[PATCH 1/4] printertask.c: Fix Unchecked return value (CID #1399710)
Gedare Bloom
gedare at rtems.org
Fri Feb 26 21:55:05 UTC 2021
On Fri, Feb 26, 2021 at 2:34 PM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1399710: Unchecked return value in printer_task().
> CID 1472764: Unchecked return value in rtems_print_printer_task().
> Closes #4258
> cpukit/libcsupport/src/printertask.c | 9 ++++++---
> 1 file changed, 6 insertions(+), 3 deletions(-)
> diff --git a/cpukit/libcsupport/src/printertask.c b/cpukit/libcsupport/src/printertask.c
> index bae623b..bca90a1 100644
> --- a/cpukit/libcsupport/src/printertask.c
> +++ b/cpukit/libcsupport/src/printertask.c
> @@ -117,6 +117,7 @@ static void printer_task( rtems_task_argument arg )
> rtems_printer_task_context *ctx;
> int fd;
> + rtems_status_code sc;
> ctx = (rtems_printer_task_context *) arg;
> fd = ctx->fd;
> @@ -141,8 +142,9 @@ static void printer_task( rtems_task_argument arg )
> printer_task_append_buffer( ctx, &ctx->free_buffers, buffer );
> break;
> case ACTION_DRAIN:
> - fsync(fd);
> - rtems_event_transient_send( buffer->action_data.task );
> + (void)fsync(fd);
why not above
int err;
and here
err = fsync(fd);
_Assert_Unused_variable_equals(err, 0);
> + sc = rtems_event_transient_send( buffer->action_data.task );
> + _Assert_Unused_variable_equals(sc, RTEMS_SUCCESSFUL);
> break;
> @@ -185,7 +187,8 @@ int rtems_print_printer_task(
> printer->context = ctx;
> printer->printer = printer_task_printer;
> - rtems_task_start( ctx->task, printer_task, (rtems_task_argument) ctx );
> + sc = rtems_task_start( ctx->task, printer_task, (rtems_task_argument) ctx );
> return 0;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
