
> hello.bin
> mv hello.img hello_mkimage.img
> gzip -9 -f -c hello.bin > hello.bin.gz
> mkimage -A ppc -O linux -T kernel -a 0x4000 -e 0x4000 -n RTEMS -d
> hello.bin.tgz hello.img
> (mkimage from the ubuntu distro:
> junkes at Krikkit:~/MVME2500_testing$ mkimage -V
> mkimage version 2020.10+dfsg-1ubuntu0~20.04.2
> Et voila:
> Using eTSEC1 device
> Loading: #####
> 5.7 MiB/s
> done
> Bytes transferred = 59818 (e9aa hex)
> Image Name: RTEMS
> Created: 2021-02-25 19:38:30 UTC
> Data Size: 59754 Bytes = 58.4 KiB
> *** BEGIN OF TEST HELLO WORLD ***
> *** TEST VERSION: 5.0.0.3824960f24304eec051fdc59121ba9ba8a8346da
> *** TEST STATE: EXPECTED_PASS
> *** TEST BUILD: RTEMS_POSIX_API
> *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (803d42cda7b3), Newlib
> 7947581)
> Hello World
> *** END OF TEST HELLO WORLD ***
> *** FATAL ***
> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> RTEMS version: 5.0.0.3824960f24304eec051fdc59121ba9ba8a8346da
> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (803d42cda7b3), Newlib
> 7947581)
> executing thread ID: 0x08a010001
> executing thread name: UI1
> U-Boot 2013.01 (Aug 23 2016 - 12:17:55)
> CPU0: P2020E, Version: 2.1, (0x80ea0021)
> Core: E500, Version: 5.1, (0x80211051)
> Clock Configuration:
> CPU0:1200 MHz, CPU1:1200 MHz,
> CCB:400 MHz,
> DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:25 MHz
> L1: D-cache 32 kB enabled
> Now, I will repeat the Installation of RTEMS6 again and try the ubuntu
> mkimage
> Heinz
> On 2021-02-25 18:23, Joel Sherrill wrote:
> On Thu, Feb 25, 2021 at 11:15 AM junkes <junkes at fhi-berlin.mpg.de>
> wrote:
> Hallo Joel,
> unfortunately, even with waf, it still does not work as it should.
> Building and not working is slightly better but still bad. :(
> The bsp-builder doesn't run any tests. I do run automated test runs on
> a
> number of BSPs and have had to login to the server and kill qemu's
> that
> get stuck and run forever. I haven't tracked down which BSP is hanging
> yet though.
> Example MVME2500 (qoriq_e500)
> #install rsb and rtems powerpc tools
> git clone https://github.com/RTEMS/rtems-source-builder.git rsb
> cd rsb/rtems
> ../source-builder/sb-set-builder
> --prefix=/home/junkes/MVME2500_testing/rtems/6 6/rtems-powerpc
> cd ../..
> #RTEMS development
> export RTEMS_VERSION=6
> export RTEMS_ARCH=powerpc-rtems${RTEMS_VERSION}
> export RTEMS_ROOT=/home/junkes/MVME2500_testing/rtems/${RTEMS_VERSION}
> export PATH=${RTEMS_ROOT}/bin:${PATH}
> # building kernel
> git clone git://git.rtems.org/rtems.git [1] kernel
> cd kernel
> # build and install bsp
> ./waf bsp_defaults --rtems-bsps=powerpc/qoriq_e500 > config.ini
> sed -i \
> -e "s|RTEMS_POSIX_API = False|RTEMS_POSIX_API = True|" \
> -e "s|CLOCK_DRIVER_USE_FAST_IDLE = True|CLOCK_DRIVER_USE_FAST_IDLE =
> False|" \
> -e "s|BUILD_TESTS = False|BUILD_TESTS = True|" \
> config.ini
> ./waf configure --prefix=/home/junkes/MVME2500_testing/rtems/6
> ./waf
> ./waf install
> #create bootable image file
> cd ..
> mkimage.py -A ppc -O linux -T kernel -a 0x4000 -e 0x4000 -n RTEMS -d
> kernel/build/powerpc/qoriq_e500/testsuites/samples/hello.exe hello.img
> junkes at Krikkit:~/MVME2500_testing$ ls -l hello.img
> -rw-rw-r-- 1 junkes junkes 2990848 Feb 25 17:50 hello.img
> #boot file on HW (MVME2500)
> 12363 bytes read in 12 ms (1005.9 KiB/s)
> Using eTSEC1 device
> Loading:
> 10.6 MiB/s
> done
> Bytes transferred = 2990848 (2da300 hex)
> Image Name: RTEMS
> Created: 2021-02-25 16:50:29 UTC
> Data Size: 2990784 Bytes = 2.9 MiB
> Uncompressing Kernel Image ... Error: Bad gzipped data
> GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to
> recover
> CCB:400 MHz,
> With mkimage no compression:
> mkimage.py -A ppc -O linux -T kernel -C none -a 0x4000 -e 0x4000 -n
> RTEMS -d kernel/build/powerpc/qoriq_e500/testsuites/samples/hello.exe
> hello.img
> Image Name: RTEMS
> Created: Thu Feb 25 18:10:00 2021
> Image Type: none
> Data Size: 2990784
> Load Address: 0x4000
> Entry Point: 0x4000
> Now the well known behavior -> hangs, must be HW-reset
> Using eTSEC1 device
> Loading:
> 10.3 MiB/s
> done
> Image Name: RTEMS
> Created: 2021-02-25 17:10:00 UTC
> Image Type: PowerPC Linux Kernel Image (uncompressed)
> Loading Kernel Image ... OK
> OK
> ---------> no more output ... frozen target ....
> On 2021-02-25 14:45, Joel Sherrill wrote:
> Hi
> Just passing along that the need to switch the BSP builder to waf is
> becoming more obvious in the BSP Builder results
> https://lists.rtems.org/pipermail/build/2021-February/026054.html
> 467 of 1615 configurations now fail to build.
> -joel
> devel mailing list
> devel at rtems.org
devel mailing list
devel at rtems.org
Links:
[1] http://git.rtems.org/rtems.git
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210225/9427a919/attachment-0001.html>
