[PATCH v2 0/4] Fix Unchecked return value Coverity errors
Gedare Bloom
gedare at rtems.org
Fri Feb 26 22:36:02 UTC 2021
v2 looks good to me
On Fri, Feb 26, 2021 at 3:15 PM Ryan Long <thisisryanlong at gmail.com> wrote:
> Hi,
> Here's the patches with the changes.
> Thanks,
> Ryan
> Ryan Long (4):
> printertask.c: Fix Unchecked return value (CID #1399710)
> record-client.c: Fix Unchecked return value (CID #1456677)
> getgrent.c: Fix Unchecked return value error (CID #1459004)
> rtems-debugger-threads.c: Fix Unchecked return value error (CID
> #1468688)
> cpukit/libcsupport/src/getgrent.c | 4 +++-
> cpukit/libcsupport/src/printertask.c | 11 ++++++++---
> cpukit/libdebugger/rtems-debugger-threads.c | 4 +++-
> cpukit/libtrace/record/record-client.c | 4 +++-
> 4 files changed, 17 insertions(+), 6 deletions(-)
> 1.8.3.1
> devel mailing list
> devel at rtems.org
