[rtems commit] getgrent.c: Fix Unchecked return value error (CID #1459004)
Gedare Bloom
gedare at rtems.org
Sat Feb 27 14:35:39 UTC 2021
The fix looks right, please push it to get the build working again.
On Fri, Feb 26, 2021 at 11:11 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi,
> I'm getting build error after this commit.
> /home/vijay/development/rtems/6/lib/gcc/i386-rtems6/10.2.1/../../../../i386-rtems6/bin/ld:
> ./librtemscpu.a(getgrent.c.57.o): in function `endgrent':
> /home/vijay/rtems-class/rtems/build/i386/pc386/../../../cpukit/libcsupport/src/getgrent.c:109:
> undefined reference to `_Assert_Unused_variable_equals'
> collect2: error: ld returned 1 exit status
> Looks like assert.h isn't included from getgrent.c . I have attached a
> patch to add the header files and checked that it's building now.
> Best regards,
> Vijay
> On Fri, Feb 26, 2021 at 3:56 PM Joel Sherrill <joel at rtems.org> wrote:
> > Module: rtems
> > Branch: master
> > Commit: e5e58da6dfbdfa78ad499c2f52ec53c88538aa1c
> > Changeset: http://git.rtems.org/rtems/commit/?id=e5e58da6dfbdfa78ad499c2f52ec53c88538aa1c
> > Author: Ryan Long <ryan.long at oarcorp.com>
> > Date: Fri Feb 19 17:30:13 2021 -0500
> > CID 1459004: Unchecked return value in endgrent().
> > Closes #4261
> > cpukit/libcsupport/src/getgrent.c | 4 +++-
> > 1 file changed, 3 insertions(+), 1 deletion(-)
> > diff --git a/cpukit/libcsupport/src/getgrent.c b/cpukit/libcsupport/src/getgrent.c
> > index b358cb9..de56430 100644
> > --- a/cpukit/libcsupport/src/getgrent.c
> > +++ b/cpukit/libcsupport/src/getgrent.c
> > @@ -95,6 +95,7 @@ void setgrent(void)
> > void endgrent(void)
> > grp_context *ctx = grp_get_context();
> > + int sc;
> > if (ctx == NULL)
> > return;
> > @@ -104,5 +105,6 @@ void endgrent(void)
> > free(ctx);
> > - pthread_setspecific(grp_key, NULL);
> > + sc = pthread_setspecific(grp_key, NULL);
> > + _Assert_Unused_variable_equals(sc, 0);
> > vc mailing list
> > vc at rtems.org
> > http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
